H3C Campus Fixed-Port Switches CLI-Based Quick Start Configuration Guide -6W102
HomeSupportQuick StartsQuick Start Configuration GuidesH3C Campus Fixed-Port Switches CLI-Based Quick Start Configuration Guide -6W102
Table of Contents
Related Documents
25-IP Source Guard Quick Start Configuration Guide
Copyright © 2025 New H3C Technologies Co., Ltd. All rights reserved.
Configuring static IPSG bindings
Introduction
The following information uses an example to describe the basic procedure for configuring IP source guard (IPSG) static bindings.
You cannot configure the IPSG feature on a service loopback interface or an aggregate interface.
As shown in Figure 1, all hosts use static IP addresses.
Configure static IPv4SG bindings on Switch A and Switch B to meet the following requirements:
·     GigabitEthernet 1/0/2 on Switch A allows IP packets from Host C to pass.
·     GigabitEthernet 1/0/1 on Switch A allows IP packets from Host A to pass.
·     GigabitEthernet 1/0/2 on Switch B allows IP packets from Host A to pass.
·     GigabitEthernet 1/0/1 on Switch B allows IP packets from the host whose IP address is 192.168.0.2/24 to pass. Thus, Host B can use that IP address to reach Host A even if the MAC address of Host B changes.
Figure 1 Network diagram
Configuring Switch A
# Enable IPv4SG on GigabitEthernet 1/0/2.
[SwitchA] interface gigabitethernet 1/0/2
[SwitchA-GigabitEthernet1/0/2] ip verify source ip-address mac-address
# On GigabitEthernet 1/0/2, configure a static IPv4SG binding for Host C. (Bind the IP address and MAC address of Host C.)
[SwitchA-GigabitEthernet1/0/2] ip source binding ip-address 192.168.0.3 mac-address 0001-0203-0405
[SwitchA-GigabitEthernet1/0/2] quit
# Enable IPv4SG on GigabitEthernet 1/0/1.
[SwitchA-GigabitEthernet1/0/1] ip verify source ip-address mac-address
# On GigabitEthernet 1/0/1, configure a static IPv4SG binding for Host A. (Bind the IP address and MAC address of Host A.)
[SwitchA-GigabitEthernet1/0/1] ip source binding ip-address 192.168.0.1 mac-address 0001-0203-0406
[SwitchA-GigabitEthernet1/0/1] quit
# Save the configuration.
[SwitchA] save
Configuring Switch B
[SwitchB] interface gigabitethernet 1/0/2
[SwitchB-GigabitEthernet1/0/2] ip verify source ip-address mac-address
# On GigabitEthernet 1/0/2, configure a static IPv4SG binding for Host A. (Bind the IP address and MAC address of Host A.)
[SwitchB-GigabitEthernet1/0/2] ip source binding ip-address 192.168.0.1 mac-address 0001-0203-0406
[SwitchB-GigabitEthernet1/0/1] ip verify source ip-address
# On GigabitEthernet 1/0/1, configure a static IPv4SG binding for Host B. (Bind the IP address of Host B.)
[SwitchB-GigabitEthernet1/0/1] ip source binding ip-address 192.168.0.2
[SwitchB] save
# Verify that the static IPv4SG bindings are configured successfully on Switch A.
[SwitchA] display ip source binding static
Total entries found: 2
IP Address      MAC Address    Interface                VLAN Type
192.168.0.1     0001-0203-0406 GE1/0/1                  N/A  Static
192.168.0.3     0001-0203-0405 GE1/0/2                  N/A  Static
# Verify that the static IPv4SG bindings are configured successfully on Switch B.
[SwitchB] display ip source binding static
192.168.0.1     0001-0203-0406 GE1/0/2                  N/A  Static
192.168.0.2     N/A            GE1/0/1                  N/A  Static
Configuration files
·     Switch A:
 port link-mode bridge
·     Switch B:
Related documentation
·     IP source guard configuration in the security configuration guide for the device.
·     IP source guard commands in the security command reference for the device.
