07-Comware 7 Web-based configuration examples (AC+fit AP deployment)
HomeSupportDoc SetsDoc PackagesH3C Wireless Products All-in-One-6W10207-Comware 7 Web-based configuration examples (AC+fit AP deployment)
Table of Contents
Related Documents
52-Blacklist-Based Client Access Control Configuration Example
H3C Access Controllers
Comware 7 Static Blacklist-Based Client Access Control Configuration Example
Copyright © 2023 New H3C Technologies Co., Ltd. All rights reserved.
Overview
The following information provides an example for configuring static blacklist-based client access control.
The following information applies to Comware 7-based access controllers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the H3C access controllers.
The following information is provided based on the assumption that you have basic knowledge of the static client blacklist.
Example: Configuring static blacklist-based client access control
As shown in Figure 1, configure the static blacklist to forbid the client whose MAC address is 4c-c0-0a-df-f6-4f to access the WLAN.
Figure 1 Network diagram
Procedures
1.     Click the Network View tab at the bottom of the page.
2.     From the navigation pane, select Wireless Configuration > Wireless Security.
3.     On the Whitelist and blacklist tab, click the More icon  from the Static Blacklist area.
4.     Click the Add button  to add MAC address 4c-c0-0a-df-f6-4f to the static blacklist.
Figure 2 Adding a MAC address to the static blacklist
3.     On the Whitelist and blacklist tab, verify that MAC address 4c-c0-0a-df-f6-4f has been added to the static blacklist.
Figure 3 Verifying static blacklist configuration
4.     Verify that the client whose MAC address is 4c-c0-0a-df-f6-4f cannot access the WLAN and the other clients can access the WLAN.
Related documentation
H3C Access Controllers Web-Based Configuration Guide
