07-Comware 7 Web-based configuration examples (AC+fit AP deployment)
HomeSupportDoc SetsDoc PackagesH3C Wireless Products All-in-One-6W10207-Comware 7 Web-based configuration examples (AC+fit AP deployment)
Table of Contents
Related Documents
55-Intra-AC Roaming Configuration Example
55-Intra-AC Roaming Configuration Example 141.59 KB
H3C Access Controllers
Comware 7 Intra-AC Roaming
Copyright © 2023 New H3C Technologies Co., Ltd. All rights reserved.
Overview
The following information provides an example for configuring intra-AC roaming.
The following information applies to Comware 7-based access controllers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the H3C access controllers.
The following information is provided based on the assumption that you have basic knowledge of intra-AC roaming.
Example: Configuring intra-AC roaming
As shown in Figure 1, configure intra-AC roaming to enable the client to roam from AP 1 to AP 2 that are managed by the same AC.
Figure 1 Network diagram
Procedures
1.     From the navigation pane, select Wireless Configuration > AP Management.
2.     Create APs ap1 and ap2. (Details not shown.)
3.     Click the Edit icon  for AP ap1 and bind wireless service service to a radio of the AP.
Figure 2 Binding a wireless service to a radio
4.     Repeat the previous step to bind wireless service service to a radio of AP ap2.
1.     Make the client come online from one AP and then move the client toward the other AP.
2.     Click the System View tab at the bottom of the page.
3.     From the navigation pane, select Network Configuration > Mobility Domain.
4.     Verify that the client has successfully roamed from one AP to another AP.
Figure 3 Displaying client roaming information
Related documentation
H3C Access Controllers Web-Based Configuration Guide
