- H3C S12500R Ethernet Switch Router Series Config Examples-6W101
- 01-Login Management Configuration Examples
- 02-RBAC Configuration Examples
- 03-Software Upgrade Examples
- 04-Ethernet Link Aggregation Configuration Examples
- 05-Port Isolation Configuration Examples
- 06-Spanning Tree Configuration Examples
- 07-VLAN Configuration Examples
- 08-VLAN Tagging Configuration Examples
- 09-DHCP Snooping Configuration Examples
- 10-Cross-Subnet Dynamic IP Address Allocation Configuration Examples
- 11-IPv6 over IPv4 Tunneling with OSPFv3 Configuration Examples
- 12-GRE Tunnel Configuration Examples
- 13-GRE with OSPF Configuration Examples
- 14-OSPF Configuration Examples
- 15-IS-IS Configuration Examples
- 16-BGP Configuration Examples
- 17-Policy-Based Routing Configuration Examples
- 18-OSPFv3 Configuration Examples
- 19-IPv6 IS-IS Configuration Examples
- 20-Routing Policy Configuration Examples
- 21-IGMP Snooping Configuration Examples
- 22-IGMP Configuration Examples
- 23-MLD Snooping Configuration Examples
- 24-Basic MPLS Configuration Examples
- 25-MPLS L3VPN Configuration Examples
- 26-ACL Configuration Examples
- 27-Control Plane-Based QoS Policy Configuration Examples
- 28-Traffic Policing Configuration Examples
- 29-GTS and Rate Limiting Configuration Examples
- 30-Priority Mapping and Queue Scheduling Configuration Examples
- 31-Traffic Filtering Configuration Examples
- 32-AAA Configuration Examples
- 33-SSH Configuration Examples
- 34-IP Source Guard Configuration Examples
- 35-Ethernet OAM Configuration Examples
- 36-CFD Configuration Examples
- 37-DLDP Configuration Examples
- 38-VRRP Configuration Examples
- 39-BFD Configuration Examples
- 40-NTP Configuration Examples
- 41-SNMP Configuration Examples
- 42-NQA Configuration Examples
- 43-Mirroring Configuration Examples
- 44-sFlow Configuration Examples
- 45-OpenFlow Configuration Examples
- 46-MAC Address Table Configuration Examples
- 47-Static Multicast MAC Address Entry Configuration Examples
- 48-IP Unnumbered Configuration Examples
- 49-Congestion Avoidance and Queue Scheduling Configuration Examples
- 50-Attack Protection Configuration Examples
- 51-Smart Link Configuration Examples
- 52-RRPP Configuration Examples
- 53-BGP Route Selection Configuration Examples
- 54-IS-IS Route Summarization Configuration Examples
- 55-MPLS OAM Configuration Examples
- 56-MPLS TE Configuration Examples
- 57-VXLAN Configuration Examples
- 58-NetStream Configuration Examples
- 59-EVPN-DCI over an MPLS L3VPN Network Configuration Examples
- 60-PTP Configuration Examples
- 61-S-MLAG Configuration Examples
- 62-MPLS SR Configuration Examples
- 63-Puppet Configuration Examples
- 64-Configuration Example of Using Ethernet OAM to Monitor ERPS Ring Link Performance
- 65-GRE Tunneling Between DHCP Relay and DHCP Server Configuration Examples
- 66-Loop Detection Configuration Examples
- 67-MPLS L3VPN+VRRP Configuration Examples
- 68-MSTP and VRRP Load Balancing Configuration Examples
- 69-Routing Policy for VPN Access Control Configuration Examples
- 70-Switch and Firewall Connection Configuration Examples for External Network Access
- 71-Switch and Router Connection Configuration Examples for External Network Access
- 72-VRRP Network Multicast Data Transmission Configuration Examples
| 42-NQA Configuration Examples | 366.69 KB |
H3C S12500R Switch Router Series |
General restrictions and guidelines
Example: Configuring an NQA ICMP echo operation
Example: Configuring an NQA ICMP jitter operation
Example: Configuring an NQA DHCP operation
Example: Configuring an NQA DNS operation
Example: Configuring an NQA FTP operation
Example: Configuring an NQA HTTP operation
Example: Configuring an NQA UDP jitter operation
Example: Configuring an NQA SNMP operation
Example: Configuring an NQA TCP operation
Example: Configuring an NQA UDP echo operation
Example: Configuring an NQA UDP tracert operation
Example: Configuring an NQA voice operation
Example: Configuring an NQA DLSw operation
Example: Configuring an NQA path jitter operation
Introduction
This document provides NQA configuration examples.
This document assumes that you have basic knowledge of NQA.
The ICMP echo operation is not supported in IPv6 networks. To test the reachability of an IPv6 address, use the ping ipv6 command.
As shown in Figure 1, configure an NQA ICMP echo operation to test the roundtrip time between Device A and Device D through Device B.
Software versions used
This configuration example was created and verified on R3606.
When you configure an NQA ICMP echo operation, follow these restrictions and guidelines:
· Make sure the devices can reach each other before you start the NQA operation.
· You cannot modify the operation configuration for a running NQA operation.
· By default, interfaces on the device are disabled (in ADM or Administratively Down state). To have an interface operate, you must use the undo shutdown command to enable that interface.
Procedures
# Create an NQA ICMP echo operation.
[DeviceA] nqa entry admin test
[DeviceA-nqa-admin-test] type icmp-echo
# Specify the destination IP address of ICMP echo requests as 60.1.1.1.
[DeviceA-nqa-admin-test-icmp-echo] destination ip 60.1.1.1
# Specify the next hop of ICMP echo requests as 10.1.1.2.
[DeviceA-nqa-admin-test-icmp-echo] next-hop ip 10.1.1.2
# Configure the ICMP echo operation to perform 10 probes.
[DeviceA-nqa-admin-test-icmp-echo] probe count 10
# Specify the probe timeout time as 500 milliseconds for the ICMP echo operation.
[DeviceA-nqa-admin-test-icmp-echo] probe timeout 500
# Configure the ICMP echo operation to repeat at an interval of 5000 milliseconds.
[DeviceA-nqa-admin-test-icmp-echo] frequency 5000
# Enable saving history records.
[DeviceA-nqa-admin-test-icmp-echo] history-record enable
# Configure the maximum number of history records that can be saved as 10.
[DeviceA-nqa-admin-test-icmp-echo] history-record number 10
[DeviceA-nqa-admin-test-icmp-echo] quit
# Start the ICMP echo operation.
[DeviceA] nqa schedule admin test start-time now lifetime forever
# After the ICMP echo operation runs for a time period, stop the operation.
[DeviceA] undo nqa schedule admin test
# Display the most recent result of the ICMP echo operation.
[DeviceA] display nqa result admin test
NQA entry (admin admin, tag test) test results:
Send operation times: 10 Receive response times: 10
Min/Max/Average round trip time: 2/5/3
Square-Sum of round trip time: 96
Last succeeded probe time: 2020-03-23 15:00:01.2
Extended results:
Packet loss ratio: 0%
Failures due to timeout: 0
Failures due to internal error: 0
Failures due to other errors: 0
# Display the history records of the ICMP echo operation.
[DeviceA] display nqa history admin test
NQA entry (admin admin, tag test) history records:
Index Response Status Time
370 3 Succeeded 2020-03-23 15:00:01.2
369 3 Succeeded 2020-03-23 15:00:01.2
368 3 Succeeded 2020-03-23 15:00:01.2
367 5 Succeeded 2020-03-23 15:00:01.2
366 3 Succeeded 2020-03-23 15:00:01.2
365 3 Succeeded 2020-03-23 15:00:01.2
364 3 Succeeded 2020-03-23 15:00:01.1
363 2 Succeeded 2020-03-23 15:00:01.1
362 3 Succeeded 2020-03-23 15:00:01.1
361 2 Succeeded 2020-03-23 15:00:01.1
The output shows that the packets sent by Device A can reach Device D through Device B. No packet loss occurs during the operation. The minimum, maximum, and average round-trip times are 2, 5, and 3 milliseconds, respectively.
Configuration files
type icmp-echo
frequency 5000
probe count 10
probe timeout 500
As shown in Figure 1, configure an ICMP jitter operation to test the jitter between Device A and Device B.
Figure 2 Network diagram
When you configure an NQA ICMP jitter operation, follow these restrictions and guidelines:
Procedures
# Create an NQA ICMP jitter operation.
[DeviceA-nqa-admin-test] type icmp-jitter
# Specify 10.2.2.2 as the destination address for the operation.
[DeviceA-nqa-admin-test-icmp-jitter] destination ip 10.2.2.2
# Configure the operation to repeat every 1000 milliseconds.
[DeviceA-nqa-admin-test-icmp-jitter] frequency 1000
[DeviceA-nqa-admin-test-icmp-jitter] quit
# Start the ICMP jitter operation.
# After the ICMP jitter operation runs for a time period, stop the operation.
# Display the most recent result of the ICMP jitter operation.
Min/Max/Average round trip time: 1/2/1
Square-Sum of round trip time: 13
Last packet received time: 2020-03-09 17:40:29.8
Extended results:
Packets out of sequence: 0
Packets arrived late: 0
ICMP-jitter results:
RTT number: 10
Min positive SD: 0 Min positive DS: 0
Max positive SD: 0 Max positive DS: 0
Positive SD number: 0 Positive DS number: 0
Positive SD sum: 0 Positive DS sum: 0
Positive SD average: 0 Positive DS average: 0
Positive SD square-sum: 0 Positive DS square-sum: 0
Min negative SD: 1 Min negative DS: 2
Max negative SD: 1 Max negative DS: 2
Negative SD number: 1 Negative DS number: 1
Negative SD sum: 1 Negative DS sum: 2
Negative SD average: 1 Negative DS average: 2
Negative SD square-sum: 1 Negative DS square-sum: 4
One way results:
Max SD delay: 1 Max DS delay: 2
Min SD delay: 1 Min DS delay: 2
Number of SD delay: 1 Number of DS delay: 1
Sum of SD delay: 1 Sum of DS delay: 2
Square-Sum of SD delay: 1 Square-Sum of DS delay: 4
Lost packets for unknown reason: 0
# Display the statistics of the ICMP jitter operation.
[DeviceA] display nqa statistics admin test
NQA entry (admin admin, tag test) test statistics:
NO. : 1
Start time: 2020-03-09 17:42:10.7
Life time: 156 seconds
Send operation times: 1560 Receive response times: 1560
Square-Sum of round trip time: 1563
Extended results:
RTT number: 1560
Min positive SD: 1 Min positive DS: 1
Max positive SD: 1 Max positive DS: 2
Positive SD number: 18 Positive DS number: 46
Positive SD sum: 18 Positive DS sum: 49
Positive SD average: 1 Positive DS average: 1
Positive SD square-sum: 18 Positive DS square-sum: 55
Min negative SD: 1 Min negative DS: 1
Negative SD number: 24 Negative DS number: 57
Negative SD sum: 24 Negative DS sum: 58
Negative SD average: 1 Negative DS average: 1
Negative SD square-sum: 24 Negative DS square-sum: 60
One way results:
Min SD delay: 1 Min DS delay: 1
Number of SD delay: 4 Number of DS delay: 4
Sum of SD delay: 4 Sum of DS delay: 5
Square-Sum of SD delay: 4 Square-Sum of DS delay: 7
Configuration files
type icmp-jitter
frequency 1000
As shown in Figure 3, configure an NQA DHCP operation to test the time required for Device A to obtain an IP address from the DHCP server (Device B).
When you configure an NQA DHCP operation, follow these restrictions and guidelines:
· Complete the DHCP server configuration before you start the DHCP operation.
· Make sure the devices can reach each other before you start the operation.
Procedures
# Create an NQA DHCP operation.
[DeviceA-nqa-admin-test] type dhcp
# Specify the DHCP server IP address 10.1.1.2 as the destination address.
[DeviceA-nqa-admin-test-dhcp] destination ip 10.1.1.2
# Enable the saving of history records.
[DeviceA-nqa-admin-test-dhcp] history-record enable
[DeviceA-nqa-admin-test-dhcp] quit
# Start the DHCP operation.
# After the operation runs for a time period, stop the operation.
# Display the most recent result of the DHCP operation.
NQA entry(admin admin, tag test) test results:
Send operation times: 1 Receive response times: 1
Min/Max/Average round trip time: 624/624/624
Square-Sum of round trip time: 389376
Last succeeded probe time: 2020-03-24 09:56:03.2
Extend results:
Packet lost in test: 0%
# Display the history records of the DHCP operation.
NQA entry(admin admin, tag test) history record(s):
1 624 Succeeded 2020-03-24 09:56:03.2
Configuration files
type dhcp
As shown in Figure 4, configure an NQA DNS operation to test whether Device A can perform address resolution through the DNS server and test the resolution time.
When you configure an NQA DNS operation, follow these restrictions and guidelines:
Procedures
# Create an NQA DNS operation.
[DeviceA-nqa-admin-test] type dns
# Specify the IP address of the DNS server 10.2.2.2 as the destination address.
[DeviceA-nqa-admin-test-dns] destination ip 10.2.2.2
# Specify the domain name to be translated as host.com.
[DeviceA-nqa-admin-test-dns] resolve-target host.com
[DeviceA-nqa-admin-test-dns] history-record enable
[DeviceA-nqa-admin-test-dns] quit
# Start the DNS operation.
# After the DNS operation runs for a time period, stop the operation.
# Display the most recent result of the DNS operation.
Min/Max/Average round trip time: 62/62/62
Square-Sum of round trip time: 3844
Last succeeded probe time: 2020-03-24 10:49:37.3
Extended results:
# Display the history records of the DNS operation.
1 62 Succeeded 2020-03-24 10:49:37.3
The output shows that it took Device A 62 milliseconds to translate the domain name host.com into an IP address.
Configuration files
type dns
As shown in Figure 5, configure an NQA FTP operation to test the file transmission time between Device A and the FTP server. The login username and password are admin and systemtest, respectively.
When you configure an NQA FTP operation, follow these restrictions and guidelines:
· When you perform the put operation with the filename command configured, make sure the file exists on the NQA client.
· Take the network bandwidth into consideration when you set the file size and the probe timeout.
Procedures
# Create an NQA FTP operation.
[DeviceA-nqa-admin-test] type ftp
# Specify the URL of the FTP server.
[DeviceA-nqa-admin-test-ftp] url ftp://10.2.2.2
# Specify 10.1.1.1 as the source IP address.
[DeviceA-nqa-admin-test-ftp] source ip 10.1.1.1
# Specify the FTP operation type as put.
[DeviceA-nqa-admin-test-ftp] operation put
# Specify the file to be uploaded as config.txt.
[DeviceA-nqa-admin-test-ftp] filename config.txt
# Specify the username for the FTP operation as admin.
[DeviceA-nqa-admin-test-ftp] username admin
# Specify the password for the FTP operation as systemtest.
[DeviceA-nqa-admin-test-ftp] password simple systemtest
[DeviceA-nqa-admin-test-ftp] history-record enable
[DeviceA-nqa-admin-test-ftp] quit
# Start the FTP operation.
# After the FTP operation runs for a time period, stop the operation.
# Display the most recent result of the FTP operation.
Min/Max/Average round trip time: 173/173/173
Square-Sum of round trip time: 29929
Last succeeded probe time: 2020-03-25 10:07:28.6
Extend results:
Failures due to disconnect: 0
Failures due to no connection: 0
# Display the history records of the FTP operation.
1 173 Succeeded 2020-03-25 10:07:28.6
The output shows that it took Device A 173 milliseconds to upload a file to the FTP server.
Configuration files
type ftp
filename config.txt
operation put
password cipher $c$3$BP255atzDilAfIPwfh+RMHqmP5LTiKWpVf/hpBs=
source ip 10.1.1.1
url ftp://10.2.2.2
username admin
As shown in Figure 6, configure an NQA HTTP operation on the NQA client to test the time required to obtain data from the HTTP server.
When you configure an NQA HTTP operation, follow these restrictions and guidelines:
Procedures
# Create an NQA HTTP operation.
[DeviceA-nqa-admin-test] type http
# Specify the URL of the HTTP server.
[DeviceA-nqa-admin-test-http] url http://10.2.2.2/index.htm
[DeviceA-nqa-admin-test-http] history-record enable
[DeviceA-nqa-admin-test-http] quit
# Start the HTTP operation.
# After the HTTP operation runs for a time period, stop the operation.
# Display the most recent result of the HTTP operation.
Min/Max/Average round trip time: 64/64/64
Square-Sum of round trip time: 4096
Last succeeded probe time: 2020-03-25 11:12:47.9
Extend results:
# Display the history records of the HTTP operation.
1 64 Succeeded 2020-03-25 11:12:47.9
The output shows that it took Device A 64 milliseconds to obtain data from the HTTP server.
Configuration files
type http
As shown in Figure 7, configure a UDP jitter operation to test the jitter, delay, and round-trip time between Device A and Device B.
When you configure an NQA UDP jitter operation, follow these restrictions and guidelines:
· Configure Device B as the NQA server before you start the NQA UDP jitter operation.
Procedures
Configuring Device B
# Enable the NQA server.
[DeviceB] nqa server enable
# Configure a listening service to listen on the IP address 10.2.2.2 and UDP port 9000.
[DeviceB] nqa server udp-echo 10.2.2.2 9000
Configuring Device A
# Create a UDP jitter operation.
[DeviceA-nqa-admin-test] type udp-jitter
# Configure 10.2.2.2 as the destination IP address and port 9000 as the destination port.
[DeviceA-nqa-admin-test-udp-jitter] destination ip 10.2.2.2
[DeviceA-nqa-admin-test-udp-jitter] destination port 9000
# Configure the operation to repeat at an interval of 1000 milliseconds.
[DeviceA-nqa-admin-test-udp-jitter] frequency 1000
[DeviceA-nqa-admin-test-udp-jitter] quit
# Start the UDP jitter operation.
# After the UDP jitter operation runs for a time period, stop the operation.
# Display the most recent result of the UDP jitter operation.
Min/Max/Average round trip time: 1/1/1
Square-Sum of round trip time: 10
Last packet received time: 2020-07-30 09:46:36.9
Extended results:
UDP-jitter results:
RTT number: 10
Min positive SD: 1 Min positive DS: 0
Max positive SD: 1 Max positive DS: 0
Positive SD number: 1 Positive DS number: 0
Positive SD sum: 1 Positive DS sum: 0
Positive SD average: 1 Positive DS average: 0
Positive SD square-sum: 1 Positive DS square-sum: 0
Min negative SD: 0 Min negative DS: 0
Max negative SD: 0 Max negative DS: 0
Negative SD number: 0 Negative DS number: 0
Negative SD sum: 0 Negative DS sum: 0
Negative SD average: 0 Negative DS average: 0
Negative SD square-sum: 0 Negative DS square-sum: 0
One way results:
Max SD delay: 0 Max DS delay: 0
Min SD delay: 0 Min DS delay: 0
Number of SD delay: 0 Number of DS delay: 0
Sum of SD delay: 0 Sum of DS delay: 0
Square-Sum of SD delay: 0 Square-Sum of DS delay: 0
SD lost packets: 0 DS lost packets: 0
# Display the statistics of the UDP jitter operation.
NO. : 1
Start time: 2020-07-30 09:46:22.7
Life time: 14 seconds
Send operation times: 150 Receive response times: 150
Min/Max/Average round trip time: 1/4/1
Square-Sum of round trip time: 165
Extended results:
UDP-jitter results:
RTT number: 150
Max positive SD: 6 Max positive DS: 1
Positive SD number: 11 Positive DS number: 5
Positive SD sum: 16 Positive DS sum: 5
Positive SD square-sum: 46 Positive DS square-sum: 5
Min negative SD: 5 Min negative DS: 1
Max negative SD: 5 Max negative DS: 1
Negative SD sum: 5 Negative DS sum: 1
Negative SD average: 5 Negative DS average: 1
Negative SD square-sum: 25 Negative DS square-sum: 1
One way results:
Configuration files
· Device B:
nqa server enable
· Device A:
type udp-jitter
frequency 1000
As shown in Figure 8, configure an SNMP operation to test the time the NQA client uses to get a response from the SNMP agent.
When you configure an NQA SNMP operation, follow these restrictions and guidelines:
· Configure Device B as the SNMP agent before you start the NQA SNMP operation.
Procedures
# Set the SNMP version to all.
[DeviceB] snmp-agent sys-info version all
# Set the read community to public.
[DeviceB] snmp-agent community read public
# Set the write community to private.
[DeviceB] snmp-agent community write private
# Create an SNMP operation.
[DeviceA-nqa-admin-test] type snmp
# Configure 10.2.2.2 as the destination IP address of the SNMP operation.
[DeviceA-nqa-admin-test-snmp] destination ip 10.2.2.2
[DeviceA-nqa-admin-test-snmp] history-record enable
[DeviceA-nqa-admin-test-snmp] quit
# Start the SNMP operation.
# After the SNMP operation runs for a time period, stop the operation.
# Display the most recent result of the SNMP operation.
Last succeeded probe time: 2020-07-30 10:07:28.2
Extended results:
# Display the history records of the SNMP operation.
NQA entry (admin admin, tag test) history record(s):
1 1 Succeeded 2020-07-30 10:07:28.2
Configuration files
· Device B:
snmp-agent
snmp-agent local-engineid 800063A20300E0FC123456
· Device A:
type snmp
As shown in Figure 9, configure a TCP operation to test the time required for Device A and Device B to establish a TCP connection.
When you configure an NQA TCP operation, follow these restrictions and guidelines:
· Configure Device B as the NQA server before you start the NQA TCP operation.
Procedures
# Configure a listening service to listen on the IP address 10.2.2.2 and TCP port 9000.
[DeviceB] nqa server tcp-connect 10.2.2.2 9000
# Create a TCP operation.
[DeviceA-nqa-admin-test] type tcp
[DeviceA-nqa-admin-test-tcp] destination ip 10.2.2.2
[DeviceA-nqa-admin-test-tcp] destination port 9000
[DeviceA-nqa-admin-test-tcp] history-record enable
[DeviceA-nqa-admin-test-tcp] quit
# Start the TCP operation.
# After the TCP operation runs for a time period, stop the operation.
# Display the most recent result of the TCP operation.
Last succeeded probe time: 2020-07-30 10:37:29.5
Extended results:
# Display the history records of the TCP operation.
2 1 Succeeded 2020-07-30 10:37:29.5
1 0 Unknown error 2020-07-30 10:34:55.9
Configuration files
· Device B:
nqa server enable
· Device A:
type tcp
As shown in Figure 10, configure a UDP echo operation to test the round-trip time between Device A and Device B. The destination port number is 8000.
When you configure an NQA UDP echo operation, follow these restrictions and guidelines:
· Configure Device B as the NQA server before you start the NQA UDP echo operation.
Procedures
# Configure a listening service to listen on the IP address 10.2.2.2 and UDP port 8000.
[DeviceB] nqa server udp-echo 10.2.2.2 8000
# Create a UDP echo operation.
[DeviceA-nqa-admin-test] type udp-echo
# Configure 10.2.2.2 as the destination IP address and port 8000 as the destination port.
[DeviceA-nqa-admin-test-udp-echo] destination ip 10.2.2.2
[DeviceA-nqa-admin-test-udp-echo] destination port 8000
[DeviceA-nqa-admin-test-udp-echo] history-record enable
[DeviceA-nqa-admin-test-udp-echo] quit
# Start the UDP echo operation.
# After the UDP echo operation runs for a time period, stop the operation.
# Display the most recent result of the UDP echo operation.
Last succeeded probe time: 2020-07-30 11:10:35.2
Extended results:
# Display the history records of the UDP echo operation.
1 1 Succeeded 2020-07-30 11:10:35.2
Configuration files
· Device B:
nqa server enable
· Device A:
type udp-echo
As shown in Figure 11, configure a UDP tracert operation to determine the routing path from Device A to Device B.
When you configure an NQA UDP tracert operation, follow these restrictions and guidelines:
· Configure Device B as the NQA server before you start the NQA UDP tracert operation.
Procedures
1. Execute the ip ttl-expires enable command on the intermediate devices and execute the ip unreachables enable command on Device B. (Details not shown.)
2. Configure Device A:
# Create a UDP tracert operation.
[DeviceA-nqa-admin-test] type udp-tracert
# Specify 10.2.2.2 as the destination IP address for the operation.
[DeviceA-nqa-admin-test-udp-tracert] destination ip 10.2.2.2
# Set the destination port number to 33434. (This step is optional because it is the default setting.)
[DeviceA-nqa-admin-test-udp-tracert] destination port 33434
# Configure Device A to perform three probes to each hop.
[DeviceA-nqa-admin-test-udp-tracert] probe count 3
# Set the probe timeout time to 500 milliseconds.
[DeviceA-nqa-admin-test-udp-tracert] probe timeout 500
# Configure the UDP tracert operation to repeat every 5000 milliseconds.
[DeviceA-nqa-admin-test-udp-tracert] frequency 5000
# Specify M-GigabitEthernet 0/0/0 as the output interface for the probe packets.
[DeviceA-nqa-admin-test-udp-tracert] out interface m-gigabitethernet0/0/0
# Enable the no-fragmentation feature.
[DeviceA-nqa-admin-test-udp-tracert] no-fragment enable
# Set the maximum number of consecutive probe failures to 6.
[DeviceA-nqa-admin-test-udp-tracert] max-failure 6
# Set the TTL value to 1 for UDP packets in the start round of the UDP tracert operation.
[DeviceA-nqa-admin-test-udp-tracert] init-ttl 1
# Start the UDP tracert operation.
# After the UDP tracert operation runs for a period of time, stop the operation.
# Display the most recent result of the UDP tracert operation.
Send operation times: 6 Receive response times: 6
Last succeeded probe time: 2020-09-09 14:46:06.2
Extended results:
Packet loss in test: 0%
UDP-tracert results:
TTL Hop IP Time
1 3.1.1.1 2020-09-09 14:46:03.2
2 10.2.2.2 2020-09-09 14:46:06.2
# Display the history records of the UDP tracert operation.
Index TTL Response Hop IP Status Time
1 2 2 10.2.2.2 Succeeded 2020-09-09 14:46:06.2
1 2 1 10.2.2.2 Succeeded 2020-09-09 14:46:05.2
1 2 2 10.2.2.2 Succeeded 2020-09-09 14:46:04.2
1 1 1 3.1.1.1 Succeeded 2020-09-09 14:46:03.2
1 1 2 3.1.1.1 Succeeded 2020-09-09 14:46:02.2
1 1 1 3.1.1.1 Succeeded 2020-09-09 14:46:01.2
Configuration files
type udp-tracert
frequency 5000
max-failure 6
no-fragment enable
probe timeout 500
As shown in Figure 12, configure a voice operation to test the jitter, delay, MOS, and ICPIF between Device A and Device B.
When you configure an NQA voice operation, follow these restrictions and guidelines:
· Configure Device B as the NQA server before you start the NQA voice operation.
Procedures
# Configure a listening service to listen on IP address 10.2.2.2 and UDP port 9000.
# Create a voice operation.
[DeviceA-nqa-admin-test] type voice
[DeviceA-nqa-admin-test-voice] destination ip 10.2.2.2
[DeviceA-nqa-admin-test-voice] destination port 9000
[DeviceA-nqa-admin-test-voice] quit
# Start the voice operation.
# After the voice operation runs for a time period, stop the operation.
# Display the most recent result of the voice operation.
Send operation times: 157 Receive response times: 157
Min/Max/Average round trip time: 1/3/1
Last packet received time: 2020-07-30 14:27:52.8
Extended results:
Voice results:
RTT number: 157
Min positive SD: 2 Min positive DS: 1
Max positive SD: 4 Max positive DS: 1
Positive SD number: 2 Positive DS number: 5
Positive SD sum: 6 Positive DS sum: 5
Positive SD average: 3 Positive DS average: 1
Positive SD square-sum: 20 Positive DS square-sum: 5
Min negative SD: 2 Min negative DS: 1
Max negative SD: 4 Max negative DS: 1
Negative SD number: 2 Negative DS number: 6
Negative SD sum: 6 Negative DS sum: 6
Negative SD average: 3 Negative DS average: 1
Negative SD square-sum: 20 Negative DS square-sum: 6
One way results:
Voice scores:
MOS value: 0.00 ICPIF value: 0
# Display the statistics of the voice operation.
NO. : 1
Start time: 2020-07-30 14:30:30.0
Life time: 204 seconds
Send operation times: 4000 Receive response times: 4000
Min/Max/Average round trip time: 1/32/1
Square-Sum of round trip time: 12853
Extended results:
Voice results:
RTT number: 4000
Max positive SD: 32 Max positive DS: 1
Positive SD number: 76 Positive DS number: 72
Positive SD sum: 567 Positive DS sum: 72
Positive SD average: 7 Positive DS average: 1
Positive SD square-sum: 9011 Positive DS square-sum: 72
Max negative SD: 20 Max negative DS: 1
Negative SD number: 87 Negative DS number: 67
Negative SD sum: 569 Negative DS sum: 67
Negative SD average: 7 Negative DS average: 1
Negative SD square-sum: 6715 Negative DS square-sum: 67
One way results:
Voice scores:
Max MOS value: 4.40 Min MOS value: 4.40
Max ICPIF value: 0 Min ICPIF value: 0
Configuration files
· Device B:
nqa server enable
· Device A:
type voice
As shown in Figure 13, configure a DLSw operation to test the response time of the DLSw device.
When you configure an NQA DLSw operation, follow these restrictions and guidelines:
Procedures
# Create a DLSw operation.
[DeviceA-nqa-admin-test] type dlsw
# Configure 10.2.2.2 as the destination IP address.
[DeviceA-nqa-admin-test-dlsw] destination ip 10.2.2.2
[DeviceA-nqa-admin-test-dlsw] history-record enable
[DeviceA-nqa-admin-test-dlsw] quit
# Start the DLSw operation.
# After the DLSw operation runs for a time period, stop the operation.
# Display the most recent result of the DLSw operation.
Min/Max/Average round trip time: 19/19/19
Square-Sum of round trip time: 361
Last succeeded probe time: 2020-07-22 10:40:27.7
Extended results:
# Display the history records of the DLSw operation.
1 19 Succeeded 2020-07-22 10:40:27.7
Configuration files
type dlsw
As shown in Figure 14, configure a path jitter operation to test the round trip time and jitters from Device A to Device B and Device C.
When you configure an NQA path jitter operation, follow these restrictions and guidelines:
Procedures
1. Execute the ip ttl-expires enable command on Device B and execute the ip unreachables enable command on Device C. (Details not shown.)
# Create a path jitter operation.
[DeviceA-nqa-admin-test] type path-jitter
[DeviceA-nqa-admin-test-path-jitter] destination ip 10.2.2.2
# Configure the path jitter operation to repeat every 10000 milliseconds.
[DeviceA-nqa-admin-test-path-jitter] frequency 10000
[DeviceA-nqa-admin-test-path-jitter] quit
# Start the path jitter operation.
# After the path jitter operation runs for a period of time, stop the operation.
# Display the most recent result of the path jitter operation.
Hop IP 10.1.1.2
Basic Results
Min/Max/Average round trip time: 9/21/14
Square-Sum of round trip time: 2419
Extended Results
Path-Jitter Results
Jitter number: 9
Min/Max/Average jitter: 1/10/4
Positive jitter number: 6
Min/Max/Average positive jitter: 1/9/4
Sum/Square-Sum positive jitter: 25/173
Negative jitter number: 3
Min/Max/Average negative jitter: 2/10/6
Sum/Square-Sum positive jitter: 19/153
Hop IP 10.2.2.2
Basic Results
Min/Max/Average round trip time: 15/40/28
Square-Sum of round trip time: 4493
Extended Results
Path-Jitter Results
Jitter number: 9
Configuration files
type path-jitter
frequency 10000
Related documentation
· H3C S12500R Switch Router Series Network Management and Monitoring Command Reference-R3606
· H3C S12500R Switch Router Series Network Management and Monitoring Configuration Guide-R3606
