H3C S12500R Ethernet Switch Router Series Config Examples-6W101
HomeSupportSwitchesS12500R SeriesConfigure & DeployConfiguration ExamplesH3C S12500R Ethernet Switch Router Series Config Examples-6W101
Table of Contents
Related Documents
40-NTP Configuration Examples
40-NTP Configuration Examples 274.71 KB
H3C S12500R Switch Router Series
Introduction· 1
Prerequisites· 1
Example: Configuring the NTP client/server mode· 1
Network configuration· 1
Software version used· 1
Restrictions and guidelines· 1
Procedures· 1
Configuring Device A· 1
Configuring Device B· 2
Verifying the configuration· 2
Configuration files· 2
Example: Configuring the NTP broadcast mode· 3
Network configuration· 3
Software version used· 3
Restrictions and guidelines· 4
Procedures· 4
Configuring Router C· 4
Configuring Router A· 4
Configuring Router B· 4
Verifying the configuration· 4
Configuration files· 5
Example: Configuring the NTP multicast mode· 6
Network configuration· 6
Software version used· 6
Restrictions and guidelines· 6
Procedures· 6
Configuring Router C· 6
Configuring Router D·· 7
Configuring Router B· 7
Configuring Router A· 7
Verifying the configuration· 8
Configuration files· 8
Example: Configuring NTP client/server mode with authentication· 9
Network configuration· 9
Software version used· 9
Restrictions and guidelines· 9
Procedures· 9
Configuring Device A· 9
Configuring Device B· 10
Verifying the configuration· 10
Configuration files· 11
Example: Configuring SNTP·· 11
Network configuration· 11
Software version used· 12
Restrictions and guidelines· 12
Procedures· 12
Configuring Device A· 12
Configuring Device B· 12
Verifying the configuration· 12
Configuration files· 12
Example: Configuring the IPv6 NTP client/server mode· 13
Network configuration· 13
Software version used· 13
Restrictions and guidelines· 13
Procedures· 13
Configuring Device A· 13
Configuring Device B· 14
Verifying the configuration· 14
Configuration files· 14
Example: Configuring the IPv6 NTP multicast mode· 15
Network configuration· 15
Software version used· 15
Restrictions and guidelines· 16
Procedures· 16
Configuring Router C· 16
Configuring Router D·· 16
Configuring Router B· 16
Configuring Router A· 17
Verifying the configuration· 17
Configuration files· 17
Example: Configuring the NTP broadcast mode with authentication· 18
Network configuration· 18
Software version used· 19
Restrictions and guidelines· 19
Procedures· 19
Configuring Router C· 19
Configuring Router A· 20
Configuring Router B· 20
Verifying the configuration· 20
Configuration files· 21
Related documentation· 21
Introduction
This document provides NTP configuration examples.
This document is not restricted to specific software or hardware versions.
This document assumes that you have basic knowledge of NTP.
As shown in Figure 1, configure the NTP client/server mode so Device B can be synchronized to Device A.
Figure 1 Network diagram
This configuration example was created and verified on R3606.
By default, interfaces on the device are disabled (in ADM or Administratively Down state). To have an interface operate, you must use the undo shutdown command to enable that interface.
Procedures
# Assign an IP address to HundredGigE 1/0/1.
[DeviceA] interface hundredgige 1/0/1
[DeviceA-HundredGigE1/0/1] ip address 1.0.1.11 24
[DeviceA-HundredGigE1/0/1] quit
# Enable the NTP service.
[DeviceA] ntp-service enable
# Specify the local clock as the reference source, with a stratum level of 2.
[DeviceA] ntp-service refclock-master 2
# Assign an IP address to HundredGigE 1/0/1. (Details not shown.)
[DeviceB] ntp-service enable
# Specify NTP for obtaining the time.
[DeviceB] clock protocol ntp
# Specify Device A as the NTP server of Device B.
[DeviceB] ntp-service unicast-server 1.0.1.11
# Verify that Device B has synchronized to Device A, and the clock stratum level is 3 on Device B and 2 on Device A.
[DeviceB] display ntp-service status
 Clock status: synchronized
 Clock stratum: 3
 System peer: 1.0.1.11
 Local mode: client
 Reference clock ID: 1.0.1.11
 Leap indicator: 00
 NTP version: 4
 Clock jitter: 0.003479 s
 Stability: 0.000 pps
 Clock precision: 2^-18
 Root delay: 1.95313 ms
 Root dispersion: 28.38135 ms
 Reference time: d5ed8cd5.577006ea  Wed, Sep 25 2020 16:24:53.341
# Verify that an IPv4 NTP association has been established between Device B and Device A.
[DeviceB] display ntp-service sessions
        source          reference       stra reach poll  now offset  delay disper
[12345]1.0.1.11        127.127.1.0        2   255   64   38 -10.22 1.9531 3.3416
 Total sessions: 1
Configuration files
·     Device A:
 ip address 1.0.1.11 255.255.255.0
 ntp-service enable
·     Device B:
 ip address 1.0.1.12 255.255.255.0
 ntp-service enable
As shown in Figure 2, configure the NTP broadcast mode so all devices on the same network segment can be synchronized to Router C.
Figure 2 Network diagram
Procedures
<RouterC> system-view
[RouterC] ntp-service enable
[RouterC] ntp-service refclock-master 2
[RouterC] interface hundredgige 1/0/1
[RouterC-HundredGigE1/0/1] ip address 3.0.1.31 24
# Configure Router C to operate in broadcast server mode and send broadcast messages from HundredGigE 1/0/1.
[RouterC-HundredGigE1/0/1] ntp-service broadcast-server
[RouterA] ntp-service enable
[RouterA] interface hundredgige 1/0/1
[RouterA-HundredGigE1/0/1] ip address 3.0.1.30 24
# Configure Router A to operate in broadcast client mode and receive broadcast messages on HundredGigE 1/0/1.
[RouterA-HundredGigE1/0/1] ntp-service broadcast-client
# Configure Router B in the same way Router A is configured. (Details not shown.)
# Verify that each device has synchronized to Router C. Router A is used in this example.
·     Verify that Router A has synchronized to Router C, and the clock stratum level is 3 on Router A and 2 on Router C.
[RouterA-HundredGigE1/0/1] display ntp-service status
 Clock stratum: 3
 System peer: 3.0.1.31
 Local mode: bclient
 Reference clock ID: 3.0.1.31
 Leap indicator: 00
 NTP version: 4
 Clock jitter: 0.044281 s
 Root delay: 0.00229 ms
 Root dispersion: 4.12572 ms
 Reference time: d0d289fe.ec43c720  Sat, Jan  8 2011  7:00:14.922
·     Verify that an IPv4 NTP association has been established between Router A and Router C.
[RouterA-HundredGigE1/0/1] display ntp-service sessions
 [1234]3.0.1.31        127.127.1.0        2   254   64   82 -2.190 0.0000 7937.5
 Total sessions: 1
Configuration files
·     Router C:
 ip address 3.0.1.31 255.255.255.0
 ntp-service enable
·     Router A:
 ip address 3.0.1.33 255.255.255.0
 ntp-service enable
·     Router B:
 ip address 3.0.1.30 255.255.255.0
 ntp-service enable
As shown in Figure 3, configure the NTP multicast mode so all devices on different network segments can be synchronized to Router C.
Figure 3 Network diagram
Procedures
# Configure Router C to operate in multicast server mode and send multicast messages from HundredGigE 1/0/1.
[RouterC-HundredGigE1/0/1] ntp-service multicast-server
<RouterD> system-view
[RouterD] ntp-service enable
[RouterD] interface hundredgige 1/0/1
[RouterD-HundredGigE1/0/1] ip address 3.0.1.32 24
# Configure Router D to operate in multicast client mode and receive multicast messages on HundredGigE 1/0/1.
[RouterD-HundredGigE1/0/1] ntp-service multicast-client
Because Router A and Router C are on different subnets, you must configure multicast settings on Router B for Router A to receive multicast messages from Router C.
# Configure multicast settings.
<RouterB> system-view
[RouterB] multicast routing
[RouterB-mrib] quit
[RouterB] interface hundredgige 1/0/1
[RouterB-HundredGigE1/0/1] igmp enable
[RouterB-HundredGigE1/0/1] igmp static-group 224.0.1.1
[RouterB-HundredGigE1/0/1] quit
[RouterB] interface hundredgige 1/0/2
[RouterB-HundredGigE1/0/2] pim dm
[RouterA] clock protocol ntp
[RouterA-HundredGigE1/0/1] ip address 1.0.1.11 24
# Configure Router A to operate in multicast client mode and receive multicast messages on HundredGigE 1/0/1.
[RouterA-HundredGigE1/0/1] ntp-service multicast-client
 Clock stratum: 3
 Local mode: bclient
 Leap indicator: 00
 NTP version: 4
 Clock jitter: 0.000061 s
 Root delay: 1.69373 ms
 Root dispersion: 1950.18005 ms
 Reference time: d5ee9b15.2f3a684d  Thu, Sep 26 2020 11:37:57.184
Configuration files
·     Router A:
 ntp-service enable
·     Router B:
ntp-service enable
multicast routing
igmp-snooping
 pim dm
 ip address 1.0.1.10 255.255.255.0
 igmp enable
·     Router C:
 ntp-service enable
·     Router D:
 ntp-service enable
 ip address 3.0.1.32 255.255.255.0
As shown in Figure 4, configure the NTP client/server mode so Device B can be synchronized to Device A. Configure NTP authentication to ensure time synchronization security.
Figure 4 Network diagram
Procedures
# Enable NTP authentication on Device A.
[DeviceA] ntp-service authentication enable
# Set an authentication key, and input the key in plain text.
[DeviceA] ntp-service authentication-keyid 42 authentication-mode md5 simple aNiceKey
# Specify the key as a trusted key.
[DeviceA] ntp-service reliable authentication-keyid 42
# Enable NTP authentication on Device B.
[DeviceB] ntp-service authentication enable
[DeviceB] ntp-service authentication-keyid 42 authentication-mode md5 simple aNiceKey
[DeviceB] ntp-service reliable authentication-keyid 42
# Specify Device A as the NTP server of Device B, and associate the server with key 42.
[DeviceB] ntp-service unicast-server 1.0.1.11 authentication-keyid 42
 Clock stratum: 3
 Local mode: client
 Leap indicator: 00
 NTP version: 4
 Clock jitter: 0.005096 s
 Root delay: 0.00655 ms
 Root dispersion: 1.15869 ms
 Reference time: d0c62687.ab1bba7d  Mon, Sep 30 2020 16:06:26.764
 [1245]1.0.1.11        127.127.1.0        2     1   64  519   -0.0 0.0065    0.0
 Total sessions : 1
Configuration files
·     Device A:
 ntp-service enable
 ntp-service authentication-keyid 42 authentication-mode md5 cipher $c$3$4j3SKCgQWBK3Un41B9U0JXzJX9i7IuNoSqi
·     Device B:
 ntp-service enable
 ntp-service authentication-keyid 42 authentication-mode md5 cipher $c$3$22eIc8l796cpudZqiaAZ2SLzIfrgzFTVYn8X
As shown in Figure 5, configure SNTP so that Device B can be synchronized to Device A.
Figure 5 Network diagram
Procedures
# Enable the SNTP service.
[DeviceB] sntp enable
# Specify Device A as the NTP server for Device B.
[DeviceB] sntp unicast-server 1.0.1.11
# Verify that an SNTP association has been established between Device B and Device A, and Device B has synchronized to Device A.
[DeviceB] display sntp sessions
SNTP server     Stratum   Version    Last receive time
1.0.1.11        2         4          Thu, Sep 26 2020 17:25:09.121 (Synced)
Configuration files
·     Device A:
 ntp-service enable
·     Device B:
 sntp enable
As shown in Figure 6, configure the IPv6 NTP client/server mode so Device B can synchronize to Device A, the NTP server.
Figure 6 Network diagram
Procedures
# Assign an IPv6 address to HundredGigE 1/0/1.
[DeviceA-HundredGigE1/0/1] ipv6 address 3000::34 64
# Assign an IPv6 address to HundredGigE 1/0/1. (Details not shown.)
# Specify Device A as the NTP server of Device B so that Device B is synchronized to Device A.
[DeviceB] ntp-service unicast-server 3000::34
 Clock stratum: 3
 System peer: 3000::34
 Local mode: client
 Reference clock ID: 95.197.17.40
 Leap indicator: 00
 NTP version: 4
# Verify that an IPv6 NTP association has been established between Device B and Device A.
[DeviceB] display ntp-service ipv6 sessions
 Source: [12345] 3000::34
 Reference: 127.127.1.0           Clock stratum: 2
 Reachabilities: 3                Poll interval: 64
 Last receive time: 62            Offset: 0.1272
 Roundtrip delay: 1.8158          Dispersion: 188.47
 Total sessions: 1
Configuration files
·     Device A:
 ipv6 address 3000::34/64
 ntp-service enable
·     Device B:
 ipv6 address 3000::35/64
 ntp-service enable
 ntp-service ipv6 unicast-server 3000::34
As shown in Figure 3, configure the IPv6 NTP multicast mode so all devices on different network segments can synchronize to Router C.
Figure 7 Network diagram
Procedures
# Configure routing protocols so that all devices can reach each other. (Details not shown.)
[RouterC-HundredGigE1/0/1] ipv6 address 3000::2 64
# Configure Router C to operate in IPv6 multicast server mode and send multicast messages from HundredGigE 1/0/1.
[RouterC-HundredGigE1/0/1] ntp-service ipv6 multicast-server ff24::1
[RouterC-HundredGigE1/0/1] quit
# Configure routing protocols and assign an IP address to each interface so that all devices can reach each other. (Details not shown.)
# Configure Router D to operate in IPv6 multicast client mode and receive multicast messages on HundredGigE 1/0/1.
[RouterD-HundredGigE1/0/1] ntp-service ipv6 multicast-client ff24::1
[RouterD-HundredGigE1/0/1] quit
Because Router A and Router C are on different subnets, you must enable IPv6 multicast settings on Router B for Router A to receive multicast messages from Router C.
# Enable IPv6 multicast settings.
[RouterB] ipv6 multicast routing
[RouterB-mrib6] quit
[RouterB-HundredGigE1/0/1] mld enable
[RouterB-HundredGigE1/0/1] mld static-group ff24::1
[RouterB-HundredGigE1/0/2] ipv6 pim dm
# Configure Router A to operate in IPv6 multicast client mode and receive multicast messages destined to FF24::1 on HundredGigE 1/0/1.
[RouterA-HundredGigE1/0/1] ntp-service ipv6 multicast-client ff24::1
[RouterA] display ntp-service status
 Clock stratum: 3
 System peer: 3000::2
 Local mode: bclient
 Reference clock ID: 165.84.121.65
 Leap indicator: 00
 NTP version: 4
Configuration files
·     Router A:
 ntp-service enable
 ipv6 address 2000::1/64
·     Router B:
ntp-service enable
 ipv6 address 3000::1/64
 ipv6 pim dm
 ipv6 address 2000::2/64
 mld enable
·     Router C:
 ntp-service enable
 ipv6 address 3000::2/64
·     Router D:
 ntp-service enable
 ipv6 address 3000::3/64
As shown in Figure 4, all devices are on the same network segment 3.0.1.0/24.
·     Configure NTP broadcast mode so all devices can synchronize to Router A.
·     Configure NTP authentication to ensure time synchronization security.
Figure 8 Network diagram
Procedures
[RouterC] clock protocol ntp
# Specify the local clock as the reference source, with a stratum level of 3.
[RouterC] ntp-service refclock-master 3
# Configure Router C to operate in NTP broadcast server mode and send broadcast messages from HundredGigE 1/0/1.
# Enable NTP authentication, and specify an NTP authentication key with ID 88 and value 123456.
[RouterC] ntp-service authentication enable
[RouterC] ntp-service authentication-keyid 88 authentication-mode md5 simple 123456
[RouterC] ntp-service reliable authentication-keyid 88
# Specify authentication key 88 for the NTP broadcast server.
[RouterC-HundredGigE1/0/1] ntp-service broadcast-server authentication-keyid 88
# Enable NTP authentication and specify an NTP authentication key with the same ID and value as that of Router C.
[RouterA] ntp-service authentication enable
[RouterA] ntp-service authentication-keyid 88 authentication-mode md5 simple 123456
[RouterA] ntp-service reliable authentication-keyid 88
# Configure Router A to operate in NTP broadcast client mode and receive NTP broadcast messages on HundredGigE 1/0/1.
[RouterA-HundredGigE1/0/1] ip address 3.0.1.33 24
[RouterA-HundredGigE1/0/1] quit
# Verify that each device has synchronized to Router C. Router B is used in this example.
·     Verify that Router B has synchronized to Router C.
[RouterB-HundredGigE1/0/1] display ntp-service status
 Clock stratum: 4
 Local mode: bclient
 Leap indicator: 00
 NTP version: 4
 Clock jitter: 0.006683 s
 Root delay: 0.00127 ms
 Root dispersion: 2.89877 ms
 Reference time: d0d287a7.3119666f  Sat, Jan  8 2011  6:50:15.191
·     Verify that an IPv4 session has been established between Router B and Router C.
[RouterB-HundredGigE1/0/1] display ntp-service sessions
 [1245]3.0.1.31        127.127.1.0        3     3   64   68   -0.0 0.0000    0.0
 Total sessions: 1
Configuration files
·     Router A and Router B:
 ntp-service enable
 ntp-service authentication-keyid 88 authentication-mode md5 cipher $c$3$pU6KvpS80MadhM2zM
CCSR07HX4qEbJhHvQ==
·     Router C:
 ntp-service enable
 ntp-service authentication-keyid 88 authentication-mode md5 cipher $c$3$iJudDKiqCVO+gOaG53
63/fz4M3dQvHo2Fw==
·     H3C S12500R Switch Router Series Network Management and Monitoring Configuration Guide-R3606
·     H3C S12500R Switch Router Series Network Management and Monitoring Command Reference-R3606
