07-Comware 7 Web-based configuration examples (AC+fit AP deployment)
HomeSupportDoc SetsDoc PackagesH3C Wireless Products All-in-One-6W10207-Comware 7 Web-based configuration examples (AC+fit AP deployment)
Table of Contents
Related Documents
02-IPv6 Telnet Access Control Configuration Example
H3C Access Controllers
Copyright © 2023 New H3C Technologies Co., Ltd. All rights reserved.
Overview
The following information provides an example for configuring IPv6 Telnet access control.
The following information applies to Comware 7-based access controllers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the H3C access controllers.
The following information is provided based on the assumption that you have basic knowledge of IPv6 Telnet access control.
Example: Configuring IPv6 Telnet access control
As shown in Figure 1, the AC is a Telnet server.
Configure the AC to permit only Telnet packets sourced from 4000::1.
Figure 1 Network diagram
Make sure the network connections are available.
Procedures
Configuring an IPv6 ACL
1.     Click the System View tab at the bottom of the page.
2.     From the navigation pane, select System > Resource.
3.     Click the IPv6 ACL tab.
4.     Click the Add button  to create an IPv6 ACL:
¡     Select Basic.
¡     Enter ACL number 2000.
¡     Click Apply.
Figure 2 Configuring an IPv6 ACL
5.     Configure an IPv6 ACL rule:
¡     Select the Source IPv6 address/prefix length match criterion, and enter 4000::1 as the IP address and 128 as the prefix length.
¡     Clear the Continue to add next rule option.
¡     Click Apply.
Figure 3 Configuring an IPv6 ACL rule
Applying the IPv6 ACL to the IPv6 Telnet service
2.     From the navigation pane, select Network Settings > Management Protocols.
3.     In the Telnet area, click the expand icon  for Advanced settings and apply the ACL to the Telnet service:
¡     Select ACL 2000 for Use an ACL to control IPv6 Telnet access.
¡     Click Apply.
Figure 4 Applying the IPv6 ACL to the Telnet service
1.     Telnet to the AC from Host A.
C:> telnet 4000::3
Trying 4000::3 ...
Press CTRL+K to abort
Connected to 4000::3 ...
* Copyright (c) 2004-2018 New H3C Technologies Co., Ltd. All rights reserved.*
<AC>
2.     Telnet to the AC from Host B.
C:\> telnet 4000::3
Trying 4000::3 ...
Failed to connect to the remote host!
Related documentation
H3C Access Controllers Web-Based Configuration Guide
