H3C S12500R Ethernet Switch Router Series Config Examples-6W101
HomeSupportSwitchesS12500R SeriesConfigure & DeployConfiguration ExamplesH3C S12500R Ethernet Switch Router Series Config Examples-6W101
Table of Contents
Related Documents
64-Configuration Example of Using Ethernet OAM to Monitor ERPS Ring Link Performance
H3C S12500R Switch Router Series
Introduction
The following information describes a typical configuration example of using Ethernet Operation, Administration, and Maintenance (OAM) to monitor Ethernet Ring Protection Switching (ERPS) ring link performance.
Ethernet OAM is a tool for monitoring network faults. It can monitor the link status between two directly connected devices.
Ethernet Ring Protection Switching (ERPS) is an Ethernet ring network link layer technology that provides high reliability and stability. It can prevent broadcast storms caused by data loops when the Ethernet ring is intact, and can quickly restore communication paths between nodes on the ring network when a link fault occurs. It provides high convergence speed.
The following information is provided based on the assumption that you have basic knowledge of Ethernet OAM and ERPS.
Example: Using Ethernet OAM to monitor ERPS ring link performance
Networking configuration
As shown in Figure 1, to improve network resource utilization and implement load balancing among links, configure ERPS as follows:
·     Configure ERPS instances 1 and 2 on the ERPS ring.
·     For ERPS instance 1, configure the following items:
¡     Configure Device A as the owner node.
¡     Configure the link between Devices A and Device B as the RPL.
¡     Configure VLAN 100 as the control VLAN.
¡     Configure VLANs 1 to 30 as the protected VLANs.
·     For ERPS instance 2, configure the following items:
¡     Configure the link between Devices C and Device D as the RPL.
¡     Configure VLANs 31 to 60 as the protected VLANs.
Use Ethernet OAM to monitor the ERPS ring link status and determine if the network link reliability meets the requirements.
·     Enable automatic detection of the connectivity of ERPS ring links.
·     Check whether a critical link event has occurred on the ERPS ring.
·     Check the statistics of Ethernet OAM link events to determine the ERPS ring status.
Figure 1 Network diagram
Analysis
An ERPS ring supports multiple ERPS instances. An ERPS instance is a logical ring to process service and protocol packets. Each ERPS instance has its own owner node and maintains its own state and data. In this example, instance 1 and instance 2 are configured on ERPS ring 1.
Common link events that can be monitored by Ethernet OAM include errored symbol events, errored frame events, errored frame period events, and errored frame seconds events. By default, the interfaces with Ethernet OAM enabled use global configuration for common link event detection parameters. To meet the detection requirements in specific network conditions, you can change the detection parameters as needed. In this example, the parameters for detecting errored frame events are changed.
Software versions used
This configuration example was created and verified on Release 5210 or later versions of S12500R.
In this example, some physical interfaces must operate in bridge mode. By default, the physical interfaces on the device operate in route mode. Use the port link-mode command in the corresponding interface view to switch the interface's operating mode as needed.
By default, the interfaces on the device are in administratively down (ADM) state. You must bring up the interfaces by using the undo shutdown command in the corresponding interface view as needed.
ERPS does not provide an election mechanism. To implement ring detection and protection, configure all nodes correctly.
Do not change the Ethernet OAM connection mode on Ethernet OAM-enabled interface. To change the Ethernet OAM connection mode on an interface, first disable Ethernet OAM on that interface.
As a best practice, do not enable Ethernet OAM remote loopback on ERPS ring member ports, as it might cause a short-term broadcast storm.
The protection VLANs of different ERPS instances must be different.
Procedures
Configuring Device A
# Create VLANs 1 to 60, map VLANs 1 to 30 to MSTI 1 and VLANs 31 to 60 to MSTI 2, and activate the MST region configuration.
[DeviceA] vlan 1 to 60
[DeviceA] stp region-configuration
[DeviceA-mst-region] instance 1 vlan 1 to 30
[DeviceA-mst-region] instance 2 vlan 31 to 60
[DeviceA-mst-region] active region-configuration
[DeviceA-mst-region] quit
# Set the link state change suppression interval to 0 seconds on HundredGigE 1/0/1 and HundredGigE 1/0/2, respectively. Disable the spanning tree feature on the interface and configure the interface as a trunk port and assign it to VLANs 1 to 60.
[DeviceA] interface hundredgige 1/0/1
[DeviceA-HundredGigE1/0/1] link-delay up 0
[DeviceA-HundredGigE1/0/1] link-delay down 0
[DeviceA-HundredGigE1/0/1] undo stp enable
[DeviceA-HundredGigE1/0/1] port link-type trunk
[DeviceA-HundredGigE1/0/1] port trunk permit vlan 1 to 60
[DeviceA-HundredGigE1/0/1] quit
[DeviceA] interface hundredgige 1/0/2
[DeviceA-HundredGigE1/0/2] link-delay up 0
[DeviceA-HundredGigE1/0/2] link-delay down 0
[DeviceA-HundredGigE1/0/2] undo stp enable
[DeviceA-HundredGigE1/0/2] port link-type trunk
[DeviceA-HundredGigE1/0/2] port trunk permit vlan 1 to 60
[DeviceA-HundredGigE1/0/2] quit
# Create ERPS ring 1.
[DeviceA] erps ring 1
# Configure ERPS ring member ports.
[DeviceA-erps-ring1] port0 interface hundredgige 1/0/1
[DeviceA-erps-ring1] port1 interface hundredgige 1/0/2
# Create ERPS instance 1.
[DeviceA-erps-ring1] instance 1
# Configure the node role.
[DeviceA-erps-ring1-inst1] node-role owner rpl port0
# Configure the control VLAN.
control-vlan 100 on [DeviceA-erps-ring1-inst1].
# Configure the protected VLANs.
[DeviceA-erps-ring1-inst1] protected-vlan reference-instance 1
# Enable ERPS for instance 1.
[DeviceA-erps-ring1-inst1] instance enable
[DeviceA-erps-ring1-inst1] quit
# Create ERPS instance 2.
[DeviceA-erps-ring1] instance 2
[DeviceA-erps-ring1-inst2] control-vlan 110
[DeviceA-erps-ring1-inst2] protected-vlan reference-instance 2
# Enable ERPS for instance 2.
[DeviceA-erps-ring1-inst2] instance enable
[DeviceA-erps-ring1-inst2] quit
[DeviceA-erps-ring1] quit
# Enable ERPS.
[DeviceA] erps enable
# Configure HundredGigE 1/0/1 to operate in active Ethernet OAM mode, and enable Ethernet OAM for it. (By default, An Ethernet OAM-enabled Ethernet interface operates in active Ethernet OAM mode.) Set the errored frame event detection window to 20000 milliseconds, and set the errored frame event triggering threshold to 10.
[DeviceA-HundredGigE1/0/1] oam mode active
[DeviceA-HundredGigE1/0/1] oam enable
[DeviceA-HundredGigE1/0/1] oam errored-frame window 200
[DeviceA-HundredGigE1/0/1] oam errored-frame threshold 10
# Configure HundredGigE 1/0/2 to operate in passive Ethernet OAM mode, and enable Ethernet OAM for it.
[DeviceA-HundredGigE1/0/2] oam mode passive
[DeviceA-HundredGigE1/0/2] oam enable
Configuring Device B
[DeviceB] vlan 1 to 60
[DeviceB] stp region-configuration
[DeviceB-mst-region] instance 1 vlan 1 to 30
[DeviceB-mst-region] instance 2 vlan 31 to 60
[DeviceB-mst-region] active region-configuration
[DeviceB-mst-region] quit
# Set the link state change suppression interval to 0 seconds on HundredGigE 1/0/1 and HundredGigE1/0/2, respectively. Disable the spanning tree feature on the interface and configure the interface as a trunk port and assign it to VLANs 1 to 60.
[DeviceB] interface hundredgige 1/0/1
[DeviceB-HundredGigE1/0/1] link-delay up 0
[DeviceB-HundredGigE1/0/1] link-delay down 0
[DeviceB-HundredGigE1/0/1] undo stp enable
[DeviceB-HundredGigE1/0/1] port link-type trunk
[DeviceB-HundredGigE1/0/1] port trunk permit vlan 1 to 60
[DeviceB-HundredGigE1/0/1] quit
[DeviceB] interface hundredgige 1/0/2
[DeviceB-HundredGigE1/0/2] link-delay up 0
[DeviceB-HundredGigE1/0/2] link-delay down 0
[DeviceB-HundredGigE1/0/2] undo stp enable
[DeviceB-HundredGigE1/0/2] port link-type trunk
[DeviceB-HundredGigE1/0/2] port trunk permit vlan 1 to 60
[DeviceB-HundredGigE1/0/2] quit
[DeviceB] erps ring 1
[DeviceB-erps-ring1] port0 interface hundredgige 1/0/1
[DeviceB-erps-ring1] port1 interface hundredgige 1/0/2
[DeviceB-erps-ring1] instance 1
[DeviceB-erps-ring1-inst1] node-role neighbor rpl port0
[DeviceB-erps-ring1-inst1] control-vlan 100
[DeviceB-erps-ring1-inst1] protected-vlan reference-instance 1
[DeviceB-erps-ring1-inst1] instance enable
[DeviceB-erps-ring1-inst1] quit
[DeviceB-erps-ring1] instance 2
[DeviceB-erps-ring1-inst2] control-vlan 110
[DeviceB-erps-ring1-inst2] protected-vlan reference-instance 2
[DeviceB-erps-ring1-inst2] instance enable
[DeviceB-erps-ring1-inst2] quit
[DeviceB-erps-ring1] quit
# Enable ERPS.
[DeviceB] erps enable
# Configure HundredGigE 1/0/2 to operate in active Ethernet OAM mode, and enable Ethernet OAM for it. (By default, An Ethernet OAM-enabled Ethernet interface operates in active Ethernet OAM mode.) Set the errored frame event detection window to 20000 milliseconds, and set the errored frame event triggering threshold to 10.
[DeviceB-HundredGigE1/0/2] oam mode active
[DeviceB-HundredGigE1/0/2] oam enable
[DeviceB-HundredGigE1/0/2] oam errored-frame window 200
[DeviceB-HundredGigE1/0/2] oam errored-frame threshold 10
# Configure HundredGigE 1/0/1 to operate in passive Ethernet OAM mode, and enable Ethernet OAM for it.
[DeviceB-HundredGigE1/0/1] oam mode passive
[DeviceB-HundredGigE1/0/1] oam enable
Configuring Device C
<DeviceC> system-view
[DeviceC] vlan 1 to 60
[DeviceC-mst-region] instance 1 vlan 1 to 30
[DeviceC-mst-region] instance 2 vlan 31 to 60
[DeviceC-mst-region] quit
[DeviceC] interface hundredgige 1/0/1
[DeviceC-HundredGigE1/0/1] link-delay up 0
[DeviceC-HundredGigE1/0/1] link-delay down 0
[DeviceC-HundredGigE1/0/1] undo stp enable
[DeviceC-HundredGigE1/0/1] port link-type trunk
[DeviceC-HundredGigE1/0/1] port trunk permit vlan 1 to 60
[DeviceC-HundredGigE1/0/1] quit
[DeviceC] interface hundredgige 1/0/2
[DeviceC-HundredGigE1/0/2] link-delay up 0
[DeviceC-HundredGigE1/0/2] link-delay down 0
[DeviceC-HundredGigE1/0/2] undo stp enable
[DeviceC-HundredGigE1/0/2] port link-type trunk
[DeviceC-HundredGigE1/0/2] port trunk permit vlan 1 to 60
[DeviceC-HundredGigE1/0/2] quit
[DeviceC] erps ring 1
[DeviceC-erps-ring1] port0 interface hundredgige 1/0/1
[DeviceC-erps-ring1] port1 interface hundredgige 1/0/2
[DeviceC-erps-ring1] instance 1
[DeviceC-erps-ring1-inst1] control-vlan 100
[DeviceC-erps-ring1-inst1] protected-vlan reference-instance 1
[DeviceC-erps-ring1-inst1] instance enable
[DeviceC-erps-ring1-inst1] quit
[DeviceC-erps-ring1] instance 2
[DeviceC-erps-ring1-inst2] node-role owner rpl port0
[DeviceC-erps-ring1-inst2] control-vlan 110
[DeviceC-erps-ring1-inst2] protected-vlan reference-instance 2
[DeviceC-erps-ring1-inst2] instance enable
[DeviceC-erps-ring1-inst2] quit
[DeviceC-erps-ring1] quit
# Enable ERPS.
[DeviceC] erps enable
[DeviceC-HundredGigE1/0/1] oam mode active
[DeviceC-HundredGigE1/0/1] oam enable
[DeviceC-HundredGigE1/0/1] oam errored-frame window 200
[DeviceC-HundredGigE1/0/1] oam errored-frame threshold 10
[DeviceC-HundredGigE1/0/2] oam mode passive
[DeviceC-HundredGigE1/0/2] oam enable
Configuring Device D
<DeviceD> system-view
[DeviceD] vlan 1 to 60
[DeviceD-mst-region] instance 1 vlan 1 to 30
[DeviceD-mst-region] instance 2 vlan 31 to 60
[DeviceD-mst-region] quit
[DeviceD] interface hundredgige 1/0/1
[DeviceD-HundredGigE1/0/1] link-delay up 0
[DeviceD-HundredGigE1/0/1] link-delay down 0
[DeviceD-HundredGigE1/0/1] undo stp enable
[DeviceD-HundredGigE1/0/1] port link-type trunk
[DeviceD-HundredGigE1/0/1] port trunk permit vlan 1 to 60
[DeviceD-HundredGigE1/0/1] quit
[DeviceD] interface hundredgige 1/0/2
[DeviceD-HundredGigE1/0/2] link-delay up 0
[DeviceD-HundredGigE1/0/2] link-delay down 0
[DeviceD-HundredGigE1/0/2] undo stp enable
[DeviceD-HundredGigE1/0/2] port link-type trunk
[DeviceD-HundredGigE1/0/2] port trunk permit vlan 1 to 60
[DeviceD-HundredGigE1/0/2] quit
[DeviceD] erps ring 1
[DeviceD-erps-ring1] port0 interface hundredgige 1/0/1
[DeviceD-erps-ring1] port1 interface hundredgige 1/0/2
[DeviceD-erps-ring1] instance 1
[DeviceD-erps-ring1-inst1] control-vlan 100
[DeviceD-erps-ring1-inst1] protected-vlan reference-instance 1
[DeviceD-erps-ring1-inst1] instance enable
[DeviceD-erps-ring1-inst1] quit
# Create ERPS for instance 2.
[DeviceD-erps-ring1] instance 2
[DeviceD-erps-ring1-inst2] node-role neighbor rpl port0
[DeviceD-erps-ring1-inst2] control-vlan 110
[DeviceD-erps-ring1-inst2] protected-vlan reference-instance 2
[DeviceD-erps-ring1-inst2] instance enable
[DeviceD-erps-ring1-inst2] quit
[DeviceD-erps-ring1] quit
# Enable ERPS.
[DeviceD] erps enable
[DeviceD-HundredGigE1/0/2] oam mode active
[DeviceD-HundredGigE1/0/2] oam enable
[DeviceD-HundredGigE1/0/2] oam errored-frame window 200
[DeviceD-HundredGigE1/0/2] oam errored-frame threshold 10
[DeviceD-HundredGigE1/0/1] oam mode passive
[DeviceD-HundredGigE1/0/1] oam enable
# Display information about ERPS instance 1 for Device A.
[Device A] display erps detail ring 1
 Ring ID               : 1
 Port0                 : HundredGigE1/0/1
 Port1                 : HundredGigE1/0/2
 Subring               : No
 Default MAC           : No
 Instance ID           : 1
 Node role             : Owner
 Node state            : Idle
 Connect(ring/instance): -
 Control VLAN          : 100
 Protected VLAN        : Reference-instance 1
 Guard timer           : 500 ms
 Hold-off timer        : 0 ms
 WTR timer             : 5 min
 Revertive operation   : Revertive
 Enable status         : Yes, Active status : Yes
 R-APS level           : 7
 Port                  PortRole                PortStatus
 Port0                 RPL                     Block
 Port1                 Non-RPL                 Up
 Instance ID           : 2
 Node role             : Normal
 Node state            : Idle
 Control VLAN          : 100
 Protected VLAN        : Reference-instance 2
 WTR timer             : 5 min
 R-APS level           : 7
 Port0                 Non-RPL                 Up
 Port1                 Non-RPL                 Up
In instance 1:
·     Device A is the owner node.
·     The ERPS ring is in idle state.
·     The RPL port is blocked.
·     The non-RPL port is unblocked.
In instance 2:
·     Device A is a normal node.
# Display global Ethernet OAM configuration information and Ethernet OAM configuration information on interfaces that have not used the default configuration for Device A.
[DeviceA] display oam configuration
---------------- [Global] ----------------
 OAM timers
   Hello timer        : 1000 milliseconds
   Keepalive timer    : 5000 milliseconds
 Link monitoring
   Errored symbol period
     Window           : 100 x 1000000 symbols
     Threshold        : 1 error symbols
   Errored frame
     Window           : 10 x 100 milliseconds
     Threshold        : 1 error frames
   Errored frame period
     Window           : 1000 x 10000 frames
   Errored frame seconds
     Window           : 600 x 100 milliseconds
     Threshold        : 1 error seconds
----------- [HundredGigE1/0/1] -----------
 OAM timers
 Link monitoring
   Errored frame
     Window           : 200 x 100 milliseconds
     Threshold        : 10 error frames
# Display the statistics about Ethernet OAM critical link events for Device A.
[DeviceA] display oam critical-event
 Local link status   : UP
 Event statistics
   Link fault        : Not occurred
   Dying gasp        : Not occurred
   Critical event    : Not occurred
The command output shows that the link between Device A and Device B is normal and no critical link event has occurred on the link.
# Display Ethernet OAM link event statistics of the local end of Device A.
[DeviceA] display oam link-event local
 Link status: UP
 OAM local errored frame event
   Event time stamp        : 5789 x 100 milliseconds
   Errored frame window    : 200 x 100 milliseconds
   Errored frame threshold : 10 error frames
   Errored frame           : 13 error frames
   Error running total     : 350 error frames
   Event running total     : 17 events
·     350 errors has occurred after Ethernet OAM is enabled on Device A.
·     17 errors were caused by error frames.
·     The link is unstable.
If the link performance is detected unstable, contact H3C Technical Support.
Configuration files
·     Device A
vlan 1 to 60
 link-delay up 0
 link-delay down 0
 undo stp enable
 oam mode active
 oam enable
 link-delay up 0
 link-delay down 0
 undo stp enable
 oam mode passive
 oam enable
erps ring 1
 instance 1
  control-vlan 100
  instance enable
 instance 2
  control-vlan 110
  instance enable
erps enable
·     Device B
vlan 1 to 60
 link-delay up 0
 link-delay down 0
 undo stp enable
 oam mode passive
 oam enable
 link-delay up 0
 link-delay down 0
 undo stp enable
 oam mode active
 oam enable
erps ring 1
 instance 1
  control-vlan 100
  instance enable
 instance 2
  control-vlan 110
  instance enable
erps enable
·     Device C
vlan 1 to 60
 link-delay up 0
 link-delay down 0
 undo stp enable
 oam mode active
 oam enable
 link-delay up 0
 link-delay down 0
 undo stp enable
 oam mode passive
 oam enable
erps ring 1
 instance 1
  control-vlan 100
  instance enable
 instance 2
  control-vlan 110
  instance enable
erps enable
·     Device D
vlan 1 to 60
 link-delay up 0
 link-delay down 0
 undo stp enable
 oam mode passive
 oam enable
 link-delay up 0
 link-delay down 0
 undo stp enable
 oam mode passive
 oam enable
 oam mode active
 oam enable
erps ring 1
 instance 1
  control-vlan 100
  instance enable
 instance 2
  control-vlan 110
  instance enable
erps enable
Related documentation
·     High Availability Configuration Guide in H3C S12500R Switch Router Series Configuration Guides-R52xx
·     High Availability Command Reference in H3C S12500R Switch Router Series Command References-R52xx
·     High Availability Configuration Guide in H3C S12500R-48Y8C&S12500R-48C6D Switch Router Configuration Guides-R52xx
·     High Availability Command Reference in H3C S12500R-48Y8C&S12500R-48C6D Switch Router Command References-R52xx
