07-Comware 7 Web-based configuration examples (AC+fit AP deployment)
HomeSupportDoc SetsDoc PackagesH3C Wireless Products All-in-One-6W10207-Comware 7 Web-based configuration examples (AC+fit AP deployment)
Table of Contents
Related Documents
44-Signature-Based Attack Detection Configuration Example
H3C Access Controllers
Comware 7 Signature-Based Attack Detection
Copyright © 2023 New H3C Technologies Co., Ltd. All rights reserved.
Overview
The following information provides an example for configuring signature-based attack detection.
The following information applies to Comware 7-based access controllers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the H3C access controllers.
The following information is provided based on the assumption that you have basic knowledge of WIPS and WLAN access.
Example: Configuring signature-based attack detection
As shown in Figure 1, AP 1 and AP 2 provide wireless services for clients through SSID abc. Enable WIPS for the sensor and configure a signature to enable WIPS to trigger an alarm when it detects beacon frames whose SSIDs are not abc.
Figure 1 Network diagram
Procedures
Configuring basic features on the AC
Configure wireless service, IP address, AP access, and radio settings. (Details not shown.)
Configuring a signature
1.     Click the Network View tab at the bottom of the page.
2.     From the navigation pane, select Wireless Configuration > Wireless Security.
3.     Click the Add button  to add a signature.
a.     Enter 1 in the Rule ID field.
b.     Select Management from the Frame type list.
c.     Select Beacon from the Frame subtype list.
d.     Enter abc in the SSID field.
e.     Select Not equal from the SSID match type list.
f.     Click Apply.
Figure 2 Adding a signature
Configuring a signature policy
3.     Click the Add button  to add a signature policy.
a.     Enter sig1 in the Policy name field.
b.     Select 1 from the Signature rule list.
c.     Click Apply.
Figure 3 Adding a signature policy
Configuring a VSD
3.     Click the Add button  to add a VSD.
a.     Enter VSD_1 in the VSD name field.
b.     Select sig1 from the Signature policy list.
c.     Click Apply.
Figure 4 Adding a VSD
Enabling WIPS
3.     Click the More button  to enable WIPS.
a.     On the page that opens, select sensor and click the Edit button  to edit the sensor.
b.     On the page that opens, select a radio band from the Radio list and select a VSD from the VSD name list.
c.     Click Apply.
Figure 5 Enabling WIPS
2.     From the navigation pane, select Monitoring > Network Security, and view the relevant information shown in the Attack statistics area.
Related documentation
H3C Access Controllers Web-Based Configuration Guide
