07-Comware 7 Web-based configuration examples (AC+fit AP deployment)
HomeSupportDoc SetsDoc PackagesH3C Wireless Products All-in-One-6W10207-Comware 7 Web-based configuration examples (AC+fit AP deployment)
Table of Contents
Related Documents
16-Static IPv4 DNS Configuration Example
16-Static IPv4 DNS Configuration Example 82.15 KB
H3C Access Controllers
Comware 7 Static IPv4 DNS
Copyright © 2023 New H3C Technologies Co., Ltd. All rights reserved.
Overview
The following information provides an example for configuring static IPv4 DNS to allow users to access a host.
The following information applies to Comware 7-based access controllers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the H3C access controllers.
The following information is provided based on the assumption that you have basic knowledge of DNS.
Example: Configuring static IPv4 DNS
As shown in Figure 1, the host at 10.1.1.2 is named host.com. Configure static IPv4 DNS on the AC so that the AC can use the easy-to-remember domain name rather than the IP address to access the host.
Figure 1 Network diagram
Make sure the network connections are available.
Procedures
1.     Click the System View tab at the bottom of the page.
2.     From the navigation pane, select Network Configuration > Network Services > DHCP/DNS.
3.     Click the IPv4 DNS tab.
4.     Click Manual.
5.     Enter host name host.com and IP address 10.1.1.2.
Figure 2 Configuring a static DNS mapping
6.     Click the Add icon .
# Verify that the AC can use the static domain name resolution to resolve domain name host.com into IP address 10.1.1.2.
<AC> ping host.com
Ping host.com (10.1.1.2): 56 data bytes, press CTRL_C to break
56 bytes from 10.1.1.2: icmp_seq=0 ttl=128 time=0.599 ms
56 bytes from 10.1.1.2: icmp_seq=1 ttl=128 time=0.488 ms
56 bytes from 10.1.1.2: icmp_seq=2 ttl=128 time=0.370 ms
56 bytes from 10.1.1.2: icmp_seq=3 ttl=128 time=0.524 ms
56 bytes from 10.1.1.2: icmp_seq=4 ttl=128 time=0.398 ms
--- Ping statistics for host.com ---
round-trip min/avg/max/std-dev = 0.370/0.476/0.599/0.084 ms
Related documentation
H3C Access Controllers Web-Based Configuration Guide
