- H3C Campus Fixed-Port Switches CLI-Based Quick Start Configuration Guide -6W102
- 01-H3C Devices CLI Reference
- 02-Login Management Quick Start Configuration Guide
- 03-Configuration File Management Quick Start Configruation Guide
- 04-Software Upgrade Quick Start Configuration Guide
- 05-Device Management Quick Start Configuration Guide
- 06-NTP Quick Start Configuration Guide
- 07-RBAC Quick Start Configuration Guide
- 08-IRF Quick Start Configuration Guide
- 09-Ethernet Interface Quick Start Configuration Guide
- 10-VLAN Quick Start Configuration Guide
- 11-Port Isolation Quick Start Configuration Guide
- 12-Loop Detection Quick Start Configuration Guide
- 13-QinQ Quick Start Configuration Guide
- 14-MAC Address Table Quick Start Configuration Guide
- 15-Ethernet Link Aggregation Quick Start Configuration Guide
- 16-Spanning Tree Quick Start Configuration Guide
- 17-DHCP Quick Start Configuration Guide
- 18-OSPF Quick Start Configuration Guide
- 19-Static Routing Quick Start Configuration Guide
- 20-Basic RIP Quick Start Configuration Guide
- 21-PBR Quick Start Configuration Guide
- 22-IGMP Snooping Quick Start Configuration Guide
- 23-Packet Filtering Quick Start Configuration Guide
- 24-QoS Quick Start Configuration Guide
- 25-IP Source Guard Quick Start Configuration Guide
- 26-SSH Quick Start Configuration Guide
- 27-Port Security Quick Start Configuration Guide
- 28-VRRP Quick Start Configuration Guide
- 29-PoE Quick Start Configuration Guide
- 30-Mirroring Quick Start Configuration Guide
- 31-Information Center Quick Start Configuration Guide
- 32-SNMP Quick Start Configuration Guide
- 33-Static Route-Based Public and Private Network Intercommunication Configuration Guide
- 34-LAN Networks Quick Start Configuration Guide
- 35-802.1X Quick Start Configuration Guide
- 36-AAA Quick Start Configuration Guide
| 11-Port Isolation Quick Start Configuration Guide | 79.24 KB |
Copyright © 2025 New H3C Technologies Co., Ltd. All rights reserved.
Configuring port isolation
Introduction
The following information uses an example to describe the basic port isolation configuration procedure.
As shown in Figure 1, the community users Host A, Host B, and Host C are connected to GigabitEthernet 1/0/1, GigabitEthernet 1/0/2, and GigabitEthernet 1/0/3 of Switch, respectively. Switch is connected to Internet through GigabitEthernet 1/0/4.
Configure port isolation to isolate Layer 2 packets among Host A, Host B, and Host C, and allow these hosts to communicate with Internet.
· To assign a port on a device to an isolation group, first create the isolation group.
· A port can be assigned to only one isolation group.
IMPORTANT: On a device that supports only one isolation group, the system automatically creates isolation group 1. You cannot delete the isolation group or create any other isolation group. On a device that supports multiple isolation groups, you can manually configure isolation groups. |
# Create isolation group 1.
<Switch> system-view
[Switch] port-isolate group 1
# Assign ports GigabitEthernet 1/0/1, GigabitEthernet 1/0/2, and GigabitEthernet 1/0/3 to isolation group 1.
[Switch-GigabitEthernet1/0/1] port-isolate enable group 1
[Switch-GigabitEthernet1/0/2] port-isolate enable group 1
[Switch] interface gigabitethernet 1/0/3
[Switch-GigabitEthernet1/0/3] port-isolate enable group 1
[Switch-GigabitEthernet1/0/3] quit
# Save the configuration.
[Switch] save force
# Display information about isolation group 1.
[Switch] display port-isolate group 1
Port isolation group information:
Group ID: 1
Group members:
The command output shows that GigabitEthernet 1/0/1, GigabitEthernet 1/0/2, and GigabitEthernet 1/0/3 on Switch have been assigned to isolation group 1 and isolated from each other at Layer 2. Host A, Host B, and Host C cannot ping each other.
Configuration files
port link-mode bridge
Related documentation
· Port isolation configuration in the Layer 2—Ethernet switching configuration guide for the device.
· Port isolation commands in the Layer 2—Ethernet switching command reference for the device.
