- 05-Web configuration examples (AC+fit AP)
- 01-Telnet Access Control Configuration Example
- 02-IPv6 Telnet Access Control Configuration Example
- 03-Web Access Control Configuration Example
- 04-User Role Assignment for Local Web Authentication Users Configuration Example
- 05-SSH Local Authentication Configuration Example
- 06-SSH User Remote Password Authentication Configuration Example
- 07-IPv6 SSH User Remote Password Authentication Configuration Example
- 08-Password Control Configuration Example
- 09-Licensing Configuration Example
- 10-Automatic License Installation Configuration Example
- 11-Layer 2 Static Link Aggregation Configuration Example
- 12-Layer 2 Dynamic Link Aggregation Configuration Example
- 13-PPPoE Client Configuration Example
- 14-Static IPv6 Address Configuration Example
- 15-IPv6 Static Routing Configuration Example
- 16-Static IPv4 DNS Configuration Example
- 17-Static IPv6 DNS Configuration Example
- 18-IGMP Snooping Configuration Example
- 19-MLD Snooping Configuration Example
- 20-IPv4 DNS Proxy Configuration Example
- 21-IPv6 DNS Proxy Configuration Example
- 22-Static NAT Configuration Example
- 23-Dynamic NAT Configuration Example
- 24-IPv4 ACL-Based Packet Filter Configuration Example
- 25-IPv6 ACL-Based Packet Filter Configuration Example
- 26-ARP Attack Protection Configuration Example
- 27-ARP Proxy Configuration Example
- 28-Dynamic IPv4 DNS Configuration Example
- 29-Dynamic IPv6 DNS Configuration Example
- 30-WLAN Access Configuration Example
- 31-Different Wireless Services on Different Radios Configuration Example
- 32-CAPWAP Tunnel Establishment Through DHCP Configuration Example
- 33-CAPWAP Tunnel Establishment Through DHCPv6 Configuration Example
- 34-CAPWAP Tunnel Establishment Through DNS Configuration Example
- 35-CAPWAP Tunnel Establishment Through DNSv6 Configuration Example
- 36-Auto AP Configuration Example
- 37-AP Group Configuration Example
- 38-Radio Management Configuration Example
- 39-Load Balancing Group-Based Session-Mode Load Balancing Configuration Example
- 40-Radio-Based Session-Mode Load Balancing Configuration Example
- 41-A-MPDU and A-MSDU Configuration Example
- 42-Device Classification and Countermeasure Configuration Example
- 43-Malformed Packet Detection and Flood Attack Detection Configuration Example
- 44-Signature-Based Attack Detection Configuration Example
- 45-802.1X RADIUS-Based AAA Configuration Example
- 46-VLAN Interface-Based Direct Portal Authentication Configuration Example
- 47-Service Template-Based Direct Portal Authentication Configuration Example
- 48-Wireless Spectrum Analysis Configuration Example
- 49-Auto DFS Configuration Examples
- 50-Auto TPC Configuration Examples
- 51-Whitelist-Based Client Access Control Configuration Example
- 52-Blacklist-Based Client Access Control Configuration Example
- 53-CAC Configuration Example
- 54-WLAN Probe Configuration Example
- 55-Intra-AC Roaming Configuration Example
- 56-Bonjour Gateway Configuration Example
- 57-IPv4 Multicast Optimization Configuration Examples
- 58-IPv6 Multicast Optimization Configuration Examples
- 59-Ping Configuration Example
- 60-Local Packet Capture Configuration Example
- 61-Remote Packet Capture Configuration Example
| 50-Auto TPC Configuration Examples | 189.66 KB |
H3C Access Controllers |
Comware 7 Auto TPC Configuration Examples |
Copyright © 2022 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
The following information provides an example for configuring auto TPC.
The following information applies to Comware 7-based access controllers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the H3C access controllers.
The following information is provided based on the assumption that you have basic knowledge of WLAN configuration.
Example: Configuring auto TPC
As shown in Figure 1, each AP is enabled with only one radio. Configure auto-TPC and set the adjacency factor to 3 to enable the AC to perform auto TPC when AP 4 joins. Add radio 1 of AP 1 to an RRM holddown group to avoid frequent power adjustments.
Procedures
Configuring basic AC settings
Configure wireless service, IP address, AP access, and radio settings on the AC. (Details not shown.)
Configuring channel settings
1. Click the Network View tab at the bottom of the page.
2. From the navigation pane, select Wireless Configuration > Radio Management.
3. Click the More icon
in the
upper right corner of the Radios
for all APs area.
4. Click the Edit icon
for AP 1
and then select OFF from the Power
lock field.
Figure 2 Disabling power lock
5. Repeat the previous steps to disable power lock for AP 2, AP 3, and AP 4.
1. From the navigation pane, select Wireless Configuration > Radio Management.
2. Click the RRM tab.
in the
upper right corner of the AP configuration area.
for AP 1
and configure auto TPC as follows:
¡ Enable auto TPC.
¡ Set the TPC mode to Custom.
¡ Set the maximum neighbor quantity, power adjustment threshold, and minimum transmit power to 3, 70, and 5, respectively.
¡ Retain the default settings for the other fields.
¡ Click Apply.
Figure 3 Configuring auto TPC
5. Repeat the previous steps to configure auto TPC for AP 2, AP 3, and AP 4.
6. Click the RRM Holddown Group area, click the Add icon
, and then
configure an RRM holddown group as follows:
¡ Set the group ID to 10.
¡ Set the power holddown time to 100 minutes.
¡ Add radio 1 of AP 1 as a group member.
¡ Click Apply.
Figure 4 Configuring an RRM holddown group
# Click the Network View tab at the bottom of the page and access the Monitoring > RF Monitoring page to view detailed information about channel adjustment. If auto TPC is configured correctly, the joining of AP 4 triggers the system to compare the third strongest radio RSSI with the power adjustment threshold. The system decreases or increases the transmit power of the radio if the RSSI is higher or lower than the threshold.
# Verify that the transmit power of radio 1 on AP 1 remains unchanged within 100 minutes after the first TPC.
Related documentation
H3C Access Controllers Web-Based Configuration Guide
