07-Comware 7 Web-based configuration examples (AC+fit AP deployment)
HomeSupportDoc SetsDoc PackagesH3C Wireless Products All-in-One-6W10207-Comware 7 Web-based configuration examples (AC+fit AP deployment)
Table of Contents
Related Documents
14-Static IPv6 Address Configuration Example
14-Static IPv6 Address Configuration Example 83.63 KB
H3C Access Controllers
Comware 7 Static IPv6 Address
Copyright © 2023 New H3C Technologies Co., Ltd. All rights reserved.
Overview
The following information provides an example for configuring a static IPv6 address to a VLAN interface to support IPv6 communication between the clients and the AC.
The following information applies to Comware 7-based access controllers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the H3C access controllers.
The following information is provided based on the assumption that you have basic knowledge of IPv6 basics and WLAN access features.
Example: Configuring a static IPv6 address
As shown in Figure 1, assign the AP and the AC to VLAN 10 and configure a global unicast IPv6 address 2001::1/64 for VLAN-interface 10 of the AC. Install IPv6 on the client to enable the client to generate an IPv6 address through stateless address autoconfiguration.
Figure 1 Network diagram
Procedures
1.     Configure basic wireless functions on the AC, including WLAN access services and radio functions. (Details not shown.)
2.     Assign IPv6 address 2001::1/64 to VLAN-interface 10:
a.     Click the System View tab at the bottom of the page.
b.     From the navigation pane, select Network Configuration > Network Interfaces.
c.     Click the Edit button  for VLAN-interface 10.
d.     Set the IPv6 address to 2001::1 and set the prefix length to 64.
Figure 2 Assigning an IPv6 address to VLAN-interface 10
e.     Click Apply.
3.     Configure VLAN-interface 10 to advertise RA messages.
b.     From the navigation pane, select Network Configuration > Network Services > ND.
c.     Click the Advanced settings button .
d.     Click the Expand icon  for RA settings.
e.     Enable RA message advertisement for VLAN-interface 10.
f.     Click Apply.
4.     Install IPv6 on the client. The client automatically generates an IPv6 address based on the address prefix information contained in the RA message.
Verify that the client and the AC can ping each other. (Details not shown.)
Related documentation
H3C Access Controllers Web-Based Configuration Guide
