07-Comware 7 Web-based configuration examples (AC+fit AP deployment)
HomeSupportDoc SetsDoc PackagesH3C Wireless Products All-in-One-6W10207-Comware 7 Web-based configuration examples (AC+fit AP deployment)
Table of Contents
Related Documents
36-Auto AP Configuration Example
36-Auto AP Configuration Example 244.08 KB
H3C Access Controllers
Comware 7 Auto AP Configuration Example
Copyright © 2023 New H3C Technologies Co., Ltd. All rights reserved.
Overview
The following information provides an example for configuring auto AP.
The following information applies to Comware 7-based access controllers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the H3C access controllers.
The following information is provided based on the assumption that you have basic knowledge of auto AP.
Example: Configuring auto AP
As shown in Figure 1, the AC assigns an IP address to the AP as a DHCP server. Enable auto AP on the AC for the AP to establish a CAPWAP tunnel with the AC automatically.
Figure 1 Network diagram
Procedures
Specifying an IP address for the AC
1.     Click the System View tab at the bottom of the page.
2.     From the navigation pane, select Network Configuration > VLAN.
a.     Click the Add button  and create VLAN 10.
Figure 2 Creating a VLAN
b.     Click the Edit icon  for VLAN 10 and configure GE1/0/3 as an untagged port.
Figure 3 Adding an untagged port
c.     Select Create VLAN interface and specify the IPv4 address as 192.168.1.1/24.
Figure 4 Configuring a VLAN interface
Configuring the DHCP service
1.     From the navigation pane, select Network Configuration > Network Services > DHCP/DNS.
2.     Click the Enable DHCP button.
3.     Configure VLAN-interface 10 to operate in DHCP server mode.
4.     Click Address pool.
5.     On the Assigned Address tab, create an address pool named pool1, and then specify 192.168.1.0/24 as the network segment for dynamic address assignment.
Figure 5 Configuring a DHCP address pool
6.     Configure DHCP Option 43:
c.     Click the DHCP Options tab.
d.     Configure the gateway address as 192.168.1.1, and configure DHCP Option 43 to specify the AC's IP address in the hexadecimal format. The option content is 8007000001c0a80101 in this example.
Figure 6 Configuring DHCP Option 43
Configuring auto AP
1.     Click the Network View tab at the bottom of the page.
2.     From the navigation pane, select Wireless Configuration > AP Management.
3.     Click the AP Global Settings tab and enable auto AP.
Figure 7 Enabling auto AP
3.     Verify that the AP is online and the AP type is Auto AP.
Figure 8 Displaying online AP information
Related documentation
H3C Access Controllers Web-Based Configuration Guide
