- H3C S6805 & S6825 & S6850 & S9850 & S9820 Config Examples-Release 66xx-6W100
- 01-Login Management Configuration Examples
- 02-RBAC Configuration Examples
- 03-Software Upgrade Examples
- 04-ISSU Configuration Examples
- 05-Software Patching Examples
- 06-Ethernet Link Aggregation Configuration Examples
- 07-Port Isolation Configuration Examples
- 08-Spanning Tree Configuration Examples
- 09-VLAN Configuration Examples
- 10-VLAN Tagging Configuration Examples
- 11-DHCP Snooping Configuration Examples
- 12-Cross-Subnet Dynamic IP Address Allocation Configuration Examples
- 13-IPv6 over IPv4 Manual Tunneling with OSPFv3 Configuration Examples
- 14-ISATAP Tunnel and 6to4 Tunnel Configuration Examples
- 15-GRE Tunnel Configuration Examples
- 16-GRE with OSPF Configuration Examples
- 17-OSPF Configuration Examples
- 18-IS-IS Configuration Examples
- 19-BGP Configuration Examples
- 20-Policy-Based Routing Configuration Examples
- 21-OSPFv3 Configuration Examples
- 22-IPv6 IS-IS Configuration Examples
- 23-Routing Policy Configuration Examples
- 24-IGMP Snooping Configuration Examples
- 25-IGMP Configuration Examples
- 26-BIDIR-PIM Configuration Examples
- 27-MLD Snooping Configuration Examples
- 28-IPv6 Multicast VLAN Configuration Examples
- 29-Basic MPLS Configuration Examples
- 30-MPLS L3VPN Configuration Examples
- 31-ACL Configuration Examples
- 32-Control Plane-Based QoS Policy Configuration Examples
- 33-Traffic Policing Configuration Examples
- 34-GTS and Rate Limiting Configuration Examples
- 35-Priority Mapping and Queue Scheduling Configuration Examples
- 36-Traffic Filtering Configuration Examples
- 37-AAA Configuration Examples
- 38-Port Security Configuration Examples
- 39-Portal Configuration Examples
- 40-SSH Configuration Examples
- 41-IP Source Guard Configuration Examples
- 42-Ethernet OAM Configuration Examples
- 43-CFD Configuration Examples
- 44-DLDP Configuration Examples
- 45-VRRP Configuration Examples
- 46-BFD Configuration Examples
- 47-NTP Configuration Examples
- 48-SNMP Configuration Examples
- 49-NQA Configuration Examples
- 50-Mirroring Configuration Examples
- 51-sFlow Configuration Examples
- 52-FCoE Configuration Examples
- 53-OpenFlow Configuration Examples
- 54-MAC Address Table Configuration Examples
- 55-Static Multicast MAC Address Entry Configuration Examples
- 56-IP Unnumbered Configuration Examples
- 57-MVRP Configuration Examples
- 58-MCE Configuration Examples
- 59-Congestion Avoidance and Queue Scheduling Configuration Examples
- 60-Attack Protection Configuration Examples
- 61-Smart Link Configuration Examples
- 62-RRPP Configuration Examples
- 63-BGP Route Selection Configuration Examples
- 64-IS-IS Route Summarization Configuration Examples
- 65-IRF Configuration Examples
- 66-MPLS OAM Configuration Examples
- 67-MPLS TE Configuration Examples
- 68-VXLAN Configuration Examples
- 69-NetStream Configuration Examples
- 70-DRNI Configuration Examples
- 71-DRNI and EVPN Configuration Examples
- 72-EVPN-DCI over an MPLS L3VPN Network Configuration Examples
- 73-VCF Fabric Configuration Examples
- 74-PTP Configuration Examples
- 75-S-MLAG Configuration Examples
- 76-Puppet Configuration Examples
- 77-802.1X Configuration Examples
- 78-MAC Authentication Configuration Examples
- 79-MOD and Elephant and Mice Flow Configuration Examples
- 80-TCB Configuration Examples
- 81-Multicast VPN Configuration Examples
| 64-IS-IS Route Summarization Configuration Examples | 94.29 KB |
H3C S6805&S6825&S6850&S9850&S9820 |
IS-IS Route Summarization |
Copyright © 2020-2023 New H3C Technologies Co., Ltd. All rights reserved.
Example: Configuring IS-IS route summarization
Configuring IP addresses for interfaces
Introduction
This document provides IS-IS route summarization configuration examples.
This document assumes that you have basic knowledge of IS-IS route summarization.
As shown in Figure 1, the five departments of a company use IS-IS to connect to the backbone network. The five departments are assigned the networks 192.168.1.0/24, 192.168.2.0/24, 192.168.3.0/24, 192.168.4.0/24, and 192.168.5.0/24. Configure IS-IS route summarization to reduce routing entries and save system resources for Device B.
Device |
IP address |
Device |
IP address |
Device A |
Vlan-int10 |
172.16.1.1/24 |
Device B |
Vlan-int10 |
172.168.1.2/24 |
Vlan-int101 |
10.1.1.1/24 |
GW 1 |
Vlan-int101 |
10.1.1.2/24 |
Vlan-int102 |
10.1.2.1/24 |
GW 2 |
Vlan-int102 |
10.1.2.2/24 |
Vlan-int103 |
10.1.3.1/24 |
GW3 |
Vlan-int103 |
10.1.3.2/24 |
Analysis
Configure route summarization on Device A because route summarization applies only to locally generated LSPs.
To avoid blackhole routes, set the summary route to 192.168.0.0/22.
Hardware |
Software version |
S6805 switch series |
Release 6607, Release 6616, Release 6616P01, Release 6635 and later |
S6825 switch series |
S6850 switch series S9850 switch series |
Release 6555P01, Release 6607, Release 6616, Release 6616P01, Release 6635 and later |
S9820-64H switch |
S9820-8C switch |
Procedures
# Configure an IP address for the interface VLAN-interface 10 on Device A.
[DeviceA-Vlan-interface10] ip address 172.16.1.1 24
# Configure IP addresses for other interfaces as shown in Figure 1 in the same way VLAN-interface 10 is configured. (Details not shown.)
Configuring basic IS-IS
Configuring Device A
# Enable IS-IS on Device A and configure Device A as a Level-1-2 router.
[DeviceA] isis 1
[DeviceA-isis-1] network-entity 10.0000.0000.0001.00
[DeviceA-isis-1] is-level level-1-2
[DeviceA-isis-1] quit
# Enable IS-IS on the interface VLAN-interface 10.
[DeviceA–Vlan-interface10] isis enable 1
[DeviceA–Vlan-interface10] quit
# Configure other interfaces in the same way VLAN-interface 10 is configured. (Details not shown.)
Configuring Device B
# Enable IS-IS on Device B and configure Device B as a Level-2 router.
[DeviceB] isis 1
[DeviceB-isis-1] network-entity 10.0000.0000.0002.00
[DeviceB-isis-1] is-level level-2
[DeviceB-isis-1] quit
[DeviceB] interface vlan-interface 10
[DeviceB–Vlan-interface10] isis enable 1
[DeviceB–Vlan-interface10] quit
Configuring the gateways
# Enable IS-IS on GW 1 and configure GW 1 as a Level-1 router.
[GW1] isis 1
[GW1-isis-1] network-entity 10.0001.0001.0001.00
[GW1-isis-1] is-level level-1
[GW1-isis-1] quit
# Enable IS-IS on the interface VLAN-interface 11.
[GW1] interface vlan-interface 11
[GW1–Vlan-interface11] isis enable 1
[GW1–Vlan-interface11] quit
# Configure other gateways in the same way GW 1 is configured. (Details not shown.)
Displaying IS-IS routing information on Device B
# Display IS-IS routing information on Device B to view the network address of each department.
[DeviceB] display isis route
Level-2 IPv4 Forwarding Table
IPv4 Destination IntCost ExtCost ExitInterface NextHop Flags
192.168.1.0/24 30 NULL Vlan10 172.16.1.1 R/-/-
10.1.1.0/24 20 NULL Vlan10 172.16.1.1 R/-/-
192.168.2.0/24 30 NULL Vlan10 172.16.1.1 R/-/-
10.1.2.0/24 20 NULL Vlan10 172.16.1.1 R/-/-
192.168.3.0/24 30 NULL Vlan10 172.16.1.1 R/-/-
10.1.3.0/24 20 NULL Vlan10 172.16.1.1 R/-/-
172.16.1.0/24 10 NULL Vlan10 Direct D/L/-
# Configure IS-IS route summarization on Device A.
[DeviceA] isis 1
[DeviceA] address-family ipv4
[DeviceA-isis-1-ipv4]summary 192.168.0.0 22
# Display IS-IS routing information on Device B.
192.168.0.0/22 30 NULL Vlan10 172.16.1.1 R/-/-
The output shows that the networks have been summarized into a single network 192.168.0.0/22.
Configuration files
· Device A:
isis 1
address-family ipv4 unicast
summary 192.168.0.0 255.255.252.0
vlan 10
vlan 101 to 103
interface vlan-interface10
ip address 172.16.1.1 255.255.255.0
isis enable 1
interface vlan-interface101
isis enable 1
interface vlan-interface102
ip address 10.1.2.1 255.255.255.0
isis enable 1
interface vlan-interface103
ip address 10.1.3.1 255.255.255.0
isis enable 1
· Device B:
isis 1
is-level level-2
vlan 10
ip address 172.16.1.2 255.255.255.0
isis enable 1
· GW 1:
isis 1
is-level level-1
vlan 11
vlan 101
isis enable 1
interface vlan-interface11
isis enable 1
· The configuration files for other gateways are similar to the configuration file for GW 1. (Details not shown.)
Related documentation
Use this document in conjunction with the following documents for the product and software version you are working with:
· Layer 3—IP Routing Configuration Guide
· Layer 3—IP Routing Command Reference
