- 05-Web configuration examples (AC+fit AP)
- 01-Telnet Access Control Configuration Example
- 02-IPv6 Telnet Access Control Configuration Example
- 03-Web Access Control Configuration Example
- 04-User Role Assignment for Local Web Authentication Users Configuration Example
- 05-SSH Local Authentication Configuration Example
- 06-SSH User Remote Password Authentication Configuration Example
- 07-IPv6 SSH User Remote Password Authentication Configuration Example
- 08-Password Control Configuration Example
- 09-Licensing Configuration Example
- 10-Automatic License Installation Configuration Example
- 11-Layer 2 Static Link Aggregation Configuration Example
- 12-Layer 2 Dynamic Link Aggregation Configuration Example
- 13-PPPoE Client Configuration Example
- 14-Static IPv6 Address Configuration Example
- 15-IPv6 Static Routing Configuration Example
- 16-Static IPv4 DNS Configuration Example
- 17-Static IPv6 DNS Configuration Example
- 18-IGMP Snooping Configuration Example
- 19-MLD Snooping Configuration Example
- 20-IPv4 DNS Proxy Configuration Example
- 21-IPv6 DNS Proxy Configuration Example
- 22-Static NAT Configuration Example
- 23-Dynamic NAT Configuration Example
- 24-IPv4 ACL-Based Packet Filter Configuration Example
- 25-IPv6 ACL-Based Packet Filter Configuration Example
- 26-ARP Attack Protection Configuration Example
- 27-ARP Proxy Configuration Example
- 28-Dynamic IPv4 DNS Configuration Example
- 29-Dynamic IPv6 DNS Configuration Example
- 30-WLAN Access Configuration Example
- 31-Different Wireless Services on Different Radios Configuration Example
- 32-CAPWAP Tunnel Establishment Through DHCP Configuration Example
- 33-CAPWAP Tunnel Establishment Through DHCPv6 Configuration Example
- 34-CAPWAP Tunnel Establishment Through DNS Configuration Example
- 35-CAPWAP Tunnel Establishment Through DNSv6 Configuration Example
- 36-Auto AP Configuration Example
- 37-AP Group Configuration Example
- 38-Radio Management Configuration Example
- 39-Load Balancing Group-Based Session-Mode Load Balancing Configuration Example
- 40-Radio-Based Session-Mode Load Balancing Configuration Example
- 41-A-MPDU and A-MSDU Configuration Example
- 42-Device Classification and Countermeasure Configuration Example
- 43-Malformed Packet Detection and Flood Attack Detection Configuration Example
- 44-Signature-Based Attack Detection Configuration Example
- 45-802.1X RADIUS-Based AAA Configuration Example
- 46-VLAN Interface-Based Direct Portal Authentication Configuration Example
- 47-Service Template-Based Direct Portal Authentication Configuration Example
- 48-Wireless Spectrum Analysis Configuration Example
- 49-Auto DFS Configuration Examples
- 50-Auto TPC Configuration Examples
- 51-Whitelist-Based Client Access Control Configuration Example
- 52-Blacklist-Based Client Access Control Configuration Example
- 53-CAC Configuration Example
- 54-WLAN Probe Configuration Example
- 55-Intra-AC Roaming Configuration Example
- 56-Bonjour Gateway Configuration Example
- 57-IPv4 Multicast Optimization Configuration Examples
- 58-IPv6 Multicast Optimization Configuration Examples
- 59-Ping Configuration Example
- 60-Local Packet Capture Configuration Example
- 61-Remote Packet Capture Configuration Example
| 42-Device Classification and Countermeasure Configuration Example | 196.46 KB |
H3C Access Controllers |
Comware 7 Device Classification and Countermeasure |
Copyright © 2022 New H3C Technologies Co., Ltd. All rights reserved.
Example: Configuring device classification and countermeasure
Configuring basic features on the AC
Configuring a classification policy
Configuring a countermeasure policy
Overview
The following information provides an example for configuring device classification and countermeasures.
The following information applies to Comware 7-based access controllers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the H3C access controllers.
The following information is provided based on the assumption that you have basic knowledge of WIPS and WLAN access.
As shown in Figure 1, the sensor connects to the AC through the switch. AP 1 and AP 2 provide wireless services to clients through SSID abc. Perform the following tasks:
· Enable WIPS for the sensor.
· Configure wireless device classification to add MAC address 000f-1c35-12a5 to the static prohibited device list and SSID abc to the trusted SSID list.
· Configure countermeasures to enable WIPS to take countermeasures against potential-external APs and unauthorized clients.
Procedures
Configure wireless service, IP address, AP access, and radio settings. (Details not shown.)
1. Click the Network View tab at the bottom of the page.
2. From the navigation pane, select Wireless Configuration > Wireless Security.
3. Click the Add button
to add a classification policy.
a. Enter class1 in the Policy name field.
b. Enter abc in the Trust SSID field.
c. Enter 00-0f-1c-35-12-a5 in the Block MAC field.
d. Click Apply.
Figure 2 Adding a classification policy
to add a countermeasure policy.
a. Enter protect in the Policy name field.
b. Select Potential-external AP and Unauthorized client from the Categories list.
c. Click Apply.
Figure 3 Adding a countermeasure policy
Configuring a VSD
to add a VSD.
a. Enter VSD_1 in the VSD name field.
b. Select class1 from the Classification policy list.
c. Select protect from the Countermeasure policy list.
d. Click Apply.
Figure 4 Adding a VSD
Enabling WIPS
3. Click the More button
to enable WIPS.
a. On the page that opens, select sensor and click
the Edit button
to
edit the sensor.
b. On the page that opens, select a radio band from the Radio list and select a VSD from the VSD name list.
c. Click Apply.
Figure 5 Enabling WIPS
2. From the navigation pane, select Monitoring > Network Security, and view the relevant information shown in the Countermeasure Statistics area.
Related documentation
H3C Access Controllers Web-Based Configuration Guide
