07-Comware 7 Web-based configuration examples (AC+fit AP deployment)
HomeSupportDoc SetsDoc PackagesH3C Wireless Products All-in-One-6W10207-Comware 7 Web-based configuration examples (AC+fit AP deployment)
Table of Contents
Related Documents
54-WLAN Probe Configuration Example
54-WLAN Probe Configuration Example 116.92 KB
H3C Access Controllers
Comware 7 WLAN Probe Configuration Example
Copyright © 2023 New H3C Technologies Co., Ltd. All rights reserved.
Overview
The following information provides an example for configuring WLAN probe.
The following information applies to Comware 7-based access controllers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the H3C access controllers.
The following information is provided based on the assumption that you have basic knowledge of WLAN probe and WLAN access.
Example: Configuring WLAN probe
As shown in Figure 1, AP 1 and AP 2 provide wireless services for clients through SSID abc. Enable WLAN probe on the sensor to monitor the WLAN and report the detected device information to the server.
Figure 1 Network diagram
Procedures
Configuring basic features on the AC
Configure AP access, wireless service, and radio settings. (Details not shown.)
Enabling WLAN probe
1.     Click the Network View tab at the bottom of the page.
2.     From the navigation pane, select Wireless Configuration > Client Proximity Sensor.
3.     Select AP sensor, and then click On.
Figure 2 Enabling sensor
2.     From the navigation pane, select Monitoring > Client Proximity Sensor, and then view the relevant information shown in the Statistics area.
Figure 3 Verifying sensor configuration
Related documentation
H3C Access Controllers Web-Based Configuration Guide
