- 05-Web configuration examples (AC+fit AP)
- 01-Telnet Access Control Configuration Example
- 02-IPv6 Telnet Access Control Configuration Example
- 03-Web Access Control Configuration Example
- 04-User Role Assignment for Local Web Authentication Users Configuration Example
- 05-SSH Local Authentication Configuration Example
- 06-SSH User Remote Password Authentication Configuration Example
- 07-IPv6 SSH User Remote Password Authentication Configuration Example
- 08-Password Control Configuration Example
- 09-Licensing Configuration Example
- 10-Automatic License Installation Configuration Example
- 11-Layer 2 Static Link Aggregation Configuration Example
- 12-Layer 2 Dynamic Link Aggregation Configuration Example
- 13-PPPoE Client Configuration Example
- 14-Static IPv6 Address Configuration Example
- 15-IPv6 Static Routing Configuration Example
- 16-Static IPv4 DNS Configuration Example
- 17-Static IPv6 DNS Configuration Example
- 18-IGMP Snooping Configuration Example
- 19-MLD Snooping Configuration Example
- 20-IPv4 DNS Proxy Configuration Example
- 21-IPv6 DNS Proxy Configuration Example
- 22-Static NAT Configuration Example
- 23-Dynamic NAT Configuration Example
- 24-IPv4 ACL-Based Packet Filter Configuration Example
- 25-IPv6 ACL-Based Packet Filter Configuration Example
- 26-ARP Attack Protection Configuration Example
- 27-ARP Proxy Configuration Example
- 28-Dynamic IPv4 DNS Configuration Example
- 29-Dynamic IPv6 DNS Configuration Example
- 30-WLAN Access Configuration Example
- 31-Different Wireless Services on Different Radios Configuration Example
- 32-CAPWAP Tunnel Establishment Through DHCP Configuration Example
- 33-CAPWAP Tunnel Establishment Through DHCPv6 Configuration Example
- 34-CAPWAP Tunnel Establishment Through DNS Configuration Example
- 35-CAPWAP Tunnel Establishment Through DNSv6 Configuration Example
- 36-Auto AP Configuration Example
- 37-AP Group Configuration Example
- 38-Radio Management Configuration Example
- 39-Load Balancing Group-Based Session-Mode Load Balancing Configuration Example
- 40-Radio-Based Session-Mode Load Balancing Configuration Example
- 41-A-MPDU and A-MSDU Configuration Example
- 42-Device Classification and Countermeasure Configuration Example
- 43-Malformed Packet Detection and Flood Attack Detection Configuration Example
- 44-Signature-Based Attack Detection Configuration Example
- 45-802.1X RADIUS-Based AAA Configuration Example
- 46-VLAN Interface-Based Direct Portal Authentication Configuration Example
- 47-Service Template-Based Direct Portal Authentication Configuration Example
- 48-Wireless Spectrum Analysis Configuration Example
- 49-Auto DFS Configuration Examples
- 50-Auto TPC Configuration Examples
- 51-Whitelist-Based Client Access Control Configuration Example
- 52-Blacklist-Based Client Access Control Configuration Example
- 53-CAC Configuration Example
- 54-WLAN Probe Configuration Example
- 55-Intra-AC Roaming Configuration Example
- 56-Bonjour Gateway Configuration Example
- 57-IPv4 Multicast Optimization Configuration Examples
- 58-IPv6 Multicast Optimization Configuration Examples
- 59-Ping Configuration Example
- 60-Local Packet Capture Configuration Example
- 61-Remote Packet Capture Configuration Example
| 02-IPv6 Telnet Access Control Configuration Example | 110.66 KB |
H3C Access Controllers |
IPv6 Telnet Access Control |
Copyright © 2022 New H3C Technologies Co., Ltd. All rights reserved.
Overview
The following information provides an example for configuring IPv6 Telnet access control.
The following information applies to Comware 7-based access controllers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the H3C access controllers.
The following information is provided based on the assumption that you have basic knowledge of IPv6 Telnet access control.
Example: Configuring IPv6 Telnet access control
As shown in Figure 1, the AC is a Telnet server.
Configure the AC to permit only Telnet packets sourced from 4000::1.
Make sure the network connections are available.
Procedures
Configuring an IPv6 ACL
1. Click the System View tab at the bottom of the page.
2. From the navigation pane, select System > Resource.
3. Click the IPv6 ACL tab.
4. Click the Add button
to create an IPv6 ACL:
¡ Select Basic.
¡ Enter ACL number 2000.
¡ Click Apply.
Figure 2 Configuring an IPv6 ACL
5. Configure an IPv6 ACL rule:
¡ Select the Source IPv6 address/prefix length match criterion, and enter 4000::1 as the IP address and 128 as the prefix length.
¡ Clear the Continue to add next rule option.
¡ Click Apply.
Figure 3 Configuring an IPv6 ACL rule
Applying the IPv6 ACL to the IPv6 Telnet service
2. From the navigation pane, select Network Settings > Management Protocols.
3. In the Telnet area, click the expand icon
for
Advanced settings and apply the ACL to the Telnet service:
¡ Select ACL 2000 for Use an ACL to control IPv6 Telnet access.
¡ Click Apply.
Figure 4 Applying the IPv6 ACL to the Telnet service
1. Telnet to the AC from Host A.
C:> telnet 4000::3
Trying 4000::3 ...
Press CTRL+K to abort
Connected to 4000::3 ...
* Copyright (c) 2004-2018 New H3C Technologies Co., Ltd. All rights reserved.*
* Without the owner's prior written consent, *
* no decompiling or reverse-engineering shall be allowed. *
<AC>
2. Telnet to the AC from Host B.
C:\> telnet 4000::3
Trying 4000::3 ...
Failed to connect to the remote host!
Related documentation
H3C Access Controllers Web-Based Configuration Guide
