07-Comware 7 Web-based configuration examples (AC+fit AP deployment)
HomeSupportDoc SetsDoc PackagesH3C Wireless Products All-in-One-6W10207-Comware 7 Web-based configuration examples (AC+fit AP deployment)
Table of Contents
Related Documents
01-Telnet Access Control Configuration Example
01-Telnet Access Control Configuration Example 120.85 KB
H3C Access Controllers
Copyright © 2023 New H3C Technologies Co., Ltd. All rights reserved.
Overview
The following information provides an example for configuring Telnet access control.
The following information applies to Comware 7-based access controllers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the H3C access controllers.
The following information is provided based on the assumption that you have basic knowledge of Telnet access control.
Example: Configuring Telnet access control
As shown in Figure 1, the AC is a Telnet server.
Configure the AC to permit only Telnet packets sourced from 192.168.100.22.
Figure 1 Network diagram
Make sure the network connections are available.
Procedures
Configuring an ACL
1.     Click the System View tab at the bottom of the page.
2.     From the navigation pane, select System > Resource.
3.     On the IPv4 ACL tab, click the Add button  to create an IPv4 ACL:
¡     Select Basic.
¡     Enter ACL number 2000.
¡     Click Apply.
Figure 2 Configuring an ACL
4.     Configure an ACL rule:
¡     Select the Source IP address/wildcard mask match criterion, and enter 192.168.100.22 as the IP address and 0.0.0.0 as the wildcard mask.
¡     Clear the Continue to add next rule option.
¡     Click Apply.
Figure 3 Configuring an ACL rule
Applying the ACL to the Telnet service
2.     From the navigation pane, select Network Configuration > Management Protocols.
3.     In the Telnet area, click the expand icon  for Advanced settings and apply the ACL to the Telnet service:
¡     Select ACL 2000 for Use an ACL to control IPv4 Telnet access.
¡     Click Apply.
Figure 4 Applying the ACL to the Telnet service
1.     Telnet to the AC from Host A.
C:> telnet 192.168.100.133
Trying 192.168.100.133 ...
Press CTRL+K to abort
Connected to 192.168.100.133 ...
* Copyright (c) 2004-2018 New H3C Technologies Co., Ltd. All rights reserved.*
<AC>
2.     Telnet to the AC from Host B.
C:\> telnet 192.168.100.133
Failed to connect to the remote host!
Related documentation
H3C Access Controllers Web-Based Configuration Guide
