H3C S12500R Ethernet Switch Router Series Config Examples-6W101
HomeSupportSwitchesS12500R SeriesConfigure & DeployConfiguration ExamplesH3C S12500R Ethernet Switch Router Series Config Examples-6W101
Table of Contents
Related Documents
15-IS-IS Configuration Examples
15-IS-IS Configuration Examples 111.34 KB
H3C S12500R Switch Router Series
Introduction
This document provides IS-IS configuration examples.
This document assumes that you have basic knowledge of IS-IS.
Example: Configuring IS-IS
As shown in Figure 1, the company's headquarters and the branch run IS-IS. The partner runs OSPF.
Configure the switches to meet the following requirements:
·     The marketing department can reach the finance department, the branch, and the partner.
·     The finance department and the branch cannot reach each other, and the branch does not have a route to the finance department.
·     When the IS-IS process on Router C restarts, the communication is not interrupted.
Figure 1 Network diagram
Analysis
To allow communication between the marketing department and the finance department, configure Router A and Router B in Area 10 as Level-1 routers.
To allow communication between the marketing department and the partner, configure route redistribution between IS-IS and OSPF on Router D.
To ensure that the branch does not have a route to the finance department, configure Router C to use a prefix list to advertise only network 10.100.1.0/24 to Level-2.
To ensure that the communication is not interrupted when the IS-IS process on Router C restarts, enable IS-IS Graceful Restart (GR) on Router C.
Software versions used
This configuration example was created and verified on Release 3606.
To avoid blackhole routes, do not change the network topology during the IS-IS GR process.
By default, interfaces on the device are disabled (in ADM or Administratively Down state). To have an interface operate, you must use the undo shutdown command to enable that interface.
Procedures
Configuring Router A
# Configure an IP address for HundredGigE 1/0/1.
[RouterA] interface hundredgige 1/0/1
[RouterA-HundredGigE1/0/1] ip address 192.168.1.1 24
[RouterA-HundredGigE1/0/1] undo shutdown
[RouterA-HundredGigE1/0/1] quit
# Configure IP addresses for other interfaces, as shown in Figure 1. (Details not shown.)
# Configure IS-IS.
[RouterA] isis 1
[RouterA-isis-1] is-level level-1
[RouterA-isis-1] network-entity 10.1921.6800.1001.00
[RouterA-isis-1] quit
[RouterA–HundredGigE1/0/1] isis enable 1
[RouterA–HundredGigE1/0/1] quit
[RouterA] interface hundredgige 1/0/2
[RouterA–HundredGigE1/0/2] isis enable 1
[RouterA–HundredGigE1/0/2] quit
Configuring Router B
# Configure an IP address for VLAN-interface 12.
<RouterB> system-view
[RouterB] interface hundredgige 1/0/1
[RouterB-HundredGigE1/0/1] ip address 192.168.2.1 24
[RouterB-HundredGigE1/0/1] undo shutdown
[RouterB-HundredGigE1/0/1] quit
# Configure IS-IS.
[RouterB] isis 1
[RouterB-isis-1] is-level level-1
[RouterB-isis-1] network-entity 10.1921.6800.2001.00
[RouterB-isis-1] quit
[RouterB–HundredGigE1/0/1] isis enable 1
[RouterB–HundredGigE1/0/1] quit
[RouterB] interface hundredgige 1/0/2
[RouterB–HundredGigE1/0/2] isis enable 1
[RouterB–HundredGigE1/0/2] quit
Configuring Router C
<RouterC> system-view
[RouterC] interface hundredgige 1/0/1
[RouterC-HundredGigE1/0/1] ip address 192.168.1.2 24
[RouterC-HundredGigE1/0/1] undo shutdown
[RouterC-HundredGigE1/0/1] quit
# Configure IS-IS.
[RouterC] isis 1
[RouterC-isis-1] network-entity 10.1921.6801.0001.00
[RouterC-isis-1] quit
[RouterC–HundredGigE1/0/1] isis enable 1
[RouterC–HundredGigE1/0/1] quit
[RouterC] interface hundredgige 1/0/2
[RouterC–HundredGigE1/0/2] isis enable 1
[RouterC–HundredGigE1/0/2] quit
[RouterC] interface hundredgige 1/0/3
[RouterC–HundredGigE1/0/3] isis enable 1
[RouterC–HundredGigE1/0/3] quit
# Configure route leaking from Level-1 to Level-2, and use prefix list 1 to advertise only network 10.100.1.0/24 to Level-2.
[RouterC] ip prefix-list 1 permit 10.100.1.0 24
[RouterC] isis 1
[RouterC] address-family ipv4
[RouterC-isis-1-ipv4] import-route isis level-1 into level-2 filter-policy prefix-list 1
[RouterC-isis-1-ipv4] quit
 # Enable IS-IS GR.
[RouterC-isis-1] graceful-restart
Configuring Router D
[RouterD] isis 1
[RouterD-isis-1] is-level level-2
[RouterD-isis-1] network-entity 20.1921.6802.0001.00
[RouterD-isis-1] quit
[RouterD] interface hundredgige 1/0/1
[RouterD–HundredGigE1/0/1] isis enable 1
[RouterD–HundredGigE1/0/1] quit
[RouterD] interface hundredgige 1/0/2
[RouterD–HundredGigE1/0/2] isis enable 1
[RouterD–HundredGigE1/0/2] quit
# Configure IS-IS.
[RouterD] isis 1
[RouterD-isis-1] network-entity 10.1921.6802.0001.00
[RouterD] interface vlan-interface 10
[RouterD–Vlan-interface10] isis enable 1
[RouterD–Vlan-interface10] quit
[RouterD] interface vlan-interface 20
[RouterD–Vlan-interface20] isis enable 1
[RouterD–Vlan-interface20] quit
# Configure OSPF.
[RouterD] ospf
[RouterD-ospf-1] area 0
[RouterD-ospf-1-area-0.0.0.0] network 192.168.20.0 0.0.0.255
[RouterD-ospf-1-area-0.0.0.0] quit
[RouterD-ospf-1] quit
# Redistribute OSPF and direct routes into IS-IS
[RouterD] isis 1
[RouterD] address-family ipv4
[RouterD-isis-1-ipv4] import-route ospf
[RouterD-isis-1-ipv4] import-route direct
[RouterD-isis-1-ipv4] quit
# Redistribute IS-IS and direct routes into OSPF.
[RouterD] ospf 1
[RouterD-ospf-1] import-route isis 1
[RouterD-ospf-1] import-route direct
Configuring Router E
<RouterE> system-view
[RouterE] interface hundredgige 1/0/1
[RouterE-HundredGigE1/0/1] ip address 192.168.20.2 24
[RouterE-HundredGigE1/0/1] undo shutdown
[RouterE-HundredGigE1/0/1] quit
# Configure OSPF.
[RouterE] ospf
[RouterE-ospf-1] area 0
[RouterE-ospf-1-area-0.0.0.0] network 192.168.20.0 0.0.0.255
[RouterE-ospf-1-area-0.0.0.0] network 10.200.1.0 0.0.0.255
[RouterE-ospf-1-area-0.0.0.0] quit
[RouterE-ospf-1] quit
# Verify that the branch can reach the marketing department, but cannot reach the finance department.
[RouterD] display isis route
                         Level-2 IPv4 Forwarding Table
 IPv4 Destination     IntCost    ExtCost ExitInterface   NextHop         Flags
 192.168.10.0/24      10         NULL    HGE1/0/1          Direct          D/L/-
 192.168.1.0/24       20         NULL    HGE1/0/1          192.168.10.1    R/-/-
 10.100.1.0/24        30         NULL    HGE1/0/1          192.168.10.1    R/-/-
 192.168.2.0/24       20         NULL    HGE1/0/1          192.168.10.1    R/-/-
# Verify that the marketing department can communicate with the partner.
·     Display the IS-IS routing table on Router C.
[RouterC] display isis route
                         Level-1 IPv4 Forwarding Table
 192.168.10.0/24      10         NULL    HGE1/0/3          Direct          D/L/-
 192.168.1.0/24       10         NULL    HGE1/0/1          Direct          D/L/-
 10.100.1.0/24        20         NULL    HGE1/0/1          192.168.1.1     R/L/-
 10.100.2.0/24        20         NULL    HGE1/0/2          192.168.2.1     R/-/-
 192.168.2.0/24       10         NULL    HGE1/0/2          Direct          D/L/-
 10.200.1.0/24        10         0       HGE1/0/3          192.168.10.2    R/-/-
 192.168.20.0/24      10         0       HGE1/0/3          192.168.10.2    R/-/-
·     Ping 10.200.1.1 from Router A.
[RouterA] ping 10.200.1.1
Ping 10.200.1.1 (10.200.1.1): 56 data bytes, press CTRL+C to break
56 bytes from 10.200.1.1: icmp_seq=0 ttl=254 time=1.862 ms
56 bytes from 10.200.1.1: icmp_seq=1 ttl=254 time=2.969 ms
56 bytes from 10.200.1.1: icmp_seq=2 ttl=254 time=1.402 ms
56 bytes from 10.200.1.1: icmp_seq=3 ttl=254 time=1.324 ms
56 bytes from 10.200.1.1: icmp_seq=4 ttl=254 time=1.510 ms
--- Ping statistics for 10.200.1.1 ---
round-trip min/avg/max/std-dev = 1.324/1.813/2.969/0.606 ms
# Verify that the communication is not interrupted when the IS-IS process restarts.
·     Ping Router B from Router A.
[RouterA] ping -c 10000 10.100.2.1
Ping 10.100.2.1 (10.100.2.1): 56 data bytes, press CTRL+C to break
56 bytes from 10.100.2.1: icmp_seq=0 ttl=254 time=1.185 ms
56 bytes from 10.100.2.1: icmp_seq=1 ttl=254 time=1.087 ms
·     Restart the IS-IS process on Router C.
[RouterC] reset isis all graceful-restart
Reset IS-IS process? [Y/N] :y
# Ping Router B from Router A.
56 bytes from 13.13.13.3: icmp_seq=2 ttl=254 time=1.672 ms
56 bytes from 13.13.13.3: icmp_seq=3 ttl=254 time=1.751 ms
56 bytes from 13.13.13.3: icmp_seq=4 ttl=254 time=1.816 ms
56 bytes from 13.13.13.3: icmp_seq=5 ttl=254 time=1.814 ms
# Check the IS-IS GR state on Router C.
[RouterC] display isis graceful-restart status
Restart status: COMPLETE
Restart phase: Finish
SA Bit: supported
                          Level-1 restart information
Total number of interfaces: 3
Number of waiting LSPs: 0
                          Level-2 restart information
Configuration files
·     Router A:
isis 1
 is-level level-1
vlan 11
vlan 100
interface HundredGigE1/0/1
 isis enable 1
interface HundredGigE1/0/2
 ip address 10.100.1.1 255.255.255.0
 isis enable 1
·     Router B:
isis 1
 is-level level-1
vlan 12
vlan 200
 ip address 192.168.2.1 255.255.255.0
 isis enable 1
 ip address 10.100.2.1 255.255.255.0
 isis enable 1
·     Router C:
isis 1
 graceful-restart
 address-family ipv4 unicast
vlan 11 to 13
 ip address 192.168.1.2 255.255.255.0
 isis enable 1
 ip address 192.168.2.2 255.255.255.0
 isis enable 1
interface HundredGigE1/0/3
 ip address 192.168.10.1 255.255.255.0
 isis enable 1
 ip prefix-list 1 index 10 permit 10.100.1.0 24
·     Router D:
isis 1
 is-level level-2
  import-route direct
  import-route ospf 1
ospf 1
 import-route direct
 import-route isis 1
 area 0.0.0.0
vlan 10
vlan 20
 ip address 192.168.10.2 255.255.255.0
 isis enable 1
 ip address 192.168.20.1 255.255.255.0
·     Router E:
ospf 1
 area 0.0.0.0
vlan 20
vlan 300
 ip address 192.168.20.2 255.255.255.0
 ip address 10.200.1.1 255.255.255.0
Related documentation
·     H3C S12500R Switch Router Series Layer 3—IP Routing Command Reference-R3606
·     H3C S12500R Switch Router Series Layer 3—IP Routing Configuration Guide-R3606
