07-Comware 7 Web-based configuration examples (AC+fit AP deployment)
HomeSupportDoc SetsDoc PackagesH3C Wireless Products All-in-One-6W10207-Comware 7 Web-based configuration examples (AC+fit AP deployment)
Table of Contents
Related Documents
53-CAC Configuration Example
53-CAC Configuration Example 131.62 KB
H3C Access Controllers
Comware 7 CAC Configuration Example
Copyright © 2023 New H3C Technologies Co., Ltd. All rights reserved.
Overview
The following information provides an example for configuring Connect Admission Control (CAC) to limit the number of clients that can use high-priority AC queues.
The following information applies to Comware 7-based access controllers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the H3C access controllers.
The following information is provided based on the assumption that you have basic knowledge of CAC.
Example: Configuring CAC
As shown in Figure 1, configure CAC to allow only one client to use the AC-VO and AC-VI queues at one time to guarantee bandwidth for high-priority traffic.
Figure 1 Network diagram
Procedures
1.     Click the Network View tab at the bottom of the page.
2.     From the navigation pane, select Wireless Configuration > Wireless QoS.
3.     On the Wi-Fi Multimedia tab, click the More icon  from the EDCA parameters for clients area.
4.     Click the Edit icon  for the target radio and configure EDCA parameters as follows:
¡     Select Based on number of clients from the CAC policy field.
¡     Set the maximum number of clients to 1.
¡     Select Enable for AC-VI and AC-VO.
Figure 2 Configuring EDCA parameters
# Verify that the other clients cannot use a high-priority AC queue (AC-VO or AC-VI) when an online client already uses a high-priority AC queue.
Related documentation
H3C Access Controllers Web-Based Configuration Guide
