- 05-Web configuration examples (AC+fit AP)
- 01-Telnet Access Control Configuration Example
- 02-IPv6 Telnet Access Control Configuration Example
- 03-Web Access Control Configuration Example
- 04-User Role Assignment for Local Web Authentication Users Configuration Example
- 05-SSH Local Authentication Configuration Example
- 06-SSH User Remote Password Authentication Configuration Example
- 07-IPv6 SSH User Remote Password Authentication Configuration Example
- 08-Password Control Configuration Example
- 09-Licensing Configuration Example
- 10-Automatic License Installation Configuration Example
- 11-Layer 2 Static Link Aggregation Configuration Example
- 12-Layer 2 Dynamic Link Aggregation Configuration Example
- 13-PPPoE Client Configuration Example
- 14-Static IPv6 Address Configuration Example
- 15-IPv6 Static Routing Configuration Example
- 16-Static IPv4 DNS Configuration Example
- 17-Static IPv6 DNS Configuration Example
- 18-IGMP Snooping Configuration Example
- 19-MLD Snooping Configuration Example
- 20-IPv4 DNS Proxy Configuration Example
- 21-IPv6 DNS Proxy Configuration Example
- 22-Static NAT Configuration Example
- 23-Dynamic NAT Configuration Example
- 24-IPv4 ACL-Based Packet Filter Configuration Example
- 25-IPv6 ACL-Based Packet Filter Configuration Example
- 26-ARP Attack Protection Configuration Example
- 27-ARP Proxy Configuration Example
- 28-Dynamic IPv4 DNS Configuration Example
- 29-Dynamic IPv6 DNS Configuration Example
- 30-WLAN Access Configuration Example
- 31-Different Wireless Services on Different Radios Configuration Example
- 32-CAPWAP Tunnel Establishment Through DHCP Configuration Example
- 33-CAPWAP Tunnel Establishment Through DHCPv6 Configuration Example
- 34-CAPWAP Tunnel Establishment Through DNS Configuration Example
- 35-CAPWAP Tunnel Establishment Through DNSv6 Configuration Example
- 36-Auto AP Configuration Example
- 37-AP Group Configuration Example
- 38-Radio Management Configuration Example
- 39-Load Balancing Group-Based Session-Mode Load Balancing Configuration Example
- 40-Radio-Based Session-Mode Load Balancing Configuration Example
- 41-A-MPDU and A-MSDU Configuration Example
- 42-Device Classification and Countermeasure Configuration Example
- 43-Malformed Packet Detection and Flood Attack Detection Configuration Example
- 44-Signature-Based Attack Detection Configuration Example
- 45-802.1X RADIUS-Based AAA Configuration Example
- 46-VLAN Interface-Based Direct Portal Authentication Configuration Example
- 47-Service Template-Based Direct Portal Authentication Configuration Example
- 48-Wireless Spectrum Analysis Configuration Example
- 49-Auto DFS Configuration Examples
- 50-Auto TPC Configuration Examples
- 51-Whitelist-Based Client Access Control Configuration Example
- 52-Blacklist-Based Client Access Control Configuration Example
- 53-CAC Configuration Example
- 54-WLAN Probe Configuration Example
- 55-Intra-AC Roaming Configuration Example
- 56-Bonjour Gateway Configuration Example
- 57-IPv4 Multicast Optimization Configuration Examples
- 58-IPv6 Multicast Optimization Configuration Examples
- 59-Ping Configuration Example
- 60-Local Packet Capture Configuration Example
- 61-Remote Packet Capture Configuration Example
| 59-Ping Configuration Example | 167.06 KB |
H3C Access Controllers |
Comware 7 Ping Configuration Example |
Copyright © 2022 New H3C Technologies Co., Ltd. All rights reserved.
Example: Using the ping utility
Pinging AC2 by its IPv4 address or hostname
Pinging AC2 by its IPv6 address or hostname
Overview
The following information provides an example for using the ping utility to determine if an address is reachable.
The following information applies to Comware 7-based access controllers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the H3C access controllers.
The following information is provided based on the assumption that you have basic knowledge of ping.
As shown in Figure 1, use the ping utility to determine if AC1 can reach AC2.
You can ping AC2 from AC1 by AC2's IPv4 address, IPv6 address, or hostname. To ping AC2 by its hostname, make sure the DNS feature is configured to resolve AC2's domain name into the correct IP address.
Procedures
1. Click the System View tab at the bottom of the page.
2. From the navigation pane, select Tools > Ping.
3. Click the IPv4 Ping tab.
4. In the Destination IP address or hostname field, enter the IPv4 address or hostname of AC2.
5. Click Start.
Figure 2 Pinging AC2 by its IPv4 address or hostname
3. Click the IPv6 Ping tab.
4. In the Destination IP address or hostname field, enter the IPv6 address or hostname of AC2.
5. Click Start.
Figure 3 Pinging AC2 by its IPv6 address or hostname
Viewing the IPv4 ping result
The IPv4 ping result will be displayed in the Result field at the bottom of the IPv4 Ping page, as shown in Figure 4.
Figure 4 Viewing the IPv4 ping result
Viewing the IPv6 ping result
The IPv6 ping result will be displayed in the Result field at the bottom of the IPv6 Ping page, as shown in Figure 5.
Figure 5 Viewing the IPv6 ping result
Related documentation
H3C Access Controllers Web-Based Configuration Guide
