H3C S12500R Ethernet Switch Router Series Config Examples-6W101
HomeSupportSwitchesS12500R SeriesConfigure & DeployConfiguration ExamplesH3C S12500R Ethernet Switch Router Series Config Examples-6W101
Table of Contents
Related Documents
63-Puppet Configuration Examples
63-Puppet Configuration Examples 83.61 KB
H3C S12500R Switch Router Series
Introduction
This document provides Puppet configuration examples.
Puppet is an open-source configuration management tool. It provides the Puppet language. You can use the Puppet language to create configuration manifests and save them to a server. You can then use the server for centralized configuration enforcement and management.
This document assumes that you have basic knowledge of Puppet.
Example: Configuring Puppet
As shown in Figure 1, Puppet agents Device A and Device B are connected to the Puppet master. Use Puppet to create VLAN 100 on each Puppet agent.
Figure 1 Network diagram
Software versions used
This configuration example was created and verified on Release 3606.
By default, interfaces on the device are disabled (in ADM or Administratively Down state). To have an interface operate, you must use the undo shutdown command to enable that interface.
Procedures
Configuring the Puppet master
1.     Assign an IP address to the Puppet master. (Details not shown.)
2.     Install Puppet on the Puppet master.
$ sudo apt-get install puppetmaster
3.     Verify that Puppet configuration file puppet.conf is created in directory /etc/puppet.
If the file does not exist, execute the following command to create the file:
$ sudo puppet master –genconfig > puppet.conf
4.     Add files provided by H3C:
# Create directory costom/lib/puppet in directory /etc/puppet/modules. Then, add the type and provider library files to the newly created directory.
$ sudo mkdir –p /etc/puppet/modules/costom/lib/puppet
# Create directory nodes in directory /etc/puppet/manifests.
$ sudo mkdir –p /etc/puppet/manifests/nodes
# Copy H3C file puppet.master.com.pp to directory /etc/puppet/manifests/nodes/. The following is the file content:
node 'puppet.master.com' {
 include custom
5.     Configure file site.pp:
# Go to directory /etc/puppet/manifests/ and create file site.pp in the directory.
$ cd ..
$ sudo touch site.pp
# Edit file site.pp.
node '16.1.136.133'{
  netdev_device{'device':
    ensure => undo_shutdown,
    username => 'test',
    password => 'test',
    ipaddr => '16.1.136.133',
    include custom
node '16.1.136.134'{
    username => 'test',
    password => 'test',
    ipaddr => '16.1.136.134',
    include custom
6.     Configure file init.pp:
# Create directory modules/custom/manifests in directory /etc/puppet/ to store configuration manifests.
$ sudo mkdir -p /etc/puppet/modules/custom/manifests
# Create configuration manifest init.pp in directory /etc/puppet/modules/custom/manifests.
$ sudo touch init.pp
# Edit file init.pp.
class custom{
  netdev_vlan{'vlan100':
    id => 100,
    require => Netdev_device['device'],
Configuring Puppet agent Device A
1.     Assign an IP address to Device A. (Details not shown.)
[DeviceA] interface hundredgige 1/0/1
[DeviceA-HundredGigE1/0/1] ip address 16.1.136.133 255.255.0.0
[DeviceA-HundredGigE1/0/1] quit
2.     Configure the device as the NETCONF over SSH server:
# Generate RSA key pairs. Leave the key pair to use the default key pair name.
[DeviceA] public-key local create rsa
# Enable NETCONF over SSH.
[DeviceA] netconf ssh server enable
# Enable scheme authentication for NETCONF over SSH users.
[DeviceA] line vty 0 63
[DeviceA-line-vty0-63] authentication-mode scheme
[DeviceA-line-vty0-63] user-role network-admin
[DeviceA-line-vty0-63] quit
# Create device management user test. Set the password to test, and assign the SSH service and network-admin user role to the user.
[DeviceA] local-user test class manage
[DeviceA-luser-manage-test] password simple test
[DeviceA-luser-manage-test] service-type ssh
[DeviceA-luser-manage-test] authorization-attribute user-role network-admin
[DeviceA-luser-manage-test] quit
3.     Configure the device as an NTP client to synchronize its system time to the system time on the Puppet master:
# Enable the NTP service
[DeviceA] ntp-service enable
# Configure the device to use NTP to obtain the UTC time.
[DeviceA] clock protocol ntp
# Configure the device to operate in NTP broadcast client mode and use VLAN-interface 2 to receive NTP broadcast packets.
[DeviceA-HundredGigE1/0/1] ntp-service broadcast-client
4.     Start Puppet on the device.
[DeviceA] third-part-process start name puppet arg agent --certname=16.1.136.133 --server=16.1.147.150
The device will act as a Puppet client to request a certificate from the Puppet master.
Configuring Puppet agent Device B
The steps are similar to the steps for Device A
Using the Puppet master to issue certificates to the Puppet clients
# Use the puppet cert list command to display devices that require a certificate. (Details not shown.)
# Sign a certificate for Device A.
$ sudo puppet cert sign 16.1.136.133
After Device A obtains a certificate, it obtains a configuration manifest from the Puppet master and run the manifest.
# Sign a certificate for Device B. (Details not shown.)
# Display device configuration information. VLAN 100 is created. (Details not shown.)
Configuration files
·     Puppet master:
The type and provider library files and the puppet.master.com.pp file are provided by H3C.
·     Device A
 clock protocol ntp
interface HundredGigE1/0/1
 ntp-service enable
line vty 0 63
 user-role network-operator
 idle-timeout 0 0
 password hash $h$6$x0kIJnaHZkFFa3Ga$H4yMQnG96xjHiTID+6UPyJrTLXru6RJaGqrCKpxmo2O
KUVWujeoTcDEovLt6LzKIUyN7J3i5Tq2rOQPdj2Nrww==
 service-type ssh
Related documentation
·     H3C S12500R Switch Router Series Network Management and Monitoring Command Reference-R3606
·     H3C S12500R Switch Router Series Network Management and Monitoring Configuration Guide-R3606
