07-Comware 7 Web-based configuration examples (AC+fit AP deployment)
HomeSupportDoc SetsDoc PackagesH3C Wireless Products All-in-One-6W10207-Comware 7 Web-based configuration examples (AC+fit AP deployment)
Table of Contents
Related Documents
61-Remote Packet Capture Configuration Example
61-Remote Packet Capture Configuration Example 360.39 KB
H3C Access Controllers
Comware 7 Remote Packet Capture
Copyright © 2023 New H3C Technologies Co., Ltd. All rights reserved.
Overview
The following information provides an example for configuring remote packet capture and analyzing the captured packets.
The following information applies to Comware 7-based access controllers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the H3C access controllers.
The following information is provided based on the assumption that you have basic knowledge of remote packet capture.
Example: Configuring remote packet capture
As shown in Figure 1, configure remote packet capture on Radio 1 of the AP to capture packets. Send the captured packets to the PC. Start Wireshark on the PC to analyze the packets.
Figure 1 Network diagram
Make sure the AP can access the AC.
Install Wireshark V2.6.4 on the PC and make sure the PC and the AP can communicate with each other.
Procedures
Configuring the AC
1.     Click the Network View tab at the bottom of the page.
2.     From the navigation pane, select Tools > Wireless Capture.
3.     Select the wa5320 AP entry with radio 5GHz(1) and click Start.
Figure 2 Selecting an AP
4.     Configure the following packet capture parameters:
¡     Select the remote capture mode.
¡     Set the RPCAP service port number to 2014.
Figure 3 Configuring remote packet capture parameters
5.     Click Start.
Figure 4 Starting remote packet capture
Configuring Wireshark on the PC
1.     Start Wireshark.
2.     Select Capture > Options.
Figure 5 Wireshark menu
3.     On the Input tab, click Manage Interfaces.
Figure 6 Entering the interface management page
4.     Click the Remote Interface tab and complete the following tasks:
¡     Enter the IP address of the AP 192.168.0.2.
¡     Set the port number to 2014.
¡     Select Null authentication.
¡     Click OK.
Figure 7 Adding a remote interface
5.     Click OK.
Figure 8 Completing the remote interface configuration
6.     Select  the remote interface and click Start.
Figure 9 Starting remote packet capture
1.     Verify that captured packets are displayed on Wireshark. (Details not shown.)
2.     Verify that you can use Wireshark to analyze the packets. (Details not shown.)
Related documentation
H3C Access Controllers Web-Based Configuration Guide
