07-Comware 7 Web-based configuration examples (AC+fit AP deployment)
HomeSupportDoc SetsDoc PackagesH3C Wireless Products All-in-One-6W10207-Comware 7 Web-based configuration examples (AC+fit AP deployment)
Table of Contents
Related Documents
24-IPv4 ACL-Based Packet Filter Configuration Example
H3C Access Controllers
Comware 7 IPv4 ACL-Based Packet Filter
Copyright © 2023 New H3C Technologies Co., Ltd. All rights reserved.
Overview
The following information provides an example for configuring packet filtering with an IPv4 ACL.
The following information applies to Comware 7-based access controllers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the H3C access controllers.
The following information is provided based on the assumption that you have basic knowledge of packet filtering.
Example: Configuring an IPv4 ACL-based packet filter
A company interconnects its departments through the AC. Configure a packet filter to:
·     Permit access from the President's office at any time to the financial database server.
·     Permit access from the Financial department to the database server only during working hours (from 8:00 to 18:00) on working days.
·     Deny access from any other department to the database server.
Figure 1 Network diagram
Procedures
1.     Click the System View tab at the bottom of the page.
2.     From the navigation pane, select System > Resource.
3.     Click the Add button  to add an IPv4 ACL.
a.     Select Advanced.
b.     Enter ACL number 3000.
c.     Click Apply.
Figure 2 Adding an IPv4 ACL
4.     In the dialog box that opens, add three ACL rules.
¡     Add the first ACL rule:
-     Enter IP protocol 256.
-     Enter the source IP address and mask 192.168.1.0/0.0.0.255 and the destination IP address and mask 192.168.0.100/0.0.0.0 as the match criteria.
-     Click Apply.
Figure 3 Adding the first ACL rule
¡     Add a time range.
-     From the navigation pane, select System > Resource.
-     On the Time Range tab, click the Add button  to add a periodic time range.
-     Enter name work.
-     Enter start time 08:00 and end time 18:00.
-     Select Monday through Friday.
-     Click Apply.
Figure 4 Adding a time range
¡     Add a second ACL rule:
-     Enter the source IP address and mask 192.168.2.0/0.0.0.255 and the destination IP address and mask 192.168.0.100/0.0.0.0 as the match criteria.
-     Select time range work.
-     Click Apply.
Figure 5 Adding a second ACL rule
¡     Add a third ACL rule:
-     Select Deny.
-     Enter the destination IP address and mask 192.168.0.100/0.0.0.0 as the match criterion.
-     Click Apply.
Figure 6 Adding a third ACL rule
5.     From the navigation pane, select Network Security > Packet Filter.
6.     On the Interface tab, click the Add button  to add a packet filter for an interface.
7.     In the dialog box that opens, configure the following settings:
a.     Select interface GE1/0/1.
b.     Select the Outgoing direction.
c.     Select IPv4 ACL.
d.     Select ACL 3000.
e.     Enable Hardware counting.
f.     Click Apply.
Figure 7 Configuring a packet filter
1.     Verify that the President's office can ping the financial database server at any time.
2.     Verify that the Financial department can ping the financial database server during working hours (from 8:00 to 18:00) on working days.
3.     Verify that the Marketing department cannot ping the financial database server at any time.
Related documentation
H3C Access Controllers Web-Based Configuration Guide
