- 02-WLAN
- 01-AP management configuration
- 02-Radio management configuration
- 03-WLAN access configuration
- 04-WLAN security configuration
- 05-WLAN authentication configuration
- 06-WIPS configuration
- 07-WLAN QoS configuration
- 08-WLAN roaming configuration
- 09-WLAN load balancing configuration
- 10-WLAN radio resource measurement configuration
- 11-Channel scanning configuration
- 12-Band navigation configuration
- 13-WLAN high availability configuration
- 14-802.11r configuration
- 15-Wireless location configuration
- 16-Hotspot 2.0 configuration
- 17-WLAN RRM configuration
- 18-WT configuration
- 19-IoT AP configuration
- 20-CM tunnel configuration
- 21-Cloud connection configuration
- 22-WLAN IP snooping configuration
- 23-WLAN fast forwarding configuration
| 19-IoT AP configuration | 80.14 KB |
Specifying a serial number for a module
Enabling a module for an AP group
Specifying the supported module type
Specifying the supported module type for an AP
Specifying the supported module type for an AP group
Setting the transmit power level for a module
Setting the transmit power level for a module in module view
Setting the transmit power level for a module in AP group's module view
Upgrading the firmware of a module
Configuring automatic module firmware upgrade
Manually upgrading the firmware of a module
Restoring the factory settings for a module
Configuring iBeacon transmission for a BLE module
Configuring iBeacon transmission for a BLE module in module view
Configuring iBeacon transmission for a BLE module in AP group's module view
Displaying and maintaining IoT APs
Configuring IoT APs
NOTE: Support for IoT capability depends on the AP model. |
An Internet of Things (IoT) AP is an AP that can communicate with IoT modules installed on the AP or connected to the AP through network cables.
An IoT AP manages IoT modules and communicates with an IoT server on behalf of the modules. The modules connect things to the Internet for intelligent identification, locating, tracking, monitoring, and management of the things.
You can apply IoT APs in different fields of the IoT by connecting them to the following IoT modules:
· RFID modules—Medical. For example, the IoT APs can provide the following medical services through identifying RFID devices:
¡ Infant protection through identifying mother and infant tags.
¡ Patients' body temperature monitoring through identifying temperature tags.
· BLE modules—Managing iBeacon devices or acting as iBeacon devices. The iBeacon technology is an Apple-developed BLE technology. This technology enables an iBeacon device to broadcast a unique identifier to nearby application software. After receiving the identifier, the application software takes actions according to the identifier to fulfill software functions.
Configuration task list
Tasks at a glance |
(Required.) Specifying a serial number for a module |
(Required.) Enabling a module |
(Required.) Specifying the supported module type |
(Optional.) Setting the transmit power level for a module |
(Optional.) Upgrading the firmware of a module |
(Optional.) Restoring the factory settings for a module |
(Optional.) Restarting a module |
(Optional.) Configuring iBeacon transmission for a BLE module |
You must specify a serial number for a module when the module connects to an IoT AP through network cables. The module can come online on the AP only when the specified serial number is the same as the actual serial number of the module. A module installed on an IoT AP can come online directly no matter whether the configured serial number is the same as the module's serial number or not.
Deleting the serial number or specifying a different serial number than the actual serial number of an online module logs off the module if the module connects to an IoT AP through network cables.
Configuration procedure
Step |
Command |
Remarks |
1. Enter system view. |
system-view |
N/A |
2. Enter AP view. |
wlan ap ap-name [ model model-name ] |
The AP must be an IoT AP. |
3. Enter module view. |
module module-id |
N/A |
4. Specify a serial number for the module. |
serial-number serial-number |
By default, no serial number is specified for a module. |
Enabling a module
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter AP view. |
module module-id |
N/A |
4. Enable the module. |
module enable |
By default, an AP uses the configuration in AP group's module view. |
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter AP group view. |
wlan ap-group group-name |
N/A |
3. Enter AP model view. |
ap-model ap-model |
The AP model must represent an IoT AP. |
4. Enter module view. |
module module-id |
N/A |
5. Enable the module. |
module enable |
By default, a module is disabled. |
For a module to operate correctly, make sure the specified module type is the same as the actual module type of the module.
The following module types are available:
· BLE—H3C-developed modules that support the Bluetooth protocol.
· IoT—IoT modules that are developed by third-party vendors.
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter AP view. |
module module-id |
N/A |
4. Specify the supported module type. |
type { ble | iot } |
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
ap-model ap-model |
module module-id |
N/A |
5. Specify the supported module type. |
By default, no supported module type is specified. |
A module has the following levels of transmit power:
· Level 1 (4 dBm).
· Level 2 (–1 dBm).
· Level 3 (–5 dBm).
· Level 4 (–9 dBm).
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter AP view. |
N/A |
module module-id |
N/A |
4. Set the transmit power level for the module. |
tx-power power |
By default, a module uses the configuration in AP group's module view. |
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
ap-model ap-model |
N/A |
module module-id |
N/A |
5. Set the transmit power level for the module. |
tx-power power |
By default, the transmit power level is 1, which indicates a transmit power of 4 dBm. |
You can use either of the following methods to upgrade the firmware of a module:
· Manual upgrade—Use the specified image file to manually upgrade the module's firmware.
· Automatic upgrade—Configure the automatic firmware upgrade feature to enable the module to immediately upgrade its firmware if its firmware version is different from the version stored in the AP's image file. After you enable this feature for a module, this feature takes effect every time the connected IoT AP restarts.
If you want the module's firmware version to be consistent with the version stored in the AP's image file, use automatic upgrade. In other cases, use manual upgrade.
Configuring automatic module firmware upgrade in module view
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter AP view. |
N/A |
module module-id |
N/A |
4. Configure automatic module firmware upgrade. |
module firmware-upgrade { disable | enable } |
Configuring automatic module firmware upgrade in AP group's module view
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
ap-model ap-model |
N/A |
module module-id |
N/A |
5. Configure automatic module firmware upgrade. |
rfid-tracking ble advertisement { disable | enable } |
By default, automatic module firmware upgrade is disabled for a BLE module. |
When you perform a manual firmware upgrade for a module, follow these restrictions and guidelines:
· Save the module's image file to the AC's local folder.
· Make sure the automatic firmware upgrade feature is disabled for the module. Automatic firmware upgrade performs version consistency check every time the connected IoT AP restarts and upgrades the module's firmware to the version stored in the AP's image file as necessary.
To manually upgrade the firmware of a module:
Step |
Command |
system-view |
2. Manually upgrade the firmware of a module. |
wlan execute module firmware-upgrade { ap ap-name | ap-group group-name ap-model ap-model } module module-id firmware-path filepath |
Step |
Command |
system-view |
2. Restore the factory settings for a module. |
wlan execute module restore-factory ap ap-name module module-id |
Restarting a module
Step |
Command |
system-view |
2. Restart a module. |
wlan execute module reset ap ap-name module module-id |
This feature enables a BLE module to periodically broadcast iBeacon advertisements. An iBeacon advertisement contains a UUID, a Major ID, a Minor ID, and measured power. Application software that receives the iBeacon advertisement will take specific actions according to the advertisement information to fulfill software functions.
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter AP view. |
N/A |
module module-id |
N/A |
4. Configure iBeacon transmission for a BLE module. |
5. Configure the advertisement information. |
rfid-tracking ble advertisement { major-id major-id | measured-power | minor-id minor-id | uuid uuid } |
6. Set the interval for the BLE module to broadcast iBeacon advertisements. |
rfid-tracking ble advertisement interval interval |
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
ap-model ap-model |
N/A |
module module-id |
N/A |
5. Configure iBeacon transmission for a BLE module. |
By default, iBeacon transmission is disabled for a BLE module. |
6. Configure the advertisement information. |
By default, the UUID is 0, Major ID is 1, Minor ID is 1, and measured power is -58 dBm in an iBeacon advertisement. |
7. Set the interval for the BLE module to broadcast iBeacon advertisements. |
By default, a BLE module broadcasts iBeacon advertisements every 100 centiseconds (1 second). |
Task |
Command |
Display firmware upgrade information for modules. |
display wlan module firmware-upgrade history { all | ap ap-name module module-id } |
Display module information for an AP. |
display wlan module-information ap ap-name module module-id |
