- H3C S12500R Ethernet Switch Router Series Config Examples-6W101
- 01-Login Management Configuration Examples
- 02-RBAC Configuration Examples
- 03-Software Upgrade Examples
- 04-Ethernet Link Aggregation Configuration Examples
- 05-Port Isolation Configuration Examples
- 06-Spanning Tree Configuration Examples
- 07-VLAN Configuration Examples
- 08-VLAN Tagging Configuration Examples
- 09-DHCP Snooping Configuration Examples
- 10-Cross-Subnet Dynamic IP Address Allocation Configuration Examples
- 11-IPv6 over IPv4 Tunneling with OSPFv3 Configuration Examples
- 12-GRE Tunnel Configuration Examples
- 13-GRE with OSPF Configuration Examples
- 14-OSPF Configuration Examples
- 15-IS-IS Configuration Examples
- 16-BGP Configuration Examples
- 17-Policy-Based Routing Configuration Examples
- 18-OSPFv3 Configuration Examples
- 19-IPv6 IS-IS Configuration Examples
- 20-Routing Policy Configuration Examples
- 21-IGMP Snooping Configuration Examples
- 22-IGMP Configuration Examples
- 23-MLD Snooping Configuration Examples
- 24-Basic MPLS Configuration Examples
- 25-MPLS L3VPN Configuration Examples
- 26-ACL Configuration Examples
- 27-Control Plane-Based QoS Policy Configuration Examples
- 28-Traffic Policing Configuration Examples
- 29-GTS and Rate Limiting Configuration Examples
- 30-Priority Mapping and Queue Scheduling Configuration Examples
- 31-Traffic Filtering Configuration Examples
- 32-AAA Configuration Examples
- 33-SSH Configuration Examples
- 34-IP Source Guard Configuration Examples
- 35-Ethernet OAM Configuration Examples
- 36-CFD Configuration Examples
- 37-DLDP Configuration Examples
- 38-VRRP Configuration Examples
- 39-BFD Configuration Examples
- 40-NTP Configuration Examples
- 41-SNMP Configuration Examples
- 42-NQA Configuration Examples
- 43-Mirroring Configuration Examples
- 44-sFlow Configuration Examples
- 45-OpenFlow Configuration Examples
- 46-MAC Address Table Configuration Examples
- 47-Static Multicast MAC Address Entry Configuration Examples
- 48-IP Unnumbered Configuration Examples
- 49-Congestion Avoidance and Queue Scheduling Configuration Examples
- 50-Attack Protection Configuration Examples
- 51-Smart Link Configuration Examples
- 52-RRPP Configuration Examples
- 53-BGP Route Selection Configuration Examples
- 54-IS-IS Route Summarization Configuration Examples
- 55-MPLS OAM Configuration Examples
- 56-MPLS TE Configuration Examples
- 57-VXLAN Configuration Examples
- 58-NetStream Configuration Examples
- 59-EVPN-DCI over an MPLS L3VPN Network Configuration Examples
- 60-PTP Configuration Examples
- 61-S-MLAG Configuration Examples
- 62-MPLS SR Configuration Examples
- 63-Puppet Configuration Examples
- 64-Configuration Example of Using Ethernet OAM to Monitor ERPS Ring Link Performance
- 65-GRE Tunneling Between DHCP Relay and DHCP Server Configuration Examples
- 66-Loop Detection Configuration Examples
- 67-MPLS L3VPN+VRRP Configuration Examples
- 68-MSTP and VRRP Load Balancing Configuration Examples
- 69-Routing Policy for VPN Access Control Configuration Examples
- 70-Switch and Firewall Connection Configuration Examples for External Network Access
- 71-Switch and Router Connection Configuration Examples for External Network Access
- 72-VRRP Network Multicast Data Transmission Configuration Examples
| 23-MLD Snooping Configuration Examples | 151.05 KB |
H3C S12500R Switch Router Series |
Example: Configuring IPv6 multicast group policies
Introduction
This document introduces MLD snooping configuration examples.
This document is not restricted to specific software or hardware versions.
This document assumes that you have basic knowledge of MLD snooping.
As shown in Figure 1:
· Router A runs MLDv1 and acts as the MLD querier in VLAN 100.
· Device A runs MLDv1 snooping.
Configure IPv6 multicast group policies on Device A so that Host A and Host B receive only the IPv6 multicast data addressed to IPv6 multicast group FF1E::101.
Analysis
To meet the network requirements, you must perform the following tasks:
· To prevent Device A from flooding MLDv1 packets in VLAN 100, specify MLD snooping version 2 in VLAN 100. By default, MLDv1 snooping runs on the device. MLDv1 snooping processes only MLDv1 packets and floods MLDv2 packets in a VLAN.
· To prevent receiver hosts in VLAN 100 from receiving IPv6 multicast data addressed to other groups, enable dropping unknown IPv6 multicast data in VLAN 100.
· To configure an IPv6 multicast group policy, specify an IPv6 basic ACL and create ACL rules to define the groups you want the receiver hosts to join.
Software versions used
This configuration example was created and verified on Release 3606.
You must globally enable MLD snooping in system view before you enable MLD snooping for a VLAN in VLAN view.
IPv6 multicast group filtering denies all groups if the specified ACL does not exist or the ACL does not have any rules.
By default, interfaces on the device are disabled (in ADM or Administratively Down state). To have an interface operate, you must use the undo shutdown command to enable that interface.
In this example, interfaces must operate in Layer 2 mode. By default, physical interfaces on the device are operating at Layer 3 mode. To configure an interface to operate in Layer 2 mode, use the port link-mode command to change the link mode of that interface.
Procedures
1. Assign an IPv6 address and prefix length to each interface on the routers in the IPv6 PIM-DM domain. (Details not shown.)
2. Configure an IPv6 unicast routing protocol on the routers in the IPv6 PIM-DM domain. (Details not shown.)
3. Enable IPv6 multicast routing globally on the routers in the IPv6 PIM-DM domain. (Details not shown.)
4. Enable IPv6 PIM-DM for the interfaces through which routers connects with each other on the routers in the IPv6 PIM-DM domain. (Details not shown.)
5. Configure Device A:
# Enable MLD snooping globally.
[DeviceA] mld-snooping
[DeviceA-mld-snooping] quit
# Create VLAN 100, and assign HundredGigE 1/0/1 through HundredGigE 1/0/4 to this VLAN.
[DeviceA] vlan 100
[DeviceA-vlan100] port hundredgige 1/0/1 to hundredgige 1/0/4
# In VLAN 100, enable MLD snooping, specify MLD snooping version 2, and dropping unknown IPv6 multicast data for VLAN 100.
[DeviceA-vlan100] mld-snooping enable
[DeviceA-vlan100] mld-snooping version 2
[DeviceA-vlan100] mld-snooping drop-unknown
[DeviceA-vlan100] quit
# Configure an IPv6 multicast group policy for VLAN 100 so that receiver hosts in this VLAN can join only IPv6 multicast group FF1E::101.
[DeviceA] acl ipv6 basic 2001
[DeviceA-acl-ipv6-basic-2001] rule permit source ff1e::101 128
[DeviceA-acl-ipv6-basic-2001] quit
[DeviceA–mld-snooping] group-policy 2001 vlan 100
[DeviceA–mld-snooping] quit
# Send MLD reports from Host A and Host B to join IPv6 multicast groups FF1E::101 and FF1E::202. (Details not shown.)
# Send IPv6 multicast data from the source to IPv6 multicast groups FF1E::101 and FF1E::202. (Details not shown.)
# Display dynamic MLD snooping group entries for VLAN 100 on Device A.
[DeviceA] display mld-snooping group vlan 100
Total 1 entries.
VLAN 100: Total 1 entries.
(::, FF1E::101)
Host ports (2 in total):
HGE1/0/3 (00:03:23)
HGE1/0/4 (00:04:10)
The output shows that Host A and Host B have joined IPv6 multicast group FF1E::101 through member ports HundredGigE 1/0/4 and HundredGigE 1/0/3. Host A and Host B do not join IPv6 multicast group FF1E::202. The IPv6 multicast group policy has taken effect.
Configuration files
Device A:
acl ipv6 number 2001
rule 0 permit source FF1E::101/128
mld-snooping
vlan 100
mld-snooping enable
interface HundredGigE1/0/1
port link-mode bridge
port access vlan 100
interface HundredGigE1/0/2
interface HundredGigE1/0/3
interface HundredGigE1/0/4
Example: Configuring MLD snooping static ports
As shown in Figure 2:
· All devices in VLAN 100 run MLD snooping.
· Router A runs MLDv1 and acts as the MLD querier.
· STP runs in VLAN 100. The direct route between Device A and Device B or the route from Device A to Device B with Device C as the intermediate device is blocked to avoid loops.
Configure MLD snooping static ports to meet the following requirements:
· IPv6 multicast data uninterruptedly flows to Host A and Host B after a link switchover occurs between Device A and Device B.
· Host A and Host B permanently receive the IPv6 multicast data addressed to IPv6 multicast group FF1E::101.
Analysis
· By default, when a link switchover occurs, multicast data can flow along the new link after a minimum of one MLD query-response cycle. Multicast delivery is interrupted during this process.
Configure HundredGigE 1/0/2 and HundredGigE 1/0/3 on Device A, HundredGigE 1/0/4 on Device B, and HundredGigE 1/0/2 on Device C as static router ports. Then, IPv6 multicast data will always be forwarded to these ports, and multicast delivery is uninterrupted.
· Configure HundredGigE 1/0/2 and HundredGigE 1/0/3 on Device B as static member ports of IPv6 multicast group FF1E::101. Then, IPv6 multicast data for the group will always be forwarded out of these ports, and Host A and Host B can always receiver the data.
Procedures
# Create VLAN 100, assign HundredGigE 1/0/1 through HundredGigE 1/0/3 to this VLAN, and enable MLD snooping for this VLAN.
[DeviceA] vlan 100
[DeviceA-vlan100] port hundredgige 1/0/1 to hundredgige 1/0/3
# Configure HundredGigE 1/0/2 and HundredGigE 1/0/3 as static router ports.
[DeviceA] interface hundredgige 1/0/2
[DeviceA-HundredGigE1/0/2] mld-snooping static-router-port vlan 100
[DeviceA-HundredGigE1/0/2] quit
[DeviceA] interface hundredgige 1/0/3
[DeviceA-HundredGigE1/0/3] mld-snooping static-router-port vlan 100
[DeviceA-HundredGigE1/0/3] quit
6. Configure Device B:
[DeviceB] mld-snooping
[DeviceB-mld-snooping] quit
# Create VLAN 100, assign HundredGigE 1/0/1 and HundredGigE 1/0/4 to this VLAN, and enable MLD snooping for this VLAN.
[DeviceB] vlan 100
[DeviceB-vlan100] port hundredgige 1/0/1 hundredgige 1/0/4
[DeviceB-vlan100] mld-snooping enable
[DeviceB-vlan100] quit
# Configure HundredGigE 1/0/4 as a static router port.
[DeviceB] interface hundredgige 1/0/4
[DeviceB-HundredGigE1/0/4] mld-snooping static-router-port vlan 100
[DeviceB-HundredGigE1/0/4] quit
# Configure HundredGigE 1/0/2 and HundredGigE 1/0/3 as static member ports for IPv6 multicast group FF1E::101 in VLAN 100.
[DeviceB] interface hundredgige 1/0/2
[DeviceB-HundredGigE1/0/2] mld-snooping static-group ff1e::101 vlan 100
[DeviceB-HundredGigE1/0/2] quit
[DeviceB] interface hundredgige 1/0/3
[DeviceB-HundredGigE1/0/3] mld-snooping static-group ff1e::101 vlan 100
[DeviceB-HundredGigE1/0/3] quit
7. Configure Device C:
<DeviceC> system-view
[DeviceC] mld-snooping
[DeviceC-mld-snooping] quit
# Create VLAN 100, assign HundredGigE 1/0/1 through HundredGigE 1/0/4 to this VLAN, and enable MLD snooping for this VLAN.
[DeviceC] vlan 100
[DeviceC-vlan100] port hundredgige 1/0/1 to hundredgige 1/0/4
[DeviceC-vlan100] mld-snooping enable
[DeviceC-vlan100] quit
# Configure HundredGigE1/0/2 as a static router port in VLAN 100.
[DeviceC] interface hundredgige 1/0/2
[DeviceC-HundredGigE1/0/2] mld-snooping static-router-port vlan 100
[DeviceC-HundredGigE1/0/2] quit
Verify the configuration before hosts join any multicast groups.
# Display static router port information for VLAN 100 on Device A.
[DeviceA] display mld-snooping static-router-port vlan 100
VLAN 100:
Router ports (2 in total):
HGE1/0/2
HGE1/0/3
The output shows that HundredGigE 1/0/2 and HundredGigE 1/0/3 on Device A have become static router ports in VLAN 100.
# Display static router port information for VLAN 100 on Device B.
[DeviceB] display mld-snooping static-router-port vlan 100
VLAN 100:
Router ports (1 in total):
HGE1/0/4
The output shows that HundredGigE 1/0/4 on Device B has become a static router port in VLAN 100.
# Display static MLD snooping group entries for VLAN 100 on Device B.
[DeviceB] display mld-snooping static-group vlan 100
Total 1 entries.
(::, FF1E::101)
HGE1/0/2
HGE1/0/3
The output shows that HundredGigE 1/0/2 and HundredGigE 1/0/3 on Device B have become static member ports of IPv6 multicast group FF1E::101 in VLAN 100.
# Display static router port information for VLAN 100 on Device C.
[DeviceC] display mld-snooping static-router-port vlan 100
VLAN 100:
HGE1/0/2
The output shows that HundredGigE 1/0/2 on Device C has become a static router port in VLAN 100.
Configuration files
· Device A:
mld-snooping
vlan 100
mld-snooping enable
· Device B:
mld-snooping
vlan 100
mld-snooping enable
mld-snooping static-group FF1E::101 vlan 100
· Device C:
mld-snooping
vlan 100
mld-snooping enable
Related documentation
· H3C S12500R Switch Router Series IP Multicast Command Reference-R3606
· H3C S12500R Switch Router Series IP Multicast Configuration Guide-R3606
