07-Comware 7 Web-based configuration examples (AC+fit AP deployment)
HomeSupportDoc SetsDoc PackagesH3C Wireless Products All-in-One-6W10207-Comware 7 Web-based configuration examples (AC+fit AP deployment)
Table of Contents
Related Documents
45-802.1X RADIUS-Based AAA Configuration Example
45-802.1X RADIUS-Based AAA Configuration Example 644.79 KB
H3C Access Controllers
Comware 7 802.1X RADIUS-Based AAA
Copyright © 2023 New H3C Technologies Co., Ltd. All rights reserved.
Overview
The following information provides an example for configuring RADIUS authentication, authorization, and accounting for 802.1X users.
The following information applies to Comware 7-based access controllers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the H3C access controllers.
The following information is provided based on the assumption that you have basic knowledge of 802.1X and AAA.
Example: Configuring RADIUS authentication, authorization, and accounting for 802.1X users
As shown in Figure 1, the switch acts as a DHCP server to assign IP addresses to the AP and the client. IMC acts as the RADIUS server.
Configure the AC, the client, the switch, and the RADIUS server to meet the following requirements:
·     The AC uses the RADIUS server to perform 802.1X authentication, authorization, and accounting for wireless clients.
·     The AC uses open system authentication to provide link layer authentication for clients.
·     The AC uses 802.1X AKM mode to secure data transmission between client and AP.
·     The cipher suite is CCMP.
Figure 1 Network diagram
Assign IP addresses to interfaces. Make sure the AC, the client, the switch, and the RADIUS server can reach each other.
Procedures
Configuring the AC
Configuring the 802.1X authentication method
1.     Click the Network View tab at the bottom of the page.
2.     From the navigation pane, select Network Security > Access Control.
3.     Click the Advanced settings button .
Figure 2 Configuring advanced settings
4.     Click the authentication method setting (CHAP by default) to open the authentication method list.
5.     Select EAP from the authentication method list.
6.     Click Apply.
Figure 3 Configuring the 802.1X authentication method
Configuring a RADIUS scheme
1.     From the navigation pane, select Network Security > Authentication.
2.     Click the RADIUS tab.
3.     Click the Create RADIUS Schemes button  to create a RADIUS scheme.
4.     On the New RADIUS Scheme page, configure the RADIUS scheme:
a.     Set the scheme name to 802.1X.
b.     Configure the primary authentication server. Set the IP address, port, and modified shared key for authentication to 10.1.1.3, 1812, and 12345, respectively. Then, select state Active.
c.     Configure the primary accounting server. Set the IP address, port, and modified shared key for accounting to 10.1.1.3, 1813, and 12345, respectively. Then, select state Active.
Figure 4 Configuring a RADIUS scheme
d.     At the bottom of the page, click Show advanced settings.
e.     Specify 10.1.1.46 as the source IPv4 address for outgoing RADIUS packets, and select Excludes the domain name from the Format for the usernames sent to the RADIUS server field.
f.     Click Apply.
Figure 5 Configuring advanced settings
Configuring an ISP domain
2.     On the ISP Domains tab, click the Create ISP Domains button  to create an ISP domain.
3.     On the New ISP Domain page, configure the ISP domain:
a.     Set the domain name to dm1X.
b.     Select state Active.
c.     Select LAN access from the Service type field.
d.     Select RADIUS for authentication, authorization, and accounting of LAN users and select 802.1x from each Scheme field.
e.     Click Apply.
Figure 6 Configuring an ISP domain
Configuring a service template
1.     From the navigation pane, select Wireless Configuration > Wireless Networks.
2.     Click the Create Service Templates button  to create a service template.
3.     In the Basic area, set the service template name to service, set the SSID to service, enable the service template, and set the default VLAN to 200.
4.     In the Authentication area, select 802.1X Authentication and enter dm1X in the Domain Name field.
5.     Click Apply.
Figure 7 Configuring the service template
Creating an AP and bind the service template to the AP
Details not shown.
Configuring the switch
Details not shown.
Configuring the RADIUS server
This example uses IMC as the RADIUS server, which runs IMC PLAT 7.1(E0303) and IMC UAM 7.1(E0304).
1.     Install the EAP-PEAP certificate in IMC. (Details not shown.)
2.     Add the AC to IMC as an access device:
a.     Log in to IMC and click the User tab.
b.     From the navigation tree, select User Access Policy > Access Device Management > Access Device.
c.     Click Add.
The Add Access Device page opens.
d.     In the Access Configuration area, configure the following parameters, as shown in Figure 8:
-     Enter 12345 in the Shared Key and Confirm Shared Key fields.
-     Select EAP from the Certificate Authentication field.
-     Select EAP-PEAP Auth from the Certificate Type field and select MS-CHAPv2 Auth from the Certificate Sub-Type field.
The certificate sub-type on the IMC server must be the same as the identity authentication method configured on the client.
e.     In the Device List area, click Select or Add Manually to add the device at 10.1.1.46 as an access device.
f.     Click OK.
Figure 8 Adding an access device
3.     Add an access policy:
a.     Click the User tab.
b.     From the navigation tree, select User Access Policy > Access Policy.
c.     Click Add.
d.     On the Add Access Policy page, enter dot1x in the Access Policy Name field.
e.     Click OK.
Figure 9 Adding an access policy
4.     Add an access service:
b.     From the navigation tree, select User Access Policy > Access Service.
c.     Click Add.
d.     On the Add Access Service page, configure the following parameters, as shown in Figure 10:
-     Enter dot1x in the Service Name field.
-     Select dot1x from the Default Access Policy list.
e.     Click OK.
Figure 10 Adding an access service
5.     Add an access user:
b.     From the navigation tree, select Access User > All Access Users.
The access user list opens.
c.     Click Add.
The Add Access User page opens.
d.     In the Access Information area, configure the following parameters, as shown in Figure 11:
-     Click Select to select a user that has been added to the IMC platform or click Add User to add a new user to the IMC platform. In this example, click Add User to add user user.
-     Enter dot1x in the Account Name field.
-     Enter dot1x123 in the Password and Confirm Password fields.
e.     In the Access Service area, select dot1x from the list.
f.     Click OK.
Figure 11 Adding an access user account
# Verify that the client can pass 802.1X authentication with username dot1x and password dot1x123.
# Verify that the client can access the service wireless network. (Details not shown.)
Related documentation
H3C Access Controllers Web-Based Configuration Guide
