07-Comware 7 Web-based configuration examples (AC+fit AP deployment)
HomeSupportDoc SetsDoc PackagesH3C Wireless Products All-in-One-6W10207-Comware 7 Web-based configuration examples (AC+fit AP deployment)
Table of Contents
Related Documents
37-AP Group Configuration Example
37-AP Group Configuration Example 204.58 KB
H3C Access Controllers
Comware 7 AP Group Configuration Example
Copyright © 2023 New H3C Technologies Co., Ltd. All rights reserved.
Overview
The following information provides an example for configuring AP groups.
The following information applies to Comware 7-based access controllers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the H3C access controllers.
The following information is provided based on the assumption that you have basic knowledge of AP groups.
Example: Configuring AP groups
As shown in Figure 1, configure AP groups and add AP 1 to AP group group1, and AP 2, AP 3, and AP 4 to AP group group2.
Figure 1 Network diagram
Procedures
Configuring the DHCP server
# Configure APs to obtain their IP addresses and the AC IP address from the DHCP server. (Details not shown.)
1.     Click the Network View tab at the bottom of the page.
2.     From the navigation pane, select Wireless Configuration > AP Management.
3.     Click the AP Groups tab.
4.     Click the Add button .
¡     Specify the group name as group1.
¡     Create AP name grouping rules to add the AP with name ap1 to the group.
Figure 2 Configuring AP groups
5.     Repeat the previous step to create AP group group2 and add APs with name ap2, ap3, and ap4 to the group.
4.     Select an AP group and click View AP List to view APs in each group. Verify that AP ap1 is in group group1 and APs ap2, ap3, and ap4 are in group group2.
Figure 3 Displaying APs in AP group group1
Figure 4 Displaying APs in AP group group2
Related documentation
H3C Access Controllers Web-Based Configuration Guide
