02-WLAN
HomeSupportConfigure & DeployConfiguration GuidesH3C Access Controllers Configuration Guides(E5208P03 E5215P01 R5215P01)-6W10202-WLAN
15-Wireless location configuration
15-Wireless location configuration 154.18 KB
Configuring wireless location
Overview
Wireless location tracks 802.11 devices for medical monitoring, asset management, and logistics management.
Wireless location system
As shown in Figure 1, a wireless location system contains 802.11 devices, information receivers (802.11 APs), and a location server. 802.11 devices include Tags (small wireless devices that can only send 802.11 packets periodically) and MUs (all 802.11 devices except Tags).
Figure 1 Wireless location system
Wireless location mechanism
Wireless location operates as follows:
1.     The 802.11 device sends a wireless packet.
2.     Upon receiving the wireless packet, the APs encapsulate the collected location information (including RSSI and timestamp) in location packets, and then send the packets to the location server.
3.     The location server calculates the location of the 802.11 device.
A location server needs location information from a minimum of three APs to locate an 802.11 device.
Configuration task list
Tasks at a glance
(Required.) Enabling RF fingerprinting
(Required.) Enabling radio-based location
(Required.) Specifying an IPv4 address and a port number for the location server
(Required.) Specifying a port to listen for messages from the location server
(Required.) Specifying a multicast MAC address for Tags
(Required.) Specifying the type of devices to locate
(Optional.) Configuring raw frame reporting
(Optional.) Configuring MU information reporting
(Optional.) Specifying the location packet format
(Optional.) Specifying the report mode for location packets
(Optional.) Configuring packet dilution
(Optional.) Enabling ignoring beacon frames
(Optional.) Enabling ignoring AP frames
(Optional.) Configuring RSSI-based packet filtering
(Optional.) Configuring client packet rate limiting
(Optional.) Configuring location packet rate limiting
(Optional.) Configuring wireless location keepalive
Configuring WLAN location
For an AP to send location packets to the location server, you must enable both RF fingerprinting and radio-based location.
Enabling RF fingerprinting in AP view
Step
Remarks
N/A
1.     Enter AP view.
wlan ap ap-name [ model model-name ]
N/A
2.     Enable RF fingerprinting.
rfid-tracking fingerprint enable
By default, an AP uses the configuration in AP group view. If no setting is configured in AP group view, the AP uses the configuration in global configuration view.
Enabling RF fingerprinting in AP group view
Step
Remarks
N/A
2.     Enter AP group view.
wlan ap-group group-name
N/A
3.     Enable RF fingerprinting.
By default, an AP uses the configuration in global configuration view.
Enabling RF fingerprinting in global configuration view
Step
Remarks
N/A
2.     Enter global configuration view.
wlan global-configuration
N/A
By default, RF fingerprinting is disabled.
Enabling radio-based location in radio view
Step
Remarks
N/A
2.     Enter AP view.
N/A
3.     Enter radio view.
radio radio-id
N/A
4.     Enable radio-based location.
rfid-tracking radio enable
By default, an AP uses the configuration in AP group radio view.
Enabling radio-based location in AP group radio view
Step
Remarks
N/A
N/A
3.     Enter AP model view.
ap-model ap-model
N/A
4.     Enter radio view.
radio radio-id
N/A
5.     Enable radio-based location.
By default, radio-based location is disabled.
APs send location packets to the specified IPv4 address and port number for communicating with the location server.
Specifying an IPv4 address and a port number for the location server in AP view
Step
Remarks
N/A
2.     Enter AP view.
N/A
3.     Specify an IPv4 address and a port number for the location server.
rfid-tracking fingerprint engine-address engine-address engine-port engine-port
Specifying an IPv4 address and a port number for the location server in AP group view
Step
Remarks
N/A
N/A
Specifying an IPv4 address and a port number for the location server in global configuration view
Step
Remarks
N/A
N/A
By default, no IPv4 address and port number are specified for the location server.
Perform this task for an AP to communicate with the location server.
Specifying a port to listen for messages from the location server in AP view
Step
Remarks
N/A
2.     Enter AP view.
N/A
3.     Specify a port to listen for messages from the location server.
rfid-tracking fingerprint vendor-port vendor-port-number
Specifying a port to listen for messages from the location server in AP group view
Step
Remarks
N/A
N/A
Specifying a port to listen for messages from the location server in global configuration view
Step
Remarks
N/A
N/A
By default, the port to listen is port 1144.
If you do not specify a multicast MAC address for Tags, an AP determines that all received 802.11 packets are from MUs.
Specifying a multicast MAC address for Tags in AP view
Step
Remarks
N/A
2.     Enter AP view.
N/A
3.     Specify a multicast MAC address for Tags.
rfid-tracking fingerprint tag-multicast-address mac-address
Specifying a multicast MAC address for Tags in AP group view
Step
Remarks
N/A
N/A
Specifying a multicast MAC address for Tags in global configuration view
Step
Remarks
N/A
N/A
By default, no multicast MAC address is specified for Tags.
This feature enables an AP to send location information about only the specified type of devices to the location server.
Specifying the type of devices to locate in radio view
Step
Remarks
N/A
2.     Enter AP view.
N/A
radio radio-id
N/A
4.     Specify the type of devices to locate.
rfid-tracking mode { mu | tag } *
Specifying the type of devices to locate in AP group radio view
Step
Remarks
N/A
N/A
ap-model ap-model
N/A
radio radio-id
N/A
5.     Specify the type of devices to locate.
By default, the type of devices to locate is not specified.
This feature enables an AP to encapsulate both the raw frames and the location information obtained from the frames in location packets.
Configuring raw frame reporting in AP view
Step
Remarks
N/A
2.     Enter AP view.
N/A
3.     Configure raw frame reporting.
rfid-tracking fingerprint raw-frame-report { disable | enable }
Configuring raw frame reporting in AP group view
Step
Remarks
N/A
N/A
Configuring raw frame reporting in global configuration view
Step
Remarks
N/A
N/A
By default, raw frame reporting is disabled.
This feature enables an AP to encapsulate MU information, including the IP address and the transmit rate of an MU in location packets.
Configuring MU information reporting in AP view
Step
Remarks
N/A
2.     Enter AP view.
N/A
3.     Configure MU information reporting.
rfid-tracking fingerprint mu-report { disable | enable }
Configuring MU information reporting in AP group view
Step
Remarks
N/A
N/A
Configuring MU information reporting in global configuration view
Step
Remarks
N/A
N/A
By default, MU information reporting is disabled.
RF fingerprinting supports the following location packet formats:
·     CUPID-hybrid—An AP encapsulates only clients' MAC addresses and RSSIs in location packets.
·     General—This format is applicable to most scenarios. Most third-party location servers support only the general format.
·     Lightweight—An AP encapsulates location information for several clients in one lightweight location packet to save bandwidth. This format is applicable to traffic-sensitive scenarios.
Specifying the location packet format in AP view
Step
Remarks
N/A
2.     Enter AP view.
N/A
3.     Specify the location packet format.
rfid-tracking fingerprint report-format { cupid-hybrid | general | light-weight }
Specifying the location packet format in AP group view
Step
Remarks
N/A
N/A
Specifying the location packet format in global configuration view
Step
Remarks
N/A
N/A
By default, an AP sends location packets in general format.
Both the AC (centralized report) and APs (local report) can report location packets to the location server. In centralized report mode, APs need to send location packets to the AC first.
Specifying the report mode for location packets in AP view
Step
Remarks
N/A
2.     Enter AP view.
N/A
3.     Specify the report mode for location packets.
rfid-tracking fingerprint report-mode { central | local }
Specifying the report mode for location packets in AP group view
Step
Remarks
N/A
N/A
Specifying the report mode for location packets in global configuration view
Step
Remarks
N/A
N/A
By default, the local report mode is used.
This feature takes effect only on MU clients.
If the dilution factor is 10 and the timeout timer is 5 seconds, the AP sends a location packet every time it receives 10 wireless packets, excluding management and broadcast packets, from an MU. If the AP fails to receive 10 packets from an MU client within the timeout timer, it sends the most recent wireless packet to the location server.
Configuring packet dilution in AP view
Step
Remarks
N/A
2.     Enter AP view.
N/A
3.     Enable packet dilution.
rfid-tracking dilution enable
4.     Set the dilution factor and dilution timeout timer.
rfid-tracking dilution factor factor timeout timeout
Configuring packet dilution in AP group view
Step
Remarks
N/A
N/A
Configuring packet dilution in global configuration view
Step
Remarks
N/A
N/A
By default, packet dilution is disabled.
By default, the dilution factor and dilution timeout timer are not configured.
This feature disables an AP from reporting the location information in beacon frames to the location server to prevent traffic flood caused by location packets.
Enabling ignoring beacon frames in AP view
Step
Remarks
N/A
2.     Enter AP view.
N/A
3.     Enable the AP to ignore beacon frames.
rfid-tracking ignore beacon enable
Enabling ignoring beacon frames in AP group view
Step
Remarks
N/A
N/A
3.     Enable APs in the AP group to ignore beacon frames.
Enabling ignoring beacon frames in global configuration view
Step
Remarks
N/A
N/A
3.     Enable APs to ignore beacon frames.
By default, beacon frames are not ignored.
AP frames are frames that an AP received from other APs. Configure this feature if you do not need to locate or monitor APs.
Enabling ignoring AP frames in AP view
Step
Remarks
N/A
2.     Enter AP view.
N/A
3.     Enable the AP to ignore AP frames.
rfid-tracking ignore ap-frame enable
Enabling ignoring AP frames in AP group view
Step
Remarks
N/A
N/A
3.     Enable APs in the AP group to ignore AP frames.
Enabling ignoring AP frames in global configuration view
Step
Remarks
N/A
N/A
3.     Enable APs to ignore AP frames.
By default, AP frames are not ignored.
When RSSI-based packet filtering is enabled, an AP does not report location information in packets with an RSSI lower than the RSSI threshold. This feature enables an AP to not locate clients far away from the AP.
Configuring RSSI-based packet filtering in AP view
Step
Remarks
N/A
2.     Enter AP view.
N/A
3.     Enable RSSI-based packet filtering.
rfid-tracking rssi enable
4.     Set the RSSI threshold.
rfid-tracking rssi threshold rssi-threshold
Configuring RSSI-based packet filtering in AP group view
Step
Remarks
N/A
N/A
Configuring RSSI-based packet filtering in global configuration view
Step
Remarks
N/A
N/A
By default, RSSI-based packet filtering is disabled.
By default, the RSSI threshold is 5 (–123 dBm).
If packet dilution is enabled, this feature limits the rate for diluted packets.
This feature enables an AP to not report location information from excessive client packets when both the CIR and CBS are exceeded. This practice ensures that the location information for each client can be sent to the location server and prevents client packets from flooding the AP.
Configuring client packet rate limiting in AP view
Step
Remarks
N/A
2.     Enter AP view.
N/A
3.     Enable client packet rate limiting.
rfid-tracking client rate-limit enable
4.     Set the CIR and CBS for client packets.
rfid-tracking client rate-limit cir cir [ cbs cbs ]
Configuring client packet rate limiting in AP group view
Step
Remarks
N/A
N/A
Configuring client packet rate limiting in global configuration view
Step
Remarks
N/A
N/A
By default, client packet rate limiting is disabled.
By default, the CIR and CBS for client packets are 0.
This feature enables an AP to discard excessive location packets when both the CIR and CBS are exceeded. This practice prevents location packets from flooding the location server.
Configuring location packet rate limiting in AP view
Step
Remarks
N/A
2.     Enter AP view.
N/A
3.     Enable location packet rate limiting.
rfid-tracking rate-limit enable
4.     Set the CIR and CBS for location packets.
rfid-tracking rate-limit cir cir [ cbs cbs ]
Configuring location packet rate limiting in AP group view
Step
Remarks
N/A
N/A
Configuring location packet rate limiting in global configuration view
Step
Remarks
N/A
N/A
By default, location packet rate limiting is disabled.
By default, the CIR and CBS for location packets are 0.
This feature enables an AP to send Hello packets to the location server at an interval of 15 seconds. If the location server does not receive any packets from an AP within 30 seconds, the location server determines that the AP is offline.
Disable this feature to avoid bandwidth waste if the location server cannot process Hello packets.
Configuring wireless location keepalive in AP view
Step
Remarks
N/A
2.     Enter AP view.
N/A
3.     Configure wireless location keepalive.
rfid-tracking keepalive { disable | enable }
Configuring wireless location keepalive in AP group view
Step
Remarks
N/A
N/A
Configuring wireless location keepalive in global configuration view
Step
Remarks
N/A
N/A
By default, wireless location keepalive is disabled.
Displaying and maintaining wireless location
Display radio information for WLAN location.
display wlan rfid-tracking radio [ ap apname ]
Wireless location configuration example
Network requirements
As shown in Figure 2, configure RF fingerprinting for AP 1, AP 2, and AP 3 to locate the MUs.
Figure 2 Network diagram
Configuration procedure
1.     Configure AP 1:
# Create manual AP ap1, and specify the AP model and serial ID.
<AC> system-view
[AC] wlan ap ap1 model WA4320i-ACN
[AC-wlan-ap-ap1] serial-id 210235A29G007C000020
[AC-wlan-ap-ap1] quit
# Enable RF fingerprinting.
[AC-wlan-ap-ap1] rfid-tracking fingerprint enable
# Specify an IPv4 address and a port number for the location server.
[AC-wlan-ap-ap1] rfid-tracking fingerprint engine-address 192.168.10.10 engine-port 1145
# Specify a port to listen for messages from the location server.
[AC-wlan-ap-ap1] rfid-tracking fingerprint vendor-port 3000
# Enable radio-based location.
[AC-wlan-ap-ap1] radio 1
[AC-wlan-ap-ap1-radio-1] rfid-tracking radio enable
# Specify the type of devices to locate as MU.
[AC-wlan-ap-ap1-radio-1] rfid-tracking mode mu
# Enable radio 1 of AP 1.
[AC-wlan-ap-ap1-radio-1] quit
[AC] quit
2.     Configure AP 2 and AP 3 in the same way AP 1 is configured.
# Verify that RF fingerprinting is enabled and the type of devices to locate is MU for each AP.
<AC> display wlan rfid-tracking radio
                                 Wireless Locating
 AP                                 Radio   Type
 ap1                                1       MU
 ap2                                1       MU
 ap3                                1       MU
# Verify that you can view location information for the MUs by maps, forms, or reports provided by the graphics software. (Details not shown.)
