- H3C S12500R Ethernet Switch Router Series Config Examples-6W101
- 01-Login Management Configuration Examples
- 02-RBAC Configuration Examples
- 03-Software Upgrade Examples
- 04-Ethernet Link Aggregation Configuration Examples
- 05-Port Isolation Configuration Examples
- 06-Spanning Tree Configuration Examples
- 07-VLAN Configuration Examples
- 08-VLAN Tagging Configuration Examples
- 09-DHCP Snooping Configuration Examples
- 10-Cross-Subnet Dynamic IP Address Allocation Configuration Examples
- 11-IPv6 over IPv4 Tunneling with OSPFv3 Configuration Examples
- 12-GRE Tunnel Configuration Examples
- 13-GRE with OSPF Configuration Examples
- 14-OSPF Configuration Examples
- 15-IS-IS Configuration Examples
- 16-BGP Configuration Examples
- 17-Policy-Based Routing Configuration Examples
- 18-OSPFv3 Configuration Examples
- 19-IPv6 IS-IS Configuration Examples
- 20-Routing Policy Configuration Examples
- 21-IGMP Snooping Configuration Examples
- 22-IGMP Configuration Examples
- 23-MLD Snooping Configuration Examples
- 24-Basic MPLS Configuration Examples
- 25-MPLS L3VPN Configuration Examples
- 26-ACL Configuration Examples
- 27-Control Plane-Based QoS Policy Configuration Examples
- 28-Traffic Policing Configuration Examples
- 29-GTS and Rate Limiting Configuration Examples
- 30-Priority Mapping and Queue Scheduling Configuration Examples
- 31-Traffic Filtering Configuration Examples
- 32-AAA Configuration Examples
- 33-SSH Configuration Examples
- 34-IP Source Guard Configuration Examples
- 35-Ethernet OAM Configuration Examples
- 36-CFD Configuration Examples
- 37-DLDP Configuration Examples
- 38-VRRP Configuration Examples
- 39-BFD Configuration Examples
- 40-NTP Configuration Examples
- 41-SNMP Configuration Examples
- 42-NQA Configuration Examples
- 43-Mirroring Configuration Examples
- 44-sFlow Configuration Examples
- 45-OpenFlow Configuration Examples
- 46-MAC Address Table Configuration Examples
- 47-Static Multicast MAC Address Entry Configuration Examples
- 48-IP Unnumbered Configuration Examples
- 49-Congestion Avoidance and Queue Scheduling Configuration Examples
- 50-Attack Protection Configuration Examples
- 51-Smart Link Configuration Examples
- 52-RRPP Configuration Examples
- 53-BGP Route Selection Configuration Examples
- 54-IS-IS Route Summarization Configuration Examples
- 55-MPLS OAM Configuration Examples
- 56-MPLS TE Configuration Examples
- 57-VXLAN Configuration Examples
- 58-NetStream Configuration Examples
- 59-EVPN-DCI over an MPLS L3VPN Network Configuration Examples
- 60-PTP Configuration Examples
- 61-S-MLAG Configuration Examples
- 62-MPLS SR Configuration Examples
- 63-Puppet Configuration Examples
- 64-Configuration Example of Using Ethernet OAM to Monitor ERPS Ring Link Performance
- 65-GRE Tunneling Between DHCP Relay and DHCP Server Configuration Examples
- 66-Loop Detection Configuration Examples
- 67-MPLS L3VPN+VRRP Configuration Examples
- 68-MSTP and VRRP Load Balancing Configuration Examples
- 69-Routing Policy for VPN Access Control Configuration Examples
- 70-Switch and Firewall Connection Configuration Examples for External Network Access
- 71-Switch and Router Connection Configuration Examples for External Network Access
- 72-VRRP Network Multicast Data Transmission Configuration Examples
| 35-Ethernet OAM Configuration Examples | 74.92 KB |
H3C S12500R Switch Router Series |
Introduction
This document provides Ethernet OAM configuration examples.
Ethernet OAM is a tool that monitors the status of the link between two directly connected devices.
This document assumes that you have basic knowledge of Ethernet OAM.
Example: Configuring Ethernet OAM
As shown in Figure 1, the edge devices Device A and Device B connect the enterprise network and the carrier network. Configure Ethernet OAM on Device A and Device B to meet the following Service Level Agreement (SLA) requirements:
· Device A and Device B automatically monitor the link between them.
· The administrator can view critical link events on the link between Device A and Device B.
· The administrator can obtain the link status by observing link error event statistics.
Analysis
To implement link event detection based on the network environment, configure errored frame event detection parameters and use global settings for other detection parameters.
Software versions used
This configuration example was created and verified on Release 3606.
To change the Ethernet OAM mode on an Ethernet OAM-enabled port, first disable Ethernet OAM on the port.
By default, interfaces on the device are disabled (in ADM or Administratively Down state). To have an interface operate, you must use the undo shutdown command to enable that interface.
Procedures
Configuring Device A
# Configure HundredGigE 1/0/1 to operate in active Ethernet OAM mode (default mode), and enable Ethernet OAM for it.
[DeviceA] interface hundredgige 1/0/1
[DeviceA-HundredGigE1/0/1] oam mode active
[DeviceA-HundredGigE1/0/1] oam enable
# Set the errored frame event detection window to 20000 milliseconds, and set the errored frame event triggering threshold to 10.
[DeviceA-HundredGigE1/0/1] oam errored-frame window 200
[DeviceA-HundredGigE1/0/1] oam errored-frame threshold 10
[DeviceA-HundredGigE1/0/1] quit
Configuring Device B
# Configure HundredGigE 1/0/1 to operate in passive Ethernet OAM mode, and enable Ethernet OAM for it.
[DeviceB] interface hundredgige 1/0/1
[DeviceB-HundredGigE1/0/1] oam mode passive
[DeviceB-HundredGigE1/0/1] oam enable
[DeviceB-HundredGigE1/0/1] quit
# Display Ethernet OAM configuration globally and on ports that do not use the default configuration.
[DeviceA] display oam configuration
---------------- [Global] ----------------
OAM timers
Hello timer : 1000 milliseconds
Keepalive timer : 5000 milliseconds
Link monitoring
Errored symbol period
Window : 100 x 1000000 symbols
Threshold : 1 error symbols
Errored frame
Window : 10 x 100 milliseconds
Threshold : 1 error frames
Errored frame period
Window : 1000 x 10000 frames
Errored frame seconds
Window : 600 x 100 milliseconds
Threshold : 1 error seconds
----------- [HundredGigE1/0/1] -----------
OAM timers
Link monitoring
Errored frame
Window : 200 x 100 milliseconds
Threshold : 10 error frames
# Display the statistics for critical Ethernet OAM link events that occurred on all ports of Device A.
[DeviceA] display oam critical-event
Local link status : UP
Event statistics
Link fault : Not occurred
Dying gasp : Not occurred
Critical event : Not occurred
The output shows that no critical link event has occurred on the link between Device A and Device B.
# Display Ethernet OAM link event statistics for the local end of Device A.
[DeviceA] display oam link-event local
Link status: UP
OAM local errored frame event
Event time stamp : 5789 x 100 milliseconds
Errored frame window : 200 x 100 milliseconds
Errored frame threshold : 10 error frames
Errored frame : 13 error frames
Error running total : 350 error frames
Event running total : 17 events
· 350 errors have occurred after Ethernet OAM is enabled on Device A.
· 17 errors are caused by error frames.
· The link is unstable.
NOTE: If the link is unstable, contact H3C Support. |
Configuration files
· Device A:
interface HundredGigE1/0/1
oam enable
· Device B:
oam mode passive
oam enable
Related documentation
· H3C S12500R Switch Router Series High Availability Command Reference-R3606
· H3C S12500R Switch Router Series High Availability Configuration Guide-R3606
