02-WLAN
HomeSupportConfigure & DeployConfiguration GuidesH3C Access Controllers Configuration Guides(E5208P03 E5215P01 R5215P01)-6W10202-WLAN
10-WLAN radio resource measurement configuration
Configuring WLAN radio resource measurement
Overview
WLAN radio resource measurement measures channel qualities and radio performance. It enables client and APs to learn the wireless environment and use wireless resources such as spectrum, power, and bandwidth more effectively.
WLAN radio resource measurement includes 802.11h measurement and 802.11k measurement.
802.11h measurement
802.11h measurement measures channels in the 5 GHz band. Table 1 lists the measurement types it supports.
Table 1 802.11h measurement
Spectrum management measurement
Basic
Measures whether a client has detected any of the following:
·     Packets from other BSSs.
·     OFDM preambles.
·     Radar signals.
·     Unknown signals.
Clear Channel Assessment (CCA)
Measures the percentage of busy time for a channel to the total measurement period.
Receive Power Indication (RPI)
Measures the percentage of time for different RPI ranges to the total measurement period.
Transmit Power Control (TPC) measurement
Measures the link redundancy and transmission power for clients.
802.11h measurement operates in the following procedure:
1.     An AP sets the Spectrum Mgmt field to 1 in beacons, probe responses, association responses, or reassociation responses to notify the clients that they can send 802.11h measurement requests.
2.     Upon receiving a measurement request from a client, the AP performs the required measurement and sends a report to the client.
The AP can also send measurement requests periodically to clients and collect measurement reports from clients.
802.11k measurement
802.11k measurement measures channels in both the 2.4 GHz and 5 GHz bands. Table 2 lists the measurement types it supports.
Table 2 802.11k measurement
Radio measurement
Beacon
Measures the Received Channel Power Indicator (RCPI) and Received Signal to Noise Indicator (RSNI) of beacons, measurement pilot packets, and probe responses.
Frame
Measures the number of frames transmitted and the average RCPI for these frames.
Station statistics
Measures the received and transmitted fragment counts, received and transmitted multicast frame counts, failed counts, retry counts, ACK failure counts.
Transmit stream
Measures the frame of a specific transmit stream.
Channel load
Measures the channel usage.
Location
Measures the relative locations of a requester and the requested.
Noise histogram
Measures the distribution of noise in different decibel ranges.
Link measurement
Measures RCPI, RSNI, and link redundancy for a requested link.
Neighbor measurement
Measures the channel and BSSID of neighbor APs.
802.11k measurement operates in the following procedure:
1.     An AP sets the Radio Measurement field to 1 in beacons, probe responses, association responses, or reassociation responses to notify the clients that they can send 802.11k measurement requests.
These frames also carry measurement capabilities of the AP to inform clients of measurement types that the AP supports.
The AP periodically sends Measurement Pilot frames to help clients fast discover the AP. Measurement Pilot frames are sent more frequently than beacons and carry less information.
Configuration task list
Tasks at a glance
(Required.) Enabling radio resource measurement
(Optional.) Setting the measurement duration and interval
(Optional.) Setting the match mode for client radio resource measurement capabilities
Enabling radio resource measurement in radio view
Step
Remarks
N/A
2.     Enter AP view.
wlan ap ap-name [ model model-name ]
N/A
3.     Enter radio view.
radio radio-id
N/A
4.     Enable radio resource measurement.
resource-measure enable
By default, the configuration in AP group view is used.
You must enable radio resource measurement if you enable link, neighbor, or radio measurement.
5.     Enable spectrum management.
spectrum-management enable
Spectrum or TPC measurement takes effect only after you enable spectrum management.
For more information about this command, see WLAN Command Reference.
6.     Enable a measurement type.
measure { all | link | neighbor | radio | spectrum | tpc } { enable | disable }
The spectrum and tpc keywords are available only on 5GHz radios.
Enabling radio resource measurement in AP group radio view
Step
Remarks
N/A
2.     Enter AP group view.
wlan ap-group group-name
N/A
3.     Enter AP model view.
ap-model ap-model
N/A
4.     Enter AP group radio view.
radio radio-id
N/A
5.     Enable radio resource measurement.
By default, radio resource measurement is disabled.
6.     Enable spectrum management.
By default, spectrum management is disabled.
7.     Enable a measurement type.
By default, measurement is disabled.
When radio resource measurement is enabled for an AP, the AP sends measurement requests that carry the measurement duration to clients at the specified interval.
Setting the measurement duration and interval in radio view
Step
Remarks
N/A
2.     Enter AP view.
N/A
radio radio-id
N/A
4.     Set the measurement duration.
measure-duration time
5.     Set the measurement interval.
measure-interval value
Setting the measurement duration and interval in AP group radio view
Step
Remarks
N/A
N/A
ap-model ap-model
N/A
radio radio-id
N/A
5.     Set the measurement duration.
By default, the measurement duration is 500 TUs.
6.     Set the measurement interval.
By default, the measurement interval is 30 seconds.
This feature allows a client to associate with an AP based on the predefined match criteria. Radio resource measurement capability refers to the radio resource measurement types supported by the AP and client. The device supports the following match modes for client radio resource measurement capabilities:
·     All—A client is allowed to associate with an AP only when all its radio resource measurement capabilities match the AP's radio resource measurement capabilities.
·     None—Client radio resource measurement capabilities are not checked.
·     Partial—A client is allowed to associate with an AP as long as one of its radio resource measurement capabilities matches any of the AP's radio resource measurement capabilities.
Setting the match mode for client radio resource measurement capabilities in radio view
Step
Remarks
N/A
2.     Enter AP view.
N/A
radio radio-id
N/A
4.     Set the match mode for client radio resource measurement capabilities.
rm-capability mode { all | none | partial }
Setting the match mode for client radio resource measurement capabilities in AP group radio view
Step
Remarks
N/A
N/A
ap-model ap-model
N/A
radio radio-id
N/A
5.     Set the match mode for client radio resource measurement capabilities.
By default, an AP does not check the radio resource measurement capabilities of a client.
Displaying and maintaining WLAN radio resource measurement
Display client measurement reports.
display wlan measure-report ap ap-name radio radio-id [ client mac-address mac-address ]
Radio resource measurement configuration examples
Network requirements
As shown in Figure 1, configure radio resource measurement to meet the following requirements:
·     The client can come online only when all its radio resource measurement capabilities match the AP's.
·     The client can perform all types of measurements.
Figure 1 Network diagram
Configuration procedures
# Create service template 1.
<AC> system-view
[AC] wlan service-template 1
# Set the SSID to resource-measure, and enable service template 1.
[AC-wlan-st-1] ssid resource-measure
[AC-wlan-st-1] quit
# Create the manual AP ap1, and specify the AP model and serial ID.
[AC] wlan ap ap1 model WA4320i-ACN
[AC-wlan-ap-ap1] serial-id 219801A0CNC138011454
# Enter radio view of radio 1.
[AC-wlan-ap-ap1] radio 1
# Enable spectrum management.
[AC-wlan-ap-ap1-radio-1] spectrum-management enable
# Enable radio resource measurement.
[AC-wlan-ap-ap1-radio-1] resource-measure enable
# Enable all measurement features.
[AC-wlan-ap-ap1-radio-1] measure all enable
# Set the match mode for client radio resource measurement capabilities to All.
[AC-wlan-ap-ap1-radio-1] rm-capability mode all
# Bind the service template to radio 1, and enable the radio.
[AC-wlan-ap-ap1-radio-1] service-template 1
[AC-wlan-ap-ap1-radio-1] quit
[AC-wlan-ap-ap1] quit
# Verify that the client has come online.
[AC] display wlan client
Total number of clients: 1
MAC address       Username   AP name    RID  IP address          VLAN ID
00ee-bd44-557f      N/A      ap1        1    1.1.1.1             1
# Display measurement reports from the client.
[AC] display wlan measure-report ap ap1 radio 1
Client MAC address                              : 00ee-bd44-557f
Link measurement:
  Link margin                                   : 2 dBm
  RCPI                                          : -85 dBm
  RSNI                                          : 53 dBm
Noise histogram:
  Antenna ID                                    : 3
  ANPI                                          : -56 dBm
  IPI0 to IPI10 density                         : 5 12 16 13 8 5 5 15 17 1 3
Spectrum measurement:
  Transmit power                                : 20 dBm
  BSS                                           : Detected
  OFDM preamble                                 : Detected
  Radar                                         : Detected
  Unidentified signal                           : Undetected
  CCA busy fraction                             : 60
  RPI0 to RPI7 density                          : 3 7 11 19 15 23 15 7
Frame report entry:
  BSSID                                         : a072-2351-e253
  PHY type                                      : fhss
  Average RCPI                                  : -10 dBm
  Last RSNI                                     : 2 dBm
  Last RCPI                                     : -20 dBm
  Frames                                        : 1
Dot11BSSAverageAccessDelay group:
  Average access delay                          : 32 ms
  BestEffort average access delay               : 1 ms
  Background average access delay               : 1 ms
  Video average access delay                    : 1 ms
  Voice average access delay                    : 1 ms
  Clients                                       : 32
  Channel utilization rate                      : 11
Transmit stream:
  Traffic ID                                    : 0
  Sent MSDUs                                    : 60
  Discarded MSDUs                               : 5
  Failed MSDUs                                  : 3
  MSDUs resent multiple times                   : 3
  Lost QoS CF-Polls                             : 2
  Average queue delay                           : 2 ms
  Average transmit delay                        : 1 ms
  Bin0 range                                    : 0 to 10 ms
  Bin0 to Bin5                                  : 5 10 10 5 10 10
