H3C Campus Fixed-Port Switches CLI-Based Quick Start Configuration Guide -6W102
HomeSupportQuick StartsQuick Start Configuration GuidesH3C Campus Fixed-Port Switches CLI-Based Quick Start Configuration Guide -6W102
Table of Contents
Related Documents
06-NTP Quick Start Configuration Guide
06-NTP Quick Start Configuration Guide 68.70 KB
Copyright © 2025 New H3C Technologies Co., Ltd. All rights reserved.
Configuring an NTP client to synchronize the time with an NTP server
Introduction
The following information uses an example to describe the basic procedure for configuring an NTP client to synchronize the time with an NTP server.
As shown in Figure 1, configure Device B and Device C to synchronize the time with Device A through NTP. To meet this requirement:
·     On device A, specify the local clock as its reference source and set the stratum level of the clock to 2.
·     Configure Device B to operate in NTP client mode and specify Device A as its NTP server.
·     Configure Device C to operate in NTP client mode and specify Device A as its NTP server.
Figure 1 Network diagram
1.     Configure Device A.
# Assign an interface to VLAN-interface 2.
[DeviceA] interface Vlan-interface 2
[DeviceA-Vlan-interface2] ip address 1.0.1.11 24
[DeviceA-Vlan-interface2] quit
# Enable NTP.
[DeviceA] ntp-service enable
# Specify the local clock as the reference source and set the stratum level of the clock to 2.
[DeviceA] ntp-service refclock-master 2
2.     Configure Device B
[DeviceB] interface Vlan-interface2
[DeviceB-Vlan-interface2] ip address 1.0.1.12 24
[DeviceB-Vlan-interface2] quit
# Enable NTP.
[DeviceB] ntp-service enable
# Specify NTP for obtaining the time.
[DeviceB] clock protocol ntp
# Specify Device A as the NTP server.
[DeviceB] ntp-service unicast-server 1.0.1.11
3.     Configure Device C.
<DeviceC> system-view
[DeviceC] interface Vlan-interface2
[DeviceC-Vlan-interface2] ip address 1.0.1.13 24
[DeviceC-Vlan-interface2] quit
# Enable NTP.
[DeviceC] ntp-service enable
[DeviceC] clock protocol ntp
[DeviceC] ntp-service unicast-server 1.0.1.11
Verify that Device B and Device C have synchronized the time with Device C. The following uses Device B as an example to verify the configuration.
# Execute the display ntp-service status command on Device B to display its NTP status.
[DeviceB] display ntp-service status
 Clock status: synchronized
 Clock stratum: 3
 System peer: 1.0.1.11
 Local mode: client
 Reference clock ID: 1.0.1.11
 Leap indicator: 00
 Clock jitter: 0.000977 s
 Stability: 0.000 pps
 Clock precision: 2^-10
 Root delay: 0.00383 ms
 Root dispersion: 16.26572 ms
 Reference time: d0c6033f.b9923965  Wed, Dec 29 2019 18:58:07.724
 System poll interval: 64 s
The command output shows that Device B has synchronized its time with Device A, and the clock stratum level of Device B is 3.
# Verify that an IPv4 NTP association has been established between Device B and Device A.
[DeviceB] display ntp-service sessions
       source          reference       stra reach poll  now offset  delay disper
[12345]1.0.1.11        127.127.1.0        2   255  64   15   -4.0 0.0038 16.262
 Total sessions: 1
Configuration files
·     Device A:
 ntp-service enable
·     Device B:
 ntp-service enable
 clock protocol ntp
·     Device C:
 ntp-service enable
 clock protocol ntp
Related documentation
·     NTP configuration in the network management and monitoring configuration guide for the device.
·     NTP commands in the network management and monitoring command reference for the device.
