- H3C S6805 & S6825 & S6850 & S9850 & S9820 Config Examples-Release 66xx-6W100
- 01-Login Management Configuration Examples
- 02-RBAC Configuration Examples
- 03-Software Upgrade Examples
- 04-ISSU Configuration Examples
- 05-Software Patching Examples
- 06-Ethernet Link Aggregation Configuration Examples
- 07-Port Isolation Configuration Examples
- 08-Spanning Tree Configuration Examples
- 09-VLAN Configuration Examples
- 10-VLAN Tagging Configuration Examples
- 11-DHCP Snooping Configuration Examples
- 12-Cross-Subnet Dynamic IP Address Allocation Configuration Examples
- 13-IPv6 over IPv4 Manual Tunneling with OSPFv3 Configuration Examples
- 14-ISATAP Tunnel and 6to4 Tunnel Configuration Examples
- 15-GRE Tunnel Configuration Examples
- 16-GRE with OSPF Configuration Examples
- 17-OSPF Configuration Examples
- 18-IS-IS Configuration Examples
- 19-BGP Configuration Examples
- 20-Policy-Based Routing Configuration Examples
- 21-OSPFv3 Configuration Examples
- 22-IPv6 IS-IS Configuration Examples
- 23-Routing Policy Configuration Examples
- 24-IGMP Snooping Configuration Examples
- 25-IGMP Configuration Examples
- 26-BIDIR-PIM Configuration Examples
- 27-MLD Snooping Configuration Examples
- 28-IPv6 Multicast VLAN Configuration Examples
- 29-Basic MPLS Configuration Examples
- 30-MPLS L3VPN Configuration Examples
- 31-ACL Configuration Examples
- 32-Control Plane-Based QoS Policy Configuration Examples
- 33-Traffic Policing Configuration Examples
- 34-GTS and Rate Limiting Configuration Examples
- 35-Priority Mapping and Queue Scheduling Configuration Examples
- 36-Traffic Filtering Configuration Examples
- 37-AAA Configuration Examples
- 38-Port Security Configuration Examples
- 39-Portal Configuration Examples
- 40-SSH Configuration Examples
- 41-IP Source Guard Configuration Examples
- 42-Ethernet OAM Configuration Examples
- 43-CFD Configuration Examples
- 44-DLDP Configuration Examples
- 45-VRRP Configuration Examples
- 46-BFD Configuration Examples
- 47-NTP Configuration Examples
- 48-SNMP Configuration Examples
- 49-NQA Configuration Examples
- 50-Mirroring Configuration Examples
- 51-sFlow Configuration Examples
- 52-FCoE Configuration Examples
- 53-OpenFlow Configuration Examples
- 54-MAC Address Table Configuration Examples
- 55-Static Multicast MAC Address Entry Configuration Examples
- 56-IP Unnumbered Configuration Examples
- 57-MVRP Configuration Examples
- 58-MCE Configuration Examples
- 59-Congestion Avoidance and Queue Scheduling Configuration Examples
- 60-Attack Protection Configuration Examples
- 61-Smart Link Configuration Examples
- 62-RRPP Configuration Examples
- 63-BGP Route Selection Configuration Examples
- 64-IS-IS Route Summarization Configuration Examples
- 65-IRF Configuration Examples
- 66-MPLS OAM Configuration Examples
- 67-MPLS TE Configuration Examples
- 68-VXLAN Configuration Examples
- 69-NetStream Configuration Examples
- 70-DRNI Configuration Examples
- 71-DRNI and EVPN Configuration Examples
- 72-EVPN-DCI over an MPLS L3VPN Network Configuration Examples
- 73-VCF Fabric Configuration Examples
- 74-PTP Configuration Examples
- 75-S-MLAG Configuration Examples
- 76-Puppet Configuration Examples
- 77-802.1X Configuration Examples
- 78-MAC Authentication Configuration Examples
- 79-MOD and Elephant and Mice Flow Configuration Examples
- 80-TCB Configuration Examples
- 81-Multicast VPN Configuration Examples
| 53-OpenFlow Configuration Examples | 110.45 KB |
H3C S6805&S6825&S6850&S9850&S9820 |
Copyright © 2023 New H3C Technologies Co., Ltd. All rights reserved.
General restrictions and guidelines
Example: Configuring OpenFlow to deploy flow entries
Introduction
This document provides examples for configuring OpenFlow.
OpenFlow separates the control plane and the data forwarding plane. An OpenFlow switch matches packets against one or more flow tables. A flow table contains one or more flow entries that are deployed by the controller and packets are matched based on the matching precedence of flow entries.
These examples use VLAN-interface 1.
This document assumes that you have basic knowledge of OpenFlow.
When you configure OpenFlow, follow these restrictions and guidelines:
· Enable LLDP globally on OpenFlow switches so that the controller can learn the OpenFlow topology through LLDP.
· Configure each OpenFlow switch with an interface for communicating with the controller so that OpenFlow instances can establish connections with the controller.
· Configure the Loosen mode when you associate VLAN 4092 and VLAN 4094 with an OpenFlow instance so that the access ports of switches can belong to the OpenFlow instance.
As shown in Figure 1, configure OpenFlow to meet the following requirements:
· The controller can deploy dynamic flow entries.
· Host A and Host C can communicate with each other based on the flow entries deployed by the controller.
· Host B and Host D can communicate with each other based on the flow entries deployed by the controller.
Hardware |
Software version |
S6805 switch series |
Release 6607, Release 6616, Release 6616P01, Release 6635 and later |
S6825 switch series |
S6850 switch series S9850 switch series |
Release 6555P01, Release 6607, Release 6616, Release 6616P01, Release 6635 and later |
S9820-64H switch |
S9820-8C switch |
Procedures
Configuring Switch A
# Create VLAN 4092 and VLAN 4094.
[SwitchA] vlan 4092
[SwitchA-vlan4092] quit
[SwitchA] vlan 4094
[SwitchA-vlan4094] quit
# Configure HundredGigE 3/0/1, HundredGigE 3/0/2, and HundredGigE 3/0/3.
[SwitchA] interface hundredgige 3/0/1
[SwitchA-HundredGigE3/0/1] port access vlan 4092
[SwitchA-HundredGigE3/0/1] quit
[SwitchA] interface hundredgige 3/0/2
[SwitchA-HundredGigE3/0/2] port access vlan 4094
[SwitchA-HundredGigE3/0/2] quit
[SwitchA] interface hundredgige 3/0/3
[SwitchA-HundredGigE3/0/3] port link-type trunk
[SwitchA-HundredGigE3/0/3] port trunk permit vlan 4092 4094
[SwitchA-HundredGigE3/0/3] quit
# Enable LLDP globally.
[SwitchA] lldp global enable
# Configure VLAN-interface 1 on Switch A for communicating with the controller.
[SwitchA] interface Vlan-interface 1
[SwitchA-Vlan-interface1] ip address 192.168.2.125 255.255.255.0
# Create OpenFlow instance 1. Associate VLAN 4092 and VLAN 4094 with it in loosen mode.
[SwitchA] openflow instance 1
[SwitchA-of-inst-1] classification vlan 4092 mask 4093 loosen
# Specify 192.168.2.225 as the IP address of controller 0 for OpenFlow instance 1 and activate the instance..
[SwitchA-of-inst-1] controller 0 address ip 192.168.2.225
[SwitchA-of-inst-1] active instance
[SwitchA-of-inst-1] quit
Configuring Switch B
[SwitchB] vlan 4092
[SwitchB-vlan4092] quit
[SwitchB] vlan 4094
[SwitchB-vlan4094] quit
[SwitchB] interface hundredgige 3/0/1
[SwitchB-HundredGigE3/0/1] port access vlan 4092
[SwitchB-HundredGigE3/0/1] quit
[SwitchB] interface hundredgige 3/0/2
[SwitchB-HundredGigE3/0/2] port access vlan 4094
[SwitchB-HundredGigE3/0/2] quit
[SwitchB] interface hundredgige 3/0/3
[SwitchB-HundredGigE3/0/3] port link-type trunk
[SwitchB-HundredGigE3/0/3] port trunk permit vlan 4092 4094
[SwitchB-HundredGigE3/0/3] quit
[SwitchB] lldp global enable
# Configure VLAN-interface 1 on Switch B for communicating with the controller.
[SwitchB] interface Vlan-interface 1
[SwitchB-Vlan-interface1] ip address 192.168.2.125 255.255.255.0
[SwitchB-Vlan-interface1] quit
[SwitchB] openflow instance 1
[SwitchB-of-inst-1] classification vlan 4092 mask 4093 loosen
[SwitchB-of-inst-1] controller 0 address ip 192.168.2.225
[SwitchB-of-inst-1] active instance
[SwitchB-of-inst-1] quit
# Display details for OpenFlow instance 1 on devices, for example, Switch A.
[SwitchA] display openflow instance 1
Instance 1 information:
Configuration information:
Description : --
Active status : Active
Inactive configuration:
None
Active configuration:
Classification VLAN, loosen mode, total VLANs(2)
4092, 4094
In-band management VLAN, total VLANs(0)
Empty VLAN
Connect mode: Multiple
MAC address learning: Enabled
Flow table:
Table ID(type): 0(Extensibility), count: 1
Flow-entry max-limit: 65535
Datapath ID: 0x000174258a024c00
Port information:
HundredGigE3/0/1
HundredGigE3/0/2
HundredGigE3/0/3
Active channel information:
Controller 0 IP address: 192.168.2.225 port: 6633
The output shows that HundredGigE 3/0/1, HundredGigE 3/0/2, and HundredGigE 3/0/3 belong to OpenFlow instance 1 and can be used to forward packets in the OpenFlow forwarding process.
# Display controller information for OpenFlow instance 1 on devices, for example, Switch A.
[SwitchA] display openflow instance 1 controller
Instance 1 controller information:
Reconnect interval: 60 (s)
Echo interval : 5 (s)
Controller ID : 0
Controller IP address : 192.168.2.225
Controller port : 6633
Controller role : Equal
Connect type : TCP
Connect state : Established
Packets sent : 132
Packets received : 434
SSL policy : --
VRF name : --
The output shows that Switch A has established a connection with the controller.
# Display flow table information for OpenFlow instance 1 on devices, for example, Switch A.
[SwitchA] display openflow instance 1 flow-table
Instance 1 flow table information:
Table 0 information:
Table type: Extensibility, flow entry count: 1, total flow entry count: 1
MissRule flow entry information:
cookie: 0x0, priority: 0, hard time: 0, idle time: 0, flags: flow_send_rem,
byte count: 0, packet count: 0
Match information: any
Instruction information:
Write actions:
Output interface: Controller, send length: 65509 bytes
The output shows that Switch A has only one table-miss flow entry with the priority of 0 and the action of outputting packets to the controller. The action in the table-miss flow entry varies by device model. For more information about the action in the table-miss flow entry, see the related documentation of the controller.
# Ping Host C from Host A.
Ping 10.1.1.2 (10.1.1.2): 56 data bytes, press CTRL_C to break
56 bytes from 10.1.1.2: icmp_seq=0 ttl=255 time=4.582 ms
56 bytes from 10.1.1.2: icmp_seq=1 ttl=255 time=1.299 ms
56 bytes from 10.1.1.2: icmp_seq=2 ttl=255 time=1.389 ms
56 bytes from 10.1.1.2: icmp_seq=3 ttl=255 time=6.688 ms
56 bytes from 10.1.1.2: icmp_seq=4 ttl=255 time=1.294 ms
--- Ping statistics for 10.1.1.2 ---
round-trip min/avg/max/std-dev = 1.294/3.050/6.688/2.213 ms
The output shows that Host A and Host C can reach each other.
# Display flow table information for OpenFlow instance 1 again on devices, for example, Switch A.
Table type: Extensibility, flow entry count: 4, total flow entry count: 4
Write actions:
Flow entry 1 information:
cookie: 0x2328, priority: 29999, hard time: 0, idle time: 300, flags:
flow_send_rem, byte count: 1, packet count: 1
Match information:
Input interface: HGE3/0/3
Ethernet destination MAC address: 0cda-41b1-d1c5
Ethernet destination MAC address mask: ffff-ffff-ffff
Ethernet source MAC address: 7425-8a0f-8034
Ethernet source MAC address mask: ffff-ffff-ffff
Ethernet type: 0x0806
Write actions:
Output interface: HGE3/0/1
Flow entry 2 information:
flow_send_rem, byte count: 1, packet count: 4
Match information:
Input interface: HGE3/0/1
Ethernet destination MAC address: 7425-8a0f-8034
Ethernet source MAC address: 0cda-41b1-d1c5
Ethernet type: 0x0800
Write actions:
Output interface: HGE3/0/3
Flow entry 3 information:
Match information:
Write actions:
· The ARP request/reply packets and ICMP request/replay packets between Host A and Host C successfully trigger the controller to deploy flow entries.
· Switch A forwards packets based on the flow entries that are deployed by the controller.
# Ping Host D from Host B.
Ping 20.1.1.2 (20.1.1.2): 56 data bytes, press CTRL_C to break
56 bytes from 20.1.1.2: icmp_seq=0 ttl=255 time=1.620 ms
56 bytes from 20.1.1.2: icmp_seq=1 ttl=255 time=6.625 ms
56 bytes from 20.1.1.2: icmp_seq=2 ttl=255 time=1.454 ms
56 bytes from 20.1.1.2: icmp_seq=3 ttl=255 time=1.134 ms
56 bytes from 20.1.1.2: icmp_seq=4 ttl=255 time=1.260 ms
--- Ping statistics for 20.1.1.2 ---
round-trip min/avg/max/std-dev = 1.134/2.419/6.625/2.110 ms
The output shows that Host B and Host D can reach each other.
Table type: Extensibility, flow entry count: 7, total flow entry count: 7
Write actions:
Match information:
Write actions:
Match information:
Write actions:
Match information:
Write actions:
Flow entry 4 information:
Match information:
Ethernet destination MAC address: 0cda-41b1-d1c4
Ethernet source MAC address: 7425-8a0f-8035
Write actions:
Output interface: HGE3/0/2
Flow entry 5 information:
Match information:
Input interface: HGE3/0/2
Ethernet destination MAC address: 7425-8a0f-8035
Ethernet source MAC address: 0cda-41b1-d1c4
Write actions:
Flow entry 6 information:
Match information:
Write actions:
· The ARP request/reply packets and ICMP request/replay packets between Host B and Host D successfully trigger the controller to deploy flow entries.
Configuration files
· Switch A:
lldp global enable
vlan 4092
vlan 4094
openflow instance 1
active instance
interface Vlan-interface1
interface HundredGigE3/0/1
port link-mode bridge
interface HundredGigE3/0/2
interface HundredGigE3/0/3
port trunk permit vlan 1 4092 4094
· Switch B:
lldp global enable
vlan 4092
vlan 4094
openflow instance 1
active instance
ip address 192.168.2.126 255.255.255.0
Related documentation
Use this document in conjunction with the following documents for the product and software version you are working with:
· OpenFlow Configuration Guide
· OpenFlow Command Reference
