07-Comware 7 Web-based configuration examples (AC+fit AP deployment)
HomeSupportDoc SetsDoc PackagesH3C Wireless Products All-in-One-6W10207-Comware 7 Web-based configuration examples (AC+fit AP deployment)
Table of Contents
Related Documents
31-Different Wireless Services on Different Radios Configuration Example
H3C Access Controllers
Comware 7 Different Wireless Services on Different Radios
Configuration Examples
Copyright © 2023 New H3C Technologies Co., Ltd. All rights reserved.
Overview
The following information provides an example for binding wireless services with different SSIDs to radios at different frequency bands.
The following information applies to Comware 7-based access controllers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the H3C access controllers.
Example: Configuring different wireless services on different radios
As shown in Figure 1, in centralized forwarding, the AC is attached to Layer 2 switch 1 in hair-pin mode. The Layer 3 switch acts as the DHCP server to assign IP addresses to the AP and the clients. Configure wireless network settings for the clients to associate with the AC through the AP and visit the host.
·     Configure Client 1 to access the WLAN with SSID service1 through VLAN 201, Client 2 to access the WLAN with SSID service2 through VLAN 202, and the host to access the network through VLAN 300.
·     Establish a Layer 2 connection between the AC and the AP and configure them to exchange packets in VLAN 100.
·     Configure Layer 2 switch 1 to supply power to the AP through PoE.
Figure 1 Network diagram
Analysis
·     Enable the DHCP server feature on the Layer 3 switch for the AP, clients, and the host to obtain IP addresses automatically through DHCP.
·     Enable PoE on Layer 2 switch 1 to supply power to the AP.
·     Configure wireless services with different SSIDs on the AC for clients to access different WLANs and reach the host.
Use the serial ID labeled on the AP's rear panel to specify an AP.
Procedures
Configuring the Layer 3 switch
# Configure VLANs and VLAN interfaces.
<L3 switch> system-view
[L3 switch] vlan 100
[L3 switch-vlan100] quit
[L3 switch] vlan 201
[L3 switch-vlan201] quit
[L3 switch] vlan 202
[L3 switch-vlan202] quit
[L3 switch] vlan 300
[L3 switch-vlan300] quit
[L3 switch] interface gigabitethernet 1/0/1
[L3 switch-GigabitEthernet1/0/1] port link-type trunk
[L3 switch-GigabitEthernet1/0/1] port trunk permit vlan 100 201 202
[L3 switch-GigabitEthernet1/0/1] quit
[L3 switch] interface gigabitethernet 1/0/3
[L3 switch-GigabitEthernet1/0/3] port link-type trunk
[L3 switch-GigabitEthernet1/0/3] undo port trunk permit vlan 1
[L3 switch-GigabitEthernet1/0/3] port trunk permit vlan 300
[L3 switch-GigabitEthernet1/0/3] quit
[L3 switch] interface vlan-interface 100
[L3 switch-Vlan-interface100] ip address 192.168.10.1 255.255.255.0
[L3 switch-Vlan-interface100] quit
[L3 switch] interface vlan-interface 201
[L3 switch-Vlan-interface201] ip address 192.168.21.1 255.255.255.0
[L3 switch-Vlan-interface201] quit
[L3 switch] interface vlan-interface 202
[L3 switch-Vlan-interface202] ip address 192.168.22.1 255.255.255.0
[L3 switch-Vlan-interface202] quit
[L3 switch] interface vlan-interface 300
[L3 switch-Vlan-interface300] ip address 192.168.30.1 255.255.255.0
[L3 switch-Vlan-interface300] quit
# Enable the DHCP server feature.
[L3 switch] dhcp enable
# Create DHCP address pool 1, specify the subnet as 192.168.10.0/24, specify the gateway address as 192.168.10.1, and exclude the AC IP address (192.168.10.2) from IP address allocation. This address pool will be used to assign an IP address to the AP.
[L3 switch] dhcp server ip-pool 1
[L3 switch-dhcp-pool-1] network 192.168.10.0 mask 255.255.255.0
[L3 switch-dhcp-pool-1] gateway-list 192.168.10.1
[L3 switch-dhcp-pool-1] forbidden-ip 192.168.10.2
[L3 switch-dhcp-pool-1] quit
# Create DHCP address pool 2, specify the subnet as 192.168.21.0/24, specify the gateway address as 192.168.21.1, and specify the DNS server address. In this example, the gateway address is also the DNS server address. This address pool will be used to assign an IP address to Client 1.
[L3 switch] dhcp server ip-pool 2
[L3 switch-dhcp-pool-2] network 192.168.21.0 mask 255.255.255.0
[L3 switch-dhcp-pool-2] gateway-list 192.168.21.1
[L3 switch-dhcp-pool-2] dns-list 192.168.21.1
[L3 switch-dhcp-pool-2] quit
# Create DHCP address pool 3, specify the subnet as 192.168.22.0/24, specify the gateway address as 192.168.22.1, and specify the DNS server address. In this example, the gateway address is also the DNS server address. This address pool will be used to assign an IP address to Client 2.
[L3 switch] dhcp server ip-pool 3
[L3 switch-dhcp-pool-3] network 192.168.22.0 mask 255.255.255.0
[L3 switch-dhcp-pool-3] gateway-list 192.168.22.1
[L3 switch-dhcp-pool-3] dns-list 192.168.22.1
[L3 switch-dhcp-pool-3] quit
# Create DHCP address pool 4, specify the subnet as 192.168.30.0/24, and specify the gateway address as 192.168.30.1. This address pool will be used to assign an IP address to the host.
[L3 switch] dhcp server ip-pool 4
[L3 switch-dhcp-pool-4] network 192.168.30.0 mask 255.255.255.0
[L3 switch-dhcp-pool-4] gateway-list 192.168.30.1
[L3 switch-dhcp-pool-4] quit
Configuring Layer 2 switch 1
<L2 switch 1> system-view
[L2 switch 1] vlan 100
[L2 switch 1-vlan100] port gigabitethernet 1/0/2
[L2 switch 1-vlan100] quit
[L2 switch 1] vlan 201
[L2 switch 1-vlan201] quit
[L2 switch 1] vlan 202
[L2 switch 1-vlan202] quit
[L2 switch 1] interface gigabitethernet 1/0/1
[L2 switch 1-GigabitEthernet1/0/1] port link-type trunk
[L2 switch 1-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[L2 switch 1-GigabitEthernet1/0/1] port trunk permit vlan 100 201 202
[L2 switch 1-GigabitEthernet1/0/1] quit
[L2 switch 1] interface gigabitethernet 1/0/3
[L2 switch 1-GigabitEthernet1/0/3] port link-type trunk
[L2 switch 1-GigabitEthernet1/0/3] undo port trunk permit vlan 1
[L2 switch 1-GigabitEthernet1/0/3] port trunk permit vlan 100 201 202
[L2 switch 1-GigabitEthernet1/0/3] quit
# Enable PoE.
[L2 switch 1] interface gigabitethernet 1/0/2
[L2 switch 1-GigabitEthernet1/0/2] poe enable
[L2 switch 1-GigabitEthernet1/0/2] quit
Configuring Layer 2 switch 2
<L2 switch 2> system-view
[L2 switch 2] vlan 300
[L2 switch 2-vlan300] port gigabitethernet 1/0/2
[L2 switch 2-vlan300] quit
[L2 switch 2] interface gigabitethernet 1/0/1
[L2 switch 2-GigabitEthernet1/0/1] port link-type trunk
[L2 switch 2-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[L2 switch 2-GigabitEthernet1/0/1] port trunk permit vlan 300
[L2 switch 2-GigabitEthernet1/0/1] quit
Configuring the AC
Configure the AC interfaces
1.     Click System View at the bottom of the page.
2.     From the left navigation pane, select Network Configuration > VLAN.
3.     Click the plus sign , and then perform the following tasks:
¡     Create VLAN 100, and assign IP address to 192.168.10.2/24 VLAN-interface 100.
¡     Create VLANs 201 and 202.
Figure 2 Configuring VLANs
4.     From the left navigation pane, select Network Configuration > Network Interfaces. On the Interfaces tab, configure GE1/0/1 as follows:
¡     Set the link type to Trunk.
¡     Enter 100,201,202 in the permit VLAN field.
Figure 3 Configuring interface GE1/0/1
Configuring wireless services
1.     Click Network View at the bottom of the page.
2.     From the left navigation pane, select Wireless Configuration > Wireless Networks.
¡     Specify the wireless service name as 1.
¡     Set the SSID to service1.
¡     Enable the wireless service.
Figure 4 Configuring a wireless service
4.     Repeat the previous step to configure wireless service 2. Set the SSID of wireless service 2 to service2.
Configuring the AP
2.     From the left navigation pane, select Wireless Configuration > AP Management.
¡     Specify the AP name as officeap.
¡     Specify the AP model and serial number.
4.     On the Wireless Configuration > AP Management page, click the edit icon for AP officeap, and bind wireless service 1 and VLAN 201 to the 5 GHz radio of the AP on the Wireless Service Settings tab.
Figure 5 Binding a wireless service to a radio
5.     Repeat the previous step to bind wireless service 2 and VLAN 202 to the 2.4 GHz radio.
6.     From the left navigation pane, select Wireless Configuration > Radio Management.
7.     On the Radio Configuration tab, click the  icon to the upper right in the Radios of all APs section, and select the 5GHz radio of AP officeap. Configure the radio as follows:
¡     Specify the radio mode as 802.11ax (5GHz).
¡     Select the working channel as 149.
¡     Enable the radio.
Figure 6 Configuring the 5GHz radio
8.     Repeat the previous step to configure the 2.4 GHz radio. Set the radio mode to 802.11n (2.4GHz) and set the channel to 11.
2.     From the left navigation pane, select Monitoring > Access Points. On the APs tab, verify that the AP is online.
3.     From the left navigation pane, select Monitoring > Clients. In the By SSID section, verify that a 5GHz client is in the WLAN whose SSID is service1, and a 2.4GHz client is in the WLAN whose SSID is service2.
