07-Comware 7 Web-based configuration examples (AC+fit AP deployment)
HomeSupportDoc SetsDoc PackagesH3C Wireless Products All-in-One-6W10207-Comware 7 Web-based configuration examples (AC+fit AP deployment)
Table of Contents
Related Documents
11-Layer 2 Static Link Aggregation Configuration Example
H3C Access Controllers
Comware 7 Layer 2 Static Link Aggregation
Copyright © 2023 New H3C Technologies Co., Ltd. All rights reserved.
Overview
The following information provides an example for configuring Layer 2 static link aggregation.
The following information applies to Comware 7-based access controllers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the H3C access controllers.
The following information is provided based on the assumption that you have basic knowledge of Layer 2 static link aggregation.
Example: Configuring a Layer 2 static link aggregation group
As shown in Figure 1, set up a static aggregate link between AC 1 and AC 2.
Figure 1 Network diagram
Procedures
Configuring an aggregation group on AC 1
1.     Click the System View tab at the bottom of the page.
2.     From the navigation pane, select Network Settings > Interfaces > Link Aggregation.
3.     Click the Create button  to create aggregation group 1.
Figure 2 Creating an aggregation group
4.     Set the aggregation mode to static and assign GigabitEthernet 1/0/1 through GigabitEthernet 1/0/3 to aggregation group 1.
Figure 3 Configuring an aggregation group
5.     Click the System View tab at the bottom of the page.
6.     From the navigation pane, select Network Settings > VLAN.
Figure 4 VLAN list
7.     Click the Create VLANs button  to create VLAN 10.
Figure 5 Creating a VLAN
8.     Click the Edit button  for VLAN 10 to assign GigabitEthernet 1/0/4 as an untagged member and GigabitEthernet 1/0/1 through GigabitEthernet 1/0/3 as tagged members to the VLAN.
Figure 6 Adding physical interfaces
Configuring an aggregation group on AC 2
Configure AC 2 in the same way you configured AC 1. (Details not shown.)
1.     Verify that GigabitEthernet 1/0/1 through GigabitEthernet 1/0/3 have been assigned to aggregation group 1 on the ACs. (Details not shown.)
2.     Verify that Host A can ping Host B. (Details not shown.)
3.     Verify that Host A can ping Host B when one of the links between the ACs fails. (Details not shown.)
Related documentation
H3C Access Controllers Web-Based Configuration Guide
