H3C S12500R Ethernet Switch Router Series Config Examples-6W101
HomeSupportSwitchesS12500R SeriesConfigure & DeployConfiguration ExamplesH3C S12500R Ethernet Switch Router Series Config Examples-6W101
Table of Contents
Related Documents
34-IP Source Guard Configuration Examples
34-IP Source Guard Configuration Examples 215.29 KB
H3C S12500R Switch Router Series
Introduction
This document provides IP source guard (IPSG) configuration examples.
IPSG prevents spoofing attacks by using IPSG bindings to filter incoming packets. IPSG bindings include static bindings that are configured manually and dynamic bindings that are generated based on information from DHCP-related modules. IPSG forwards only the packets that match IPSG bindings.
This document assumes that you have basic knowledge of IPSG.
Example: Configuring static IPv4SG
As shown in Figure 1, Host A, Host B, and the file server use static IPv4 addresses.
Enable static IPv4SG and configure static IPSG bindings on Device A and Device B to meet the following requirements:
·     The interface HundredGigE 1/0/1 of Device A allows IP packets from Host A to pass.
·     All interfaces of Device A allow IP packets from Host B to pass.
·     The interface HundredGigE 1/0/1 of Device B allows only IP packets from Host A and Host B to pass.
·     The interface HundredGigE 1/0/2 of Device B allows only IP packets from the file server to pass.
Figure 1 Network diagram
Analysis
To meet the network requirements, you must perform the following tasks:
·     To allow IP packets from Host A to pass through HundredGigE 1/0/1 on Device A, configure a static IPSG binding for Host A on the interface.
·     To allow IP packets from Host B to pass through all interfaces on Device A, configure a global static IPSG binding for Host B.
·     To allow IP packets from both hosts to pass through HundredGigE 1/0/1 on Device B, configure static IPSG bindings for the hosts on the interface.
·     To allow only IP packets from the file server to pass through HundredGigE 1/0/2 on Device B, configure a static IPSG binding for the file server on the interface.
Software versions used
This configuration example was created and verified on Release 3606.
IPSG does not use the VLAN information (if specified) in static IPSG bindings to filter packets.
By default, interfaces on the device are disabled (in ADM or Administratively Down state). To have an interface operate, you must use the undo shutdown command to enable that interface.
Procedures
Configuring Device A
# Configure HundredGigE 1/0/1 and HundredGigE 1/0/2 to operate in Layer 2 mode.
[DeviceA] interface hundredgige 1/0/1
[DeviceA-HundredGigE1/0/1] port link-mode bridge
[DeviceA-HundredGigE1/0/1] quit
[DeviceA] interface hundredgige 1/0/2
[DeviceA-HundredGigE1/0/2] port link-mode bridge
[DeviceA-HundredGigE1/0/2] quit
# Create VLAN 10, and assign HundredGigE 1/0/1 through HundredGigE 1/0/2 to VLAN 10.
[DeviceA] vlan 10
[DeviceA-vlan10] port hundredgige 1/0/1 to hundredgige 1/0/2
[DeviceA-vlan10] quit
# Create VLAN-interface 10, and assign an IP address to VLAN-interface 10.
[DeviceA-Vlan-interface10] ip address 192.168.0.10 255.255.255.0
# Enable IPv4SG on HundredGigE 1/0/1 and HundredGigE 1/0/2.
[DeviceA-HundredGigE1/0/2] ip verify source ip-address mac-address
[DeviceA-HundredGigE1/0/1] ip verify source ip-address mac-address
# Configure a static IPSG binding for Host A on HundredGigE 1/0/1.
[DeviceA-HundredGigE1/0/1] ip source binding ip-address 192.168.0.1 mac-address 0001-0203-0401
# Configure a static IPSG binding for Host B.
[DeviceA] ip source binding ip-address 192.168.0.2 mac-address 0001-0203-0402
Configuring Device B
[DeviceB] interface hundredgige 1/0/1
[DeviceB-HundredGigE1/0/1] port link-mode bridge
[DeviceB-HundredGigE1/0/1] quit
[DeviceB] interface hundredgige 1/0/2
[DeviceB-HundredGigE1/0/2] port link-mode bridge
[DeviceB-HundredGigE1/0/2] quit
# Create VLAN 10, and assign HundredGigE 1/0/1 to VLAN 10.
[DeviceB] vlan 10
[DeviceB-vlan10] port hundredgige 1/0/1
[DeviceB-vlan10] quit
[DeviceB] interface vlan-interface 10
[DeviceB-Vlan-interface10] ip address 192.168.0.100 255.255.255.0
[DeviceB-Vlan-interface10] quit
# Create VLAN 20, and assign HundredGigE 1/0/2 to VLAN 20.
[DeviceB] vlan 20
[DeviceB-vlan20] port hundredgige 1/0/2
[DeviceB-vlan20] quit
# Create VLAN-interface 20, and assign an IP address to VLAN-interface 20.
[DeviceB] interface vlan-interface 20
[DeviceB-Vlan-interface20] ip address 192.168.2.100 255.255.255.0
[DeviceB-Vlan-interface20] quit
# Enable IPv4SG on HundredGigE 1/0/1.
[DeviceB-HundredGigE1/0/1] ip verify source ip-address mac-address
# Configure static IPSG bindings for Host A and Host B on HundredGigE 1/0/1.
[DeviceB-HundredGigE1/0/1] ip source binding ip-address 192.168.0.1 mac-address 0001-0203-0401
[DeviceB-HundredGigE1/0/1] ip source binding ip-address 192.168.0.2 mac-address 0001-0203-0402
# Enable IPSG on HundredGigE 1/0/2.
[DeviceB-HundredGigE1/0/2] ip verify source ip-address mac-address
# Configure a static IPSG binding for the file server on HundredGigE 1/0/2.
[DeviceB-HundredGigE1/0/2] ip source binding ip-address 192.168.2.3 mac-address 0001-0203-0403
# Verify that Host A can ping the IP addresses of HundredGigE 1/0/1 on both Device A and Device B. (Details not shown.)
# Verify that Host B can ping the IP addresses of all interfaces of Device A and HundredGigE 1/0/1 of Device B. (Details not shown.)
# Verify that the file server can ping the IP address of VLAN-interface 20 of Device B. (Details not shown.)
# Verify that Device A has static IPSG bindings for Host A and Host B.
[DeviceA] display ip source binding static
Total entries found: 2
IP Address      MAC Address    Interface                VLAN Type
192.168.0.2     0001-0203-0402 N/A                      N/A  Static
192.168.0.1     0001-0203-0401 HGE1/0/1                 N/A  Static
# Verify that Device B has static IPSG bindings for Host A, Host B, and the file server.
[DeviceB] display ip source binding static
Total entries found: 3
192.168.0.2     0001-0203-0402 HGE1/0/1                 N/A  Static
192.168.2.3     0001-0203-0403 HGE1/0/2                 N/A  Static
# Verify that Host B can ping Device A when Host B is connected to Device A through HundredGigE 1/0/1. (Details not shown.)
# Verify that Host B cannot ping Device A when Host B is assigned an IP address different from 192.168.0.2. (Details not shown.)
# Verify that Host A cannot ping Device A when any of following conditions exist (details not shown):
·     Host A is connected to Device A through HundredGigE 1/0/2 or HundredGigE 1/0/3.
·     Host A is assigned an IP address different from 192.168.0.1.
Configuration files
·     Device A:
vlan 10
interface Vlan-interface10
interface HundredGigE1/0/1
 port access vlan 10
interface HundredGigE1/0/2
 port access vlan 10
·     Device B:
vlan 10
vlan 20
interface Vlan-interface20
 port access vlan 10
 port access vlan 20
Example: Configuring dynamic IPv4SG based on DHCP snooping
As shown in Figure 2, the DHCP clients obtain IP addresses from the DHCP server.
·     Enable DHCP snooping on the device to make sure the DHCP clients obtain IP addresses from the authorized DHCP server.
·     Enable dynamic IPv4SG on HundredGigE 1/0/1 to filter incoming packets by using the IPSG bindings that are generated based on DHCP snooping entries. Only packets from the DHCP clients are allowed to pass.
Figure 2 Network diagram
Analysis
·     To enable the DHCP clients to obtain IP addresses from the DHCP server, configure HundredGigE 1/0/2 as the DHCP trusted port. By default, all ports are untrusted ports after DHCP snooping is enabled.
·     To generate DHCP snooping entries for the DHCP clients, enable recording of client information in DHCP snooping entries on HundredGigE 1/0/1. By default, recording of DHCP snooping entries is disabled.
Procedures
This example uses an S12500R switch router as the DHCP server.
Configuring the DHCP server
# Create VLAN-interface 1, and assign an IP address to VLAN-interface 1.
<DHCPserver> system-view
[DHCPserver] interface vlan-interface 1
[DHCPserver-Vlan-interface1] ip address 192.168.0.2 24
# Enable the DHCP server on VLAN-interface 1.
[DHCPserver-Vlan-interface1] dhcp select server
[DHCPserver-Vlan-interface1] quit
# Enable DHCP.
[DHCPserver] dhcp enable
# Create DHCP address pool 1.
[DHCPserver] dhcp server ip-pool 1
# Specify the assignable subnet as 192.168.0.0/24 and the address lease duration as 7 days.
[DHCPserver-dhcp-pool-1] network 192.168.0.0 24
[DHCPserver-dhcp-pool-1] expired day 7
[DHCPserver-dhcp-pool-1] quit
Configuring the device
# Enable DHCP snooping.
[Device] dhcp snooping enable
[Device] interface hundredgige 1/0/1
[Device-HundredGigE1/0/1] port link-mode bridge
[Device-HundredGigE1/0/1] quit
[Device] interface hundredgige 1/0/2
[Device-HundredGigE1/0/2] port link-mode bridge
# Configure HundredGigE 1/0/2 as a trusted port.
[Device-HundredGigE1/0/2] dhcp snooping trust
[Device-HundredGigE1/0/2] quit
# Enable IPv4SG on HundredGigE 1/0/1 and verify the source IP address and MAC address for dynamic IPv4SG.
[Device-HundredGigE1/0/1] ip verify source ip-address mac-address
# Enable recording of client information in DHCP snooping entries on HundredGigE 1/0/1.
[Device-HundredGigE1/0/1] dhcp snooping binding record
Configuring the DHCP clients
# Configure the DHCP clients to use DHCP for IP address acquisition. (Details not shown.)
# Verify that the device has generated dynamic IPSG bindings for the clients based on DHCP snooping entries.
[Device] display ip source binding dhcp-snooping
Total entries found: 4
192.168.0.1     0001-0203-0401 HGE1/0/1                 1    DHCP snooping
192.168.0.3     0001-0203-0403 HGE1/0/1                 1    DHCP snooping
192.168.0.4     0001-0203-0404 HGE1/0/1                 1    DHCP snooping
192.168.0.5     0001-0203-0405 HGE1/0/1                 1    DHCP snooping
# Verify that the DHCP server can be pinged from the clients. (Details not shown.)
# Verify that the DHCP server cannot be pinged from the clients when the clients are assigned IP addresses manually. (Details not shown.)
Configuration files
vlan 1
dhcp snooping trust
Example: Configuring dynamic IPv4SG based on DHCP relay agent
As shown in Figure 3, DHCP relay is enabled on the device. The DHCP clients obtain IP addresses from the DHCP server through the DHCP relay agent.
Enable dynamic IPv4SG on VLAN-interface 10 to filter incoming packets by using the dynamic IPSG bindings generated based on the DHCP relay entries.
Figure 3 Network diagram
Analysis
To generate DHCP relay entries for the DHCP clients, enable recording of relay entries on the delay agent. By default, the DHCP relay agent does not record client information in relay entries.
Procedures
[DHCPserver] interface vlan-interface 20
[DHCPserver-Vlan-interface20] ip address 10.10.0.2 24
# Enable the DHCP server on VLAN-interface 20.
[DHCPserver-Vlan-interface20] dhcp select server
[DHCPserver-Vlan-interface20] quit
# Enable DHCP.
# Configure a static route for the subnet where VLAN-interface 10 of the DHCP relay agent resides on the DHCP server.
[DHCPserver] ip route-static 192.168.0.0 24 10.10.0.1
[Device] vlan 10
[Device-vlan10] port hundredgige 1/0/1
[Device-vlan10] quit
# Assign an IP address to VLAN-interface 10.
[Device] interface vlan-interface 10
[Device-Vlan-interface10] ip address 192.168.0.1 255.255.255.0
[Device-Vlan-interface10] quit
[Device] vlan 20
[Device-vlan20] port hundredgige 1/0/2
[Device-vlan20] quit
# Assign an IP address to VLAN-interface 20.
[Device] interface vlan-interface 20
[Device-Vlan-interface20] ip address 10.10.0.1 255.255.255.0
[Device-Vlan-interface20] quit
# Enable DHCP.
[Device] dhcp enable
# Enable recording of relay entries on the delay agent.
[Device] dhcp relay client-information record
# Enable the DHCP relay agent on VLAN-interface 10.
[Device-Vlan-interface10] dhcp select relay
# Specify the IP address of the DHCP server on the relay agent.
[Device-Vlan-interface10] dhcp relay server-address 10.10.0.2
# Enable IPv4SG on VLAN-interface 10 and verify the source IP address and MAC address for dynamic IPSG.
[Device-Vlan-interface10] ip verify source ip-address mac-address
# Verify that the device has generated dynamic IPSG bindings for the clients based on DHCP relay entries.
<Device> display ip source binding dhcp-relay
192.168.0.2     0001-0203-0402 Vlan10                   10   DHCP relay
192.168.0.3     0001-0203-0403 Vlan10                   10   DHCP relay
192.168.0.4     0001-0203-0404 Vlan10                   10   DHCP relay
192.168.0.5     0001-0203-0405 Vlan10                   10   DHCP relay
Configuration files
 dhcp enable
vlan 10
vlan 20
 dhcp select relay
 port access vlan 10
 port access vlan 20
Example: Configuring static IPv6SG and dynamic IPv6SG
As shown in Figure 4, the file server uses static IPv6 address 2001::1. Host A and Host B obtain IP addresses from the DHCPv6 server.
Configure IPv6SG on the device to meet the following requirements:
·     The interface HundredGigE 1/0/1 allows only packets from the file server to pass.
·     The interface HundredGigE 1/0/2 allows only packets from Host A to pass.
·     The interface HundredGigE 1/0/3 allows only packets from Host B to pass.
Figure 4  Network diagram
Analysis
·     To enable Host A and Host B to obtain IP addresses from the DHCPv6 server, configure HundredGigE 1/0/4 as the DHCP trusted port. By default, all ports are untrusted ports after DHCPv6 snooping is enabled.
·     To allow only incoming packets from the file server on HundredGigE 1/0/1, configure a static IPSG binding for the file server.
·     To allow only packets from Host A to pass through HundredGigE 1/0/2 and only packets from Host B to pass through HundredGigE 1/0/3, perform the following tasks:
¡     Enable IPv6SG on HundredGigE 1/0/2 and HundredGigE 1/0/3.
¡     To generate DHCPv6 snooping entries for Host A and Host B, enable recording of client information in DHCPv6 snooping entries on HundredGigE 1/0/2 and HundredGigE 1/0/3. By default, recording of DHCP snooping entries is disabled.
IPv6SG does not use the VLAN information (if specified) in static IPSG bindings to filter packets.
Procedures
# Configure the DHCPv6 server and the DHCPv6 clients (Host A and Host B). (Details not shown.)
# Configure HundredGigE 1/0/1 through HundredGigE 1/0/4 to operate in Layer 2 mode.
[Device] interface hundredgige 1/0/3
[Device-HundredGigE1/0/3] port link-mode bridge
[Device-HundredGigE1/0/3] quit
[Device] interface hundredgige 1/0/4
[Device-HundredGigE1/0/4] port link-mode bridge
[Device-HundredGigE1/0/4] quit
# Enable IPv6SG on HundredGigE 1/0/1.
[Device-HundredGigE1/0/1] ipv6 verify source ip-address mac-address
# Configure a static IPSG binding for the file server on HundredGigE 1/0/1.
[Device-HundredGigE1/0/1] ipv6 source binding ip-address 2001::1 mac-address 0001-0203-0405
# Enable DHCPv6 snooping.
[Device] ipv6 dhcp snooping enable
# Configure HundredGigE 1/0/4 as a trusted port.
[Device-HundredGigE1/0/4] ipv6 dhcp snooping trust
# Enable IPv6SG on HundredGigE 1/0/2 and verify the source IPv6 address and MAC address for dynamic IPv6SG.
[Device-HundredGigE1/0/2] ipv6 verify source ip-address mac-address
# Enable recording of client information in DHCPv6 snooping entries on HundredGigE 1/0/2.
[Device-HundredGigE1/0/2] ipv6 dhcp snooping binding record
# Enable IPv6SG on HundredGigE 1/0/3 and verify the source IPv6 address and MAC address for dynamic IPv6SG.
[Device-HundredGigE1/0/3] ipv6 verify source ip-address mac-address
# Enable recording of client information in DHCPv6 snooping entries on HundredGigE 1/0/3.
[Device-HundredGigE1/0/3] ipv6 dhcp snooping binding record
# Verify that the file server can ping the DHCPv6 server. (Details not shown.)
# Verify that the device has a static IPSG binding for the file server.
[Device] display ipv6 source binding static
Total entries found: 1
IPv6 Address         MAC Address    Interface               VLAN Type
2001::1              0001-0203-0405 HGE1/0/1                N/A  Static
# Verify that the device has generated dynamic IPSG bindings for Host A and Host B based on DHCP snooping entries.
[Device] display ipv6 source binding dhcpv6-snooping
2001::2              0001-0203-0406 HGE1/0/2                1    DHCPv6 snooping
2001::3              0001-0203-0407 HGE1/0/3                1    DHCPv6 snooping
# Verify that Host A and Host B can ping the DHCPv6 server. (Details not shown.)
# Verify that Host A and Host B cannot ping the DHCPv6 server when they are assigned IPv6 addresses manually. (Details not shown.)
Configuration files
interface HundredGigE1/0/3
interface HundredGigE1/0/4
Related documentation
·     H3C S12500R Switch Router Series Security Configuration Guide-R3606
·     H3C S12500R Switch Router Series Security Command Reference-R3606
