02-WLAN
HomeSupportConfigure & DeployConfiguration GuidesH3C Access Controllers Configuration Guides(E5208P03 E5215P01 R5215P01)-6W10202-WLAN
23-WLAN fast forwarding configuration
23-WLAN fast forwarding configuration 33.80 KB
Configuring WLAN fast forwarding
Overview
WLAN fast forwarding uses both software and hardware to enhance forwarding performance. Software fast forwarding enables the AC to perform concurrent forwarding by using the multi-core CPU and the 5-tuple table. The AC learns the source IP, source port, destination IP, destination port, and protocol during forwarding and uses high-speed buffer technology to save the information in the 5-tuple table.
In hardware fast forwarding, the AC performs software fast forwarding and uses the embedded FPGA chip to perform line-speed forwarding.
Feature and hardware compatibility
Hardware series
Model
Software fast forwarding compatibility
Hardware fast forwarding compatibility
WX1800H series
WX1804H
WX1810H
WX1820H
No
No
WX2500H series
WX2510H
WX2540H
WX2560H
No
No
WX3000H series
WX3010H
WX3010H-X
WX3024H
Yes
No
WX3010H-L
WX3024H-L
No
No
WX3500H series
WX3508H
WX3510H
WX3520H
WX3540H
Yes
No
WX5500E series
WX5510E
Yes
No
WX5540E
Yes
Yes
WX5500H series
WX5540H
WX5560H
WX5580H
Yes
Yes
Access controller modules
EWPXM1MAC0F
EWPXM1WCME0
EWPXM2WCMD0F
LSQM1WCMX20
LSQM1WCMX40
LSUM1WCME0
LSUM1WCMX20RT
LSUM1WCMX40RT
Yes
Yes
Step
Remarks
N/A
2.     Enable WLAN fast forwarding.
wlan fast-forwarding enable
By default, WLAN fast forwarding is enabled.
3.     Specify the fast forwarding mode.
wlan fast-forwarding mode { hardware | hardware-lite | software }
By default, the fast forwarding mode is software.
Support for the fast forwarding modes varies by device model. For more information, see WLAN Command Reference.
4.     Disable hardware fast forwarding.
wlan fast-forwarding hardware disable
By default, hardware fast forwarding is enabled.
Support for hardware fast forwarding varies by device model. For more information, see WLAN Command Reference.
Displaying and maintaining WLAN fast forwarding
Display WLAN fast forwarding status.
display wlan fast-forwarding status
