07-Comware 7 Web-based configuration examples (AC+fit AP deployment)
HomeSupportDoc SetsDoc PackagesH3C Wireless Products All-in-One-6W10207-Comware 7 Web-based configuration examples (AC+fit AP deployment)
Table of Contents
Related Documents
40-Radio-Based Session-Mode Load Balancing Configuration Example
H3C Access Controllers
Comware 7 Radio-Based Session-Mode Load Balancing
Copyright © 2023 New H3C Technologies Co., Ltd. All rights reserved.
Overview
The following information provides an example for configuring radio-based session-mode load balancing.
The following information applies to Comware 7-based access controllers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the H3C access controllers.
The following information is provided based on the assumption that you have basic knowledge of radio-based session-mode load balancing.
Example: Configuring radio-based session-mode load balancing
As shown in Figure 1, AP 1 and AP 2 are managed by the AC and the clients can discover the APs. Client 1 associates with AP 1, and Client 2 through Client 4 associate with AP 2.
Configure the AC to perform radio load balancing on radios of AP 1 and AP 2 when the following conditions are met:
·     The number of sessions on a radio of an AP reaches 3.
·     The session gap between the radio and the radio that has the fewest sessions reaches 2.
Figure 1 Network diagram
Procedures
Configuring basic features on the AC
Configure AP access, wireless service, and radio settings. (Details not shown.)
Configuring load balancing
1.     Click the Network View tab at the bottom of the page.
2.     From the navigation pane, select Wireless Configuration > Radio Management.
3.     Click the Load Balancing tab and click the More button  in the Global settings area.
a.     On the page that opens, select on and Session.
b.     Enter 3 and 2 in the Session threshold and Session gap threshold fields, respectively.
Use the default values in the Max denials and RSSI threshold fields.
c.     Click Apply.
Figure 2 Configuring load balancing
1.     Configure Client 5 to access the WLAN in the nearby area of AP 2.
2.     Click the Network View tab at the bottom of the page.
3.     From the navigation pane, select Monitoring > Clients.
4.     Verify that the number of clients associated with AP 1 has increased by 1.
Related documentation
H3C Access Controllers Web-Based Configuration Guide
