07-Comware 7 Web-based configuration examples (AC+fit AP deployment)
HomeSupportDoc SetsDoc PackagesH3C Wireless Products All-in-One-6W10207-Comware 7 Web-based configuration examples (AC+fit AP deployment)
Table of Contents
Related Documents
19-MLD Snooping Configuration Example
19-MLD Snooping Configuration Example 96.20 KB
H3C Access Controllers
Comware 7 MLD Snooping
Copyright © 2023 New H3C Technologies Co., Ltd. All rights reserved.
Overview
The following information provides an example for configuring MLD snooping on the AC to forward IPv6 multicast packets to receivers instead of flooding them within a VLAN.
The following information applies to Comware 7-based access controllers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the H3C access controllers.
The following information is provided based on the assumption that you have basic knowledge of MLD snooping.
Example: Configuring MLD snooping
As shown in Figure 1, Source 1 sends IPv6 multicast data to multicast group FF1E::101. Host A and Host B are receivers of multicast group FF1E::101 and run MLDv1.
Configure the AC as an MLD querier. To prevent IPv6 multicast packet from being flooded in VLAN 10, enable dropping unknown IPv6 multicast data on all devices.
Figure 1 Network diagram
Procedures
Configuring the AC as an MLD querier
1.     Click the System View tab at the bottom of the page.
2.     From the navigation pane, select Network Configuration > Network Services > Multicast.
3.     Click the MLD Snooping tab.
4.     Click Enable MLD snooping.
Figure 2 Enabling MLD snooping
5.     On the page that opens, click the Add button .
6.     Configure MLD snooping for VLAN 10:
a.     Set the MLD snooping version to 1.
b.     Enable dropping unknown IPv6 multicast data.
c.     Enable MLD querier.
Figure 3 Configuring MLD snooping for VLAN 10
7.     Click Apply.
Configuring MLD snooping on switches
On Switch A and Switch B, enable MLDv1 snooping and enable dropping unknown IPv6 multicast packets for VLAN 10.
Verify that an MLD snooping forwarding entry is created for multicast group FF1E::101 after Host A or Host B joins the multicast group. (Details not shown.)
Related documentation
H3C Access Controllers Web-Based Configuration Guide
