- H3C S12500R Ethernet Switch Router Series Config Examples-6W101
- 01-Login Management Configuration Examples
- 02-RBAC Configuration Examples
- 03-Software Upgrade Examples
- 04-Ethernet Link Aggregation Configuration Examples
- 05-Port Isolation Configuration Examples
- 06-Spanning Tree Configuration Examples
- 07-VLAN Configuration Examples
- 08-VLAN Tagging Configuration Examples
- 09-DHCP Snooping Configuration Examples
- 10-Cross-Subnet Dynamic IP Address Allocation Configuration Examples
- 11-IPv6 over IPv4 Tunneling with OSPFv3 Configuration Examples
- 12-GRE Tunnel Configuration Examples
- 13-GRE with OSPF Configuration Examples
- 14-OSPF Configuration Examples
- 15-IS-IS Configuration Examples
- 16-BGP Configuration Examples
- 17-Policy-Based Routing Configuration Examples
- 18-OSPFv3 Configuration Examples
- 19-IPv6 IS-IS Configuration Examples
- 20-Routing Policy Configuration Examples
- 21-IGMP Snooping Configuration Examples
- 22-IGMP Configuration Examples
- 23-MLD Snooping Configuration Examples
- 24-Basic MPLS Configuration Examples
- 25-MPLS L3VPN Configuration Examples
- 26-ACL Configuration Examples
- 27-Control Plane-Based QoS Policy Configuration Examples
- 28-Traffic Policing Configuration Examples
- 29-GTS and Rate Limiting Configuration Examples
- 30-Priority Mapping and Queue Scheduling Configuration Examples
- 31-Traffic Filtering Configuration Examples
- 32-AAA Configuration Examples
- 33-SSH Configuration Examples
- 34-IP Source Guard Configuration Examples
- 35-Ethernet OAM Configuration Examples
- 36-CFD Configuration Examples
- 37-DLDP Configuration Examples
- 38-VRRP Configuration Examples
- 39-BFD Configuration Examples
- 40-NTP Configuration Examples
- 41-SNMP Configuration Examples
- 42-NQA Configuration Examples
- 43-Mirroring Configuration Examples
- 44-sFlow Configuration Examples
- 45-OpenFlow Configuration Examples
- 46-MAC Address Table Configuration Examples
- 47-Static Multicast MAC Address Entry Configuration Examples
- 48-IP Unnumbered Configuration Examples
- 49-Congestion Avoidance and Queue Scheduling Configuration Examples
- 50-Attack Protection Configuration Examples
- 51-Smart Link Configuration Examples
- 52-RRPP Configuration Examples
- 53-BGP Route Selection Configuration Examples
- 54-IS-IS Route Summarization Configuration Examples
- 55-MPLS OAM Configuration Examples
- 56-MPLS TE Configuration Examples
- 57-VXLAN Configuration Examples
- 58-NetStream Configuration Examples
- 59-EVPN-DCI over an MPLS L3VPN Network Configuration Examples
- 60-PTP Configuration Examples
- 61-S-MLAG Configuration Examples
- 62-MPLS SR Configuration Examples
- 63-Puppet Configuration Examples
- 64-Configuration Example of Using Ethernet OAM to Monitor ERPS Ring Link Performance
- 65-GRE Tunneling Between DHCP Relay and DHCP Server Configuration Examples
- 66-Loop Detection Configuration Examples
- 67-MPLS L3VPN+VRRP Configuration Examples
- 68-MSTP and VRRP Load Balancing Configuration Examples
- 69-Routing Policy for VPN Access Control Configuration Examples
- 70-Switch and Firewall Connection Configuration Examples for External Network Access
- 71-Switch and Router Connection Configuration Examples for External Network Access
- 72-VRRP Network Multicast Data Transmission Configuration Examples
| 22-IGMP Configuration Examples | 177.85 KB |
H3C S12500R Switch Router Series |
Example: Configuring basic IGMP features
Example: Configuring IGMP static group members
Introduction
This document provides IGMP configuration examples.
This document assumes that you have basic knowledge of IGMP.
As shown in Figure 1:
· OSPF and PIM-DM run on the network.
· VOD streams are sent in multicast. Hosts of different organizations form stub networks N1 and N2.
· IGMPv2 runs between Device A and N1, and between the other two switches and N2. Device A acts as the IGMP querier in N1. Device B acts as the IGMP querier in N2 because it has a lower IP address.
Configure basic IGMP features on the switches to meet the following requirements:
· Hosts in N1 can join any multicast groups.
· Hosts in N2 can join only multicast group 224.1.1.1.
Analysis
To limit the multicast groups that hosts can join, create an IPv4 basic ACL and specify the multicast groups that you want the hosts to join.
Software versions used
This configuration example was created and verified on Release 3606.
The protocol packets of different IGMP versions are different in structures and types. For IGMP to operate correctly, you must enable the same IGMP version for all switches on the same subnet.
You must configure the same multicast group policy for all switches on the same subnet.
By default, interfaces on the device are disabled (in ADM or Administratively Down state). To have an interface operate, you must use the undo shutdown command to enable that interface.
Procedures
1. Assign an IP address and subnet mask to each interface, as shown in Figure 1. (Details not shown.)
2. Configure OSPF on the switches in the PIM-DM domain. (Details not shown.)
3. Configure Device A:
# Enable IP multicast routing.
[DeviceA] multicast routing
[DeviceA-mrib] quit
# Enable IGMP on the receiver-side interface HundredGigE 1/0/1.
[DeviceA] interface hundredgige 1/0/1
[DeviceA-Hundredgige1/0/1] igmp enable
[DeviceA-Hundredgige1/0/1] quit
# Enable PIM-DM on HundredGigE 1/0/2.
[DeviceA] interface hundredgige 1/0/2
[DeviceA-Hundredgige1/0/2] pim dm
[DeviceA-Hundredgige1/0/2] quit
4. Configure Device B:
# Create ACL 2001 to permit IGMP reports for multicast group 224.1.1.1.
[DeviceB] acl basic 2001
[DeviceB-acl-ipv4-basic-2001] rule permit source 224.1.1.1 0
[DeviceB-acl-ipv4-basic-2001] quit
[DeviceB] multicast routing
[DeviceB-mrib] quit
[DeviceB] interface hundredGigE 1/0/1
[DeviceB-HundredGigE1/0/1] igmp enable
# Configure a multicast group policy that uses ACL 2001.
[DeviceB-HundredGigE1/0/1] igmp group-policy 2001
[DeviceB-HundredGigE1/0/1] quit
[DeviceB] interface hundredGigE 1/0/2
[DeviceB-HundredGigE1/0/2] pim dm
[DeviceB-HundredGigE1/0/2] quit
5. Configure Device C:
<DeviceC> system-view
[DeviceC] acl basic 2001
[DeviceC-acl-ipv4-basic-2001] rule permit source 224.1.1.1 0
[DeviceC-acl-ipv4-basic-2001] quit
[DeviceC] multicast routing
[DeviceC-mrib] quit
# Enable IGMP on the receiver-side interface HundredGig E1/0/1.
[DeviceC] interface hundredGigE 1/0/1
[DeviceC-HundredGigE1/0/1] igmp enable
[DeviceC-HundredGigE1/0/1] igmp group-policy 2001
[DeviceC-HundredGigE1/0/1] quit
[DeviceC] interface hundredGigE 1/0/2
[DeviceC-HundredGigE1/0/2] pim dm
[DeviceC-HundredGigE1/0/22] quit
1. Verify that hosts in N1 can join the multicast groups 224.1.1.1 and 224.1.1.2:
# Send IGMP reports from Host A (10.110.1.10) to join the multicast groups 224.1.1.1 and 224.1.1.2. (Details not shown.)
# Display information about IGMP groups that hosts have dynamically joined on Device A.
[DeviceA] display igmp group
IGMP groups in total: 2
HundredGigE 1/0/1(10.110.1.1):
IGMP groups reported in total: 2
Group address Last reporter Uptime Expires
224.1.1.1 10.110.1.10 00:02:04 00:01:15
224.1.1.2 10.110.1.10 00:02:00 00:01:19
The output shows that Host A has joined the multicast groups 224.1.1.1 and 224.1.1.2.
2. Verify that hosts in N2 can join only multicast group 224.1.1.1:
# Send IGMP reports from Host C (10.110.2.10) to join the multicast groups 224.1.1.1 and 224.1.1.2. (Details not shown.)
# Display information about IGMP groups that hosts have dynamically joined on Device B.
[DeviceB] display igmp group
IGMP groups in total: 1
HundredGigE 1/0/1(10.110.2.1):
IGMP groups reported in total: 1
224.1.1.1 10.110.2.10 04:36:03 00:01:23
# Display information about IGMP groups that hosts have dynamically joined on Device C.
[DeviceC] display igmp group
HundredGigE 1/0/1(10.110.2.2):
224.1.1.1 10.110.2.10 04:21:03 00:01:13
The output shows that Device B and Device C each have IGMP information about only the multicast group, 224.1.1.1. The multicast group policy has taken effect, and hosts in N2 can join only multicast group 224.1.1.1.
Configuration files
· Device A:
interface HundredGigE1/0/1
ip address 10.110.1.1 255.255.255.0
igmp enable
interface HundredGigE1/0/2
ip address 10.111.1.1 255.255.255.0
pim dm
multicast routing
· Device B:
acl basic 2001
rule 0 permit source 224.1.1.1 0
ip address 10.110.2.1 255.255.255.0
igmp enable
ip address 10.111.2.1 255.255.255.0
pim dm
multicast routing
· Device C:
acl basic 2001
ip address 10.110.2.2 255.255.255.0
igmp enable
ip address 10.111.3.1 255.255.255.0
pim dm
multicast routing
As shown in Figure 2:
Configure the switches to meet the following requirements:
· Hosts in N1 can join any multicast groups, and Host A can permanently receive multicast data addressed to multicast group 224.1.1.2.
Analysis
For Host A to permanently receive multicast data addressed to the group 224.1.1.2, configure VLAN-interface 100 on Device A as a static member of the multicast group.
The protocol packets of different IGMP versions are different in structures and types. For IGMP to operate correctly, specify the same IGMP version for all switches on the same subnet.
Procedures
1. Assign an IP address and subnet mask to each interface, as shown in Figure 2. (Details not shown.)
[DeviceA-mrib] quit
[DeviceA-HundredGigE1/0/2] pim dm
[DeviceA-HundredGigE1/0/2] quit
[DeviceA-HundredGigE1/0/1] igmp enable
# Configure VLAN-interface 100 as a static member of multicast group 224.1.1.2.
[DeviceA-HundredGigE1/0/1] igmp static-group 224.1.1.2
[DeviceA-HundredGigE1/0/1] quit
[DeviceB-mrib] quit
[DeviceB] interface hundredgige 1/0/2
[DeviceB-Hundredgige1/0/2] pim dm
[DeviceB-Hundredgige1/0/2] quit
[DeviceB] interface hundredgige 1/0/1
[DeviceB-Hundredgige1/0/1] igmp enable
[DeviceB-Hundredgige1/0/1] igmp group-policy 2001
[DeviceB-Hundredgige1/0/10] quit
[DeviceC-mrib] quit
[DeviceC] interface hundredgige 1/0/2
[DeviceC-Hundredgige1/0/2] pim dm
[DeviceC-Hundredgige1/0/22] quit
# Enable IGMP on HundredGigE1/0/1.
[DeviceC] interface hundredgige1/0/1
[DeviceC-Hundredgige1/0/1] igmp enable
[DeviceC-Hundredgige1/0/1] igmp group-policy 2001
[DeviceC-Hundredgige1/0/10] quit
IGMP groups in total: 2.
Hundredgige1/0/1(10.110.1.1):
The output shows that Host A has dynamically joined the multicast groups 224.1.1.1 and 224.1.1.2.
# Display information about IGMP groups that hosts have statically joined on Device A.
[DeviceA] display igmp group static
Entries in total: 1
Group address Source address Interface Expires
224.1.1.2 0.0.0.0 HGE1/0/1 Never
The output shows that Host A has statically joined multicast group 224.1.1.1 through VLAN-interface 100.
# Send IGMP reports from Host C (10.110.2.10) to join multicast groups 224.1.1.1 and 224.1.1.2. (Details not shown.)
Hundredgige1/0/1(10.110.2.1):
Hundredgige1/0/1(10.110.2.2):
The output shows that Device B and Device C each have information only about multicast group 224.1.1.1. The multicast group policy has taken effect, and hosts in N2 can join only multicast group 224.1.1.1.
Configuration files
· Device A:
pim dm
igmp enable
multicast routing
· Device B:
acl basic 2001
pim dm
igmp enable
multicast routing
· Device C:
acl basic 2001
pim dm
igmp enable
multicast routing
Example: Configuring IGMP SSM mappings
As shown in Figure 3:
· The SSM group range for the PIM-SSM domain is 232.1.1.0/24.
· Device A and Device B in the PIM-SSM domain run IGMPv3.
· Host A in N1 and Host B in N2 run IGMPv2, and they do not support IGMPv3. The other hosts in N1 and N2 run IGMPv3.
Configure IGMP SSM mappings on Device A and Device B to meet the following requirements:
· Hosts in N1 receive multicast data only from Source 1.
· Hosts in N2 receive multicast data only from Source 2.
Procedures
1. Assign an IP address and subnet mask to each interface, as shown in Figure 3. (Details not shown.)
2. Configure OSPF on the switches in the PIM-SSM domain. (Details not shown.)
3. Enable IP multicast routing and enable PIM-SM:
# On Device A, enable IP multicast routing, and enable PIM-SM on HundredGigE 1/0/1.
[DeviceA-mrib] quit
[DeviceA] interface hundredgige1/0/1
[DeviceA-HundredGigE1/0/1] pim sm
# Configure Device B in the same way Device A is configured. (Details not shown.)
# On Router C, enable IP multicast routing, and enable PIM-SM on each interface.
[DeviceC-mrib] quit
[DeviceC-Hundredgige1/0/1] pim sm
[DeviceC-Hundredgige1/0/1] quit
[DeviceC] interface hundredgige1/0/2
[DeviceC-Hundredgige1/0/2] pim sm
[DeviceC-Hundredgige1/0/2] quit
[DeviceC] interface hundredgige1/0/3
[DeviceC-Hundredgige1/0/3] pim sm
[DeviceC-Hundredgige1/0/3] quit
4. On Device C, configure VLAN-interface 200 as a C-BSR and a C-RP:
[DeviceC] pim
[DeviceC-pim] c-bsr 192.168.1.1
[DeviceC-pim] c-rp 192.168.1.1
[DeviceC-pim] quit
5. Configure IGMPv3 on the receiver-side interfaces:
# On Device A, enable IGMP, and specify IGMP version 3 on HundredGigE 1/0/2.
[DeviceA-Hundredgige1/0/2] igmp enable
[DeviceA-Hundredgige1/0/2] igmp version 3
6. Configure the SSM group range:
# On Device A, configure the SSM group range as 232.1.1.0/24.
[DeviceA] acl basic 2000
[DeviceA-acl-ipv4-basic-2000] rule permit source 232.1.1.0 0.0.0.255
[DeviceA] pim
[DeviceA-pim] ssm-policy 2000
[DeviceA-pim] quit
# Configure Device B and Device C in the same way Device A is configured. (Details not shown.)
7. Configure IGMP SSM mappings:
# On Device A, configure an IGMP SSM mapping with multicast source 10.110.5.100 and multicast group range 232.1.1.0/24 specified in ACL 2000.
[DeviceA] igmp
[DeviceA-igmp] ssm-mapping 10.110.5.100 2000
[DeviceA-igmp] quit
# On Device B, configure an IGMP SSM mapping with multicast source 10.110.5.101 and multicast group range 232.1.1.0/24 specified in ACL 2000.
[DeviceB] igmp
[DeviceB-igmp] ssm-mapping 10.110.5.101 2000
[DeviceB-igmp] quit
# Send IGMPv2 reports from Host A and Host C to join multicast group 232.1.1.1. (Details not shown.)
# Send multicast data from Source 1 and Source 2 to multicast group 232.1.1.1. (Details not shown.)
# Display IGMP SSM mappings for multicast group 232.1.1.1 on Device A.
[DeviceA] display igmp ssm-mapping 232.1.1.1
Group: 232.1.1.1
Source list:
10.110.5.100
The output shows that multicast group 232.1.1.1 is associated with Source 1 (10.110.5.100). Device A will translate (0.0.0.0, 232.1.1.1) in IGMPv2 reports to (10.110.5.100, 232.1.1.1).
# Display the PIM routing table on Device A.
[DeviceA] display pim routing-table
Total 0 (*, G) entries; 1 (S, G) entries
Protocol: pim-ssm, Flag:
UpTime: 00:13:25
Upstream interface: HundredGigE1/0/1
Upstream neighbor: 192.168.1.1
RPF prime neighbor: 192.168.1.1
1: HundredGigE1/0/2
Protocol: igmp, UpTime: 02:54:43, Expires: 00:02:47
The output shows that Device A has the (10.110.5.100, 232.1.1.1) entry.
# Display IGMP SSM mappings for multicast group 232.1.1.1 on Device B.
[DeviceB] display igmp ssm-mapping 232.1.1.1
Group: 232.1.1.1
Source list:
10.110.5.101
The output shows that multicast group 232.1.1.1 is associated with Source 2 (10.110.5.101). Device B will translate (0.0.0.0, 232.1.1.1) in IGMPv2 reports to (10.101.5.101, 232.1.1.1).
# Display the PIM routing table on Device B.
[DeviceB] display pim routing-table
(10.110.5.101, 232.1.1.1)
UpTime: 00:12:16
Upstream neighbor: 192.168.2.1
RPF prime neighbor: 192.168.2.1
1: HundredGigE1/0/2
The output shows that Device B has the (10.110.5.101, 232.1.1.1) entry.
Configuration files
· Device A:
pim sm
igmp enable
igmp version 3
multicast routing
pim
ssm-policy 2000
igmp
acl basic 2000
rule 0 permit source 232.1.1.0 0.0.0.255
· Device B:
pim sm
igmp enable
igmp version 3
multicast routing
pim
ssm-policy 2000
igmp
acl basic 2000
· Device C:
pim sm
pim sm
interface HundredGigE1/0/3
pim sm
multicast routing
pim
c-bsr 192.168.1.1
c-rp 192.168.1.1
Related documentation
· H3C S12500R Switch Router Series IP Multicast Command Reference-R3606
· H3C S12500R Switch Router Series IP Multicast Configuration Guide-R3606
