H3C S12500R Ethernet Switch Router Series Config Examples-6W101
HomeSupportSwitchesS12500R SeriesConfigure & DeployConfiguration ExamplesH3C S12500R Ethernet Switch Router Series Config Examples-6W101
Table of Contents
Related Documents
62-MPLS SR Configuration Examples
62-MPLS SR Configuration Examples 110.54 KB
H3C S12500R Switch Router Series
Introduction
This document provides MPLS SR configuration examples.
Segment Routing (SR) is a source routing technology. The source node selects a path for the packets, and then encodes the path in the packet header as an ordered list of segments. Each segment is identified by the segment identifier (SID). The SR nodes along the path forward the packets based on the SIDs in the packets. Only the source node needs to maintain the path status.
SR can operate with MPLS. In an MPLS network, SR uses MPLS labels as SIDs to forward packets on an LSP.
This document assumes that you have basic knowledge of MPLS SR.
Example: Configuring MPLS SR over LDP
As shown in Figure 1, configure the devices so the two SR networks can communicate across the LDP network.
Figure 1 Network diagram
Device
IP address
Device
IP address
Device A
Loop1
1.1.1.1/32
Device B
Loop1
2.2.2.2/32
HGE1/0/1
10.0.0.1/24
HGE1/0/1
10.0.0.2/24
Device C
Loop1
3.3.3.3/32
HGE1/0/2
11.0.0.1/24
HGE1/0/1
12.0.0.1/24
Device D
Loop1
4.4.4.4/32
HGE1/0/2
11.0.0.2/24
HGE1/0/2
12.0.0.2/24
Device E
Loop1
5.5.5.5/32
HGE1/0/1
13.0.0.1/24
HGE1/0/1
13.0.0.2/24
Analysis
To enable the two SR networks to communicate across the LDP network, you must perform the following tasks:
·     Configure Device A, Device B, Device C, Device D, and Device E to run IS-IS.
·     Configure Device B, Device C, and Device D to run LDP.
·     Configure Device A, Device B, Device D, and Device E to run MPLS SR.
Software versions used
This configuration example was created and verified on Release 3606.
Procedures
Configuring Device A
# Configure IP addresses and masks for interfaces. (Details not shown.)
#  Configure IS-IS to achieve network level connectivity and set the IS-IS cost style to wide.
[DeviceA] isis 1
[DeviceA-isis-1] network-entity 00.0000.0000.0001.00
[DeviceA-isis-1] cost-style wide
[DeviceA-isis-1] quit
[DeviceA] interface hundredgige 1/0/1
[DeviceA-HundredGigE1/0/1] isis enable 1
[DeviceA-HundredGigE1/0/1] quit
[DeviceA] interface loopback 1
[DeviceA-LoopBack1] isis enable 1
[DeviceA-LoopBack1] quit
# Set the LSR ID.
[DeviceA] mpls lsr-id 1.1.1.1
# Enable MPLS SR.
[DeviceA] isis 1
[DeviceA-isis-1] address-family ipv4
[DeviceA-isis-1-ipv4] segment-routing mpls
[DeviceA-isis-1-ipv4] quit
# Configure the SRGB.
[DeviceA-isis-1] segment-routing global-block 16000 16999
# Configure IS-IS prefix SID.
[DeviceA-LoopBack1] isis prefix-sid index 10
Configuring Device B
[DeviceB] isis 1
[DeviceB-isis-1] network-entity 00.0000.0000.0002.00
[DeviceB-isis-1] cost-style wide
[DeviceB-isis-1] quit
[DeviceB] interface hundredgige 1/0/1
[DeviceB-HundredGigE1/0/1] isis enable 1
[DeviceB-HundredGigE1/0/1] quit
[DeviceB] interface hundredgige 1/0/2
[DeviceB-HundredGigE1/0/2] isis enable 1
[DeviceB-HundredGigE1/0/2] quit
[DeviceB] interface loopback 1
[DeviceB-LoopBack1] isis enable 1
[DeviceB-LoopBack1] quit
# Set the LSR ID.
[DeviceB] mpls lsr-id 2.2.2.2
# Configure LDP.
[DeviceB] mpls ldp
[DeviceB-ldp] quit
[DeviceB-HundredGigE1/0/2] mpls enable
[DeviceB-HundredGigE1/0/2] mpls ldp enable
# Enable MPLS SR.
[DeviceB] isis 1
[DeviceB-isis-1] address-family ipv4
[DeviceB-isis-1-ipv4] segment-routing mpls
[DeviceB-isis-1-ipv4] quit
[DeviceB-isis-1] segment-routing global-block 17000 17999
[DeviceB-LoopBack1] isis prefix-sid index 20
Configuring Device C
<DeviceC> system-view
[DeviceC] isis 1
[DeviceC-isis-1] network-entity 00.0000.0000.0003.00
[DeviceC-isis-1] cost-style wide
[DeviceC-isis-1] quit
[DeviceC] interface hundredgige 1/0/1
[DeviceC-HundredGigE1/0/1] isis enable 1
[DeviceC-HundredGigE1/0/1] quit
[DeviceC] interface hundredgige 1/0/2
[DeviceC-HundredGigE1/0/2] isis enable 1
[DeviceC-HundredGigE1/0/2] quit
[DeviceC] interface loopback 1
[DeviceC-LoopBack1] isis enable 1
[DeviceC-LoopBack1] quit
# Set the LSR ID.
[DeviceC] mpls lsr-id 3.3.3.3
# Configure LDP.
[DeviceC] mpls ldp
[DeviceC-ldp] quit
[DeviceC-HundredGigE1/0/1] mpls enable
[DeviceC-HundredGigE1/0/1] mpls ldp enable
[DeviceC-HundredGigE1/0/2] mpls enable
[DeviceC-HundredGigE1/0/2] mpls ldp enable
Configuring Device D
<DeviceD> system-view
[DeviceD] isis 1
[DeviceD-isis-1] network-entity 00.0000.0000.0004.00
[DeviceD-isis-1] cost-style wide
[DeviceD-isis-1] quit
[DeviceD] interface hundredgige 1/0/1
[DeviceD-HundredGigE1/0/1] isis enable 1
[DeviceD-HundredGigE1/0/1] quit
[DeviceD] interface hundredgige 1/0/2
[DeviceD-HundredGigE1/0/2] isis enable 1
[DeviceD-HundredGigE1/0/2] quit
[DeviceD] interface loopback 1
[DeviceD-LoopBack1] isis enable 1
[DeviceD-LoopBack1] quit
# Set the LSR ID.
[DeviceD] mpls lsr-id 4.4.4.4
# Configure LDP.
[DeviceD] mpls ldp
[DeviceD-ldp] quit
[DeviceD-HundredGigE1/0/1] mpls enable
[DeviceD-HundredGigE1/0/1] mpls ldp enable
# Enable MPLS SR.
[DeviceD] isis 1
[DeviceD-isis-1] address-family ipv4
[DeviceD-isis-1-ipv4] segment-routing mpls
[DeviceD-isis-1-ipv4] quit
[DeviceD-isis-1] segment-routing global-block 18000 18999
[DeviceD-LoopBack1] isis prefix-sid index 40
Configuring Device E
<DeviceE> system-view
[DeviceE] isis 1
[DeviceE-isis-1] network-entity 00.0000.0000.0005.00
[DeviceE-isis-1] cost-style wide
[DeviceE-isis-1] quit
[DeviceE] interface hundredgige 1/0/1
[DeviceE-HundredGigE1/0/1] isis enable 1
[DeviceE-HundredGigE1/0/1] quit
[DeviceE] interface loopback 1
[DeviceE-LoopBack1] isis enable 1
[DeviceE-LoopBack1] quit
# Set the LSR ID.
[DeviceE] mpls lsr-id 5.5.5.5
# Enable MPLS SR.
[DeviceE] isis 1
[DeviceE-isis-1] address-family ipv4
[DeviceE-isis-1-ipv4] segment-routing mpls
[DeviceE-isis-1-ipv4] quit
[DeviceE-isis-1] segment-routing global-block 19000 19999
[DeviceE-LoopBack1] isis prefix-sid index 50
# Display LDP LSP information on Device B.
[DeviceB] display mpls ldp lsp
Status Flags: * - stale, L - liberal, B - backup, N/A - unavailable
FECs: 5            Ingress: 3          Transit: 3      Egress: 2
FEC                In/Out Label        Nexthop         OutInterface/LSINDEX
1.1.1.1/32         24116/-
                   -/24117(L)
2.2.2.2/32         3/-
                   -/24120(L)
3.3.3.3/32         -/3                 11.0.0.2        HGE1/0/2
                   24121/3             11.0.0.2        HGE1/0/2
4.4.4.4/32         -/24119             11.0.0.2        HGE1/0/2
                   24118/24119         11.0.0.2        HGE1/0/2
5.5.5.5/32         -/24118             11.0.0.2        HGE1/0/2
                   24117/24118         11.0.0.2        HGE1/0/2
# Display IS-IS SRLSP information on Device B.
[DeviceB] display mpls lsp protocol isis
FEC                         Proto    In/Out Label    Interface/Out NHLFE
1.1.1.1/32                  ISIS     17010/3         HGE1/0/1
1.1.1.1/32                  ISIS     -/3             HGE1/0/1
2.2.2.2/32                  ISIS     17020/-         -
4.4.4.4/32                  ISIS     17040/24119     HGE1/0/2
4.4.4.4/32                  ISIS     -/24119         HGE1/0/2
5.5.5.5/32                  ISIS     17050/24118     HGE1/0/2
5.5.5.5/32                  ISIS     -/24118         HGE1/0/2
The output shows that the IS-IS SRLSP entries for Device D and Device E are using LDP labels.
Configuration files
·     Device A:
isis 1
 cost-style wide
 address-family ipv4 unicast
 mpls lsr-id 1.1.1.1
interface LoopBack1
 ip address 1.1.1.1 255.255.255.255
 isis enable 1
interface HundredGigE1/0/1
 port link-mode route
 ip address 10.0.0.1 255.255.255.0
 isis enable 1
·     Device B:
isis 1
 cost-style wide
 mpls lsr-id 2.2.2.2
mpls ldp
interface LoopBack1
 ip address 2.2.2.2 255.255.255.255
 isis enable 1
 ip address 10.0.0.2 255.255.255.0
 isis enable 1
interface HundredGigE1/0/2
 ip address 11.0.0.1 255.255.255.0
 isis enable 1
 mpls enable
 mpls ldp enable
·     Device C:
isis 1
 cost-style wide
 mpls lsr-id 3.3.3.3
mpls ldp
interface LoopBack1
 ip address 3.3.3.3 255.255.255.255
 isis enable 1
 ip address 12.0.0.1 255.255.255.0
 isis enable 1
 mpls enable
 mpls ldp enable
 ip address 11.0.0.2 255.255.255.0
 isis enable 1
 mpls enable
 mpls ldp enable
·     Device D:
isis 1
 cost-style wide
 mpls lsr-id 4.4.4.4
mpls ldp
interface LoopBack1
 ip address 4.4.4.4 255.255.255.255
 isis enable 1
 ip address 13.0.0.1 255.255.255.0
 isis enable 1
 ip address 12.0.0.2 255.255.255.0
 isis enable 1
 mpls enable
 mpls ldp enable
·     Device E:
isis 1
 cost-style wide
 mpls lsr-id 5.5.5.5
interface LoopBack1
 ip address 5.5.5.5 255.255.255.255
 isis enable 1
 ip address 13.0.0.2 255.255.255.0
 isis enable 1
Related documentation
·     H3C S12500R Switch Router Series Segment Routing Command Reference-R3606
·     H3C S12500R Switch Router Series Segment Routing Configuration Guide-R3606
