02-WLAN
HomeSupportConfigure & DeployConfiguration GuidesH3C Access Controllers Configuration Guides(E5208P03 E5215P01 R5215P01)-6W10202-WLAN
20-CM tunnel configuration
20-CM tunnel configuration 73.28 KB
Configuring CM tunnels
Overview
A cloud management tunnel (CM tunnel) is a management tunnel established between a local device and the H3C Oasis server. It enables you to manage the local device from the H3C Oasis server without accessing the network where the device resides.
CM tunnel establishment
This section uses an AC and the H3C Oasis server as an example. The CM tunnel is established as follows:
1.     The AC sends a registration request to the H3C Oasis server.
2.     The H3C Oasis server sends a registration success packet to the AC.
The H3C Oasis server sends a registration success packet to the AC only if the serial number of the AC has been added to the H3C Oasis server.
If the serial number of the AC has not been added to the H3C Oasis server, the H3C Oasis server sends a registration failure packet to the AC. After receiving the registration failure packet, the AC starts the re-establishment timer and requests to re-establish the CM tunnel when the timer expires.
3.     The AC sends a CM tunnel request to the H3C Oasis server.
4.     The H3C Oasis server sends a CM tunnel response to the AC.
5.     The AC uses the CM tunnel interface to establish a CM tunnel with the H3C Oasis server.
Figure 1 CM tunnel establishment
Configuring a CM tunnel
For a successful CM tunnel establishment, add the serial number of the device to be managed to the H3C Oasis server.
To configure a CM tunnel:
Step
Remarks
N/A
2.     Configure the domain name of the H3C Oasis server.
cmtunnel server domain domain-name
By default, the domain name of the H3C Oasis server is not configured.
Displaying and maintaining CM tunnels
Display CM tunnel state information.
display cmtunnel state
CM tunnel configuration example
Network requirements
As shown in Figure 2, configure the AC to establish a CM tunnel with the H3C Oasis server.
Figure 2 Network diagram
Configuration procedure
1.     Configure IP addresses for interfaces as shown in Figure 2, and configure a routing protocol to make sure the devices can reach each other. (Details not shown.)
2.     Log in to the H3C Oasis server to add the serial number of the AC to the server. (Details not shown.)
3.     Configure the domain name of the H3C Oasis server as lvzhou.h3c.com.
<AC> system-view
[AC] cmtunnel server domain-name lvzhou.h3c.com
The DNS service is provided by the ISP DNS server.
# Verify that the AC and the H3C Oasis server have established a CM tunnel.
[AC] display cmtunnel state
Server address     : 10.1.1.1
Server name        : lvzhou.h3c.com
Local port         : 80
Connection state   : Established
Device state       : Request_success
