- H3C S6805 & S6825 & S6850 & S9850 & S9820 Config Examples-Release 66xx-6W100
- 01-Login Management Configuration Examples
- 02-RBAC Configuration Examples
- 03-Software Upgrade Examples
- 04-ISSU Configuration Examples
- 05-Software Patching Examples
- 06-Ethernet Link Aggregation Configuration Examples
- 07-Port Isolation Configuration Examples
- 08-Spanning Tree Configuration Examples
- 09-VLAN Configuration Examples
- 10-VLAN Tagging Configuration Examples
- 11-DHCP Snooping Configuration Examples
- 12-Cross-Subnet Dynamic IP Address Allocation Configuration Examples
- 13-IPv6 over IPv4 Manual Tunneling with OSPFv3 Configuration Examples
- 14-ISATAP Tunnel and 6to4 Tunnel Configuration Examples
- 15-GRE Tunnel Configuration Examples
- 16-GRE with OSPF Configuration Examples
- 17-OSPF Configuration Examples
- 18-IS-IS Configuration Examples
- 19-BGP Configuration Examples
- 20-Policy-Based Routing Configuration Examples
- 21-OSPFv3 Configuration Examples
- 22-IPv6 IS-IS Configuration Examples
- 23-Routing Policy Configuration Examples
- 24-IGMP Snooping Configuration Examples
- 25-IGMP Configuration Examples
- 26-BIDIR-PIM Configuration Examples
- 27-MLD Snooping Configuration Examples
- 28-IPv6 Multicast VLAN Configuration Examples
- 29-Basic MPLS Configuration Examples
- 30-MPLS L3VPN Configuration Examples
- 31-ACL Configuration Examples
- 32-Control Plane-Based QoS Policy Configuration Examples
- 33-Traffic Policing Configuration Examples
- 34-GTS and Rate Limiting Configuration Examples
- 35-Priority Mapping and Queue Scheduling Configuration Examples
- 36-Traffic Filtering Configuration Examples
- 37-AAA Configuration Examples
- 38-Port Security Configuration Examples
- 39-Portal Configuration Examples
- 40-SSH Configuration Examples
- 41-IP Source Guard Configuration Examples
- 42-Ethernet OAM Configuration Examples
- 43-CFD Configuration Examples
- 44-DLDP Configuration Examples
- 45-VRRP Configuration Examples
- 46-BFD Configuration Examples
- 47-NTP Configuration Examples
- 48-SNMP Configuration Examples
- 49-NQA Configuration Examples
- 50-Mirroring Configuration Examples
- 51-sFlow Configuration Examples
- 52-FCoE Configuration Examples
- 53-OpenFlow Configuration Examples
- 54-MAC Address Table Configuration Examples
- 55-Static Multicast MAC Address Entry Configuration Examples
- 56-IP Unnumbered Configuration Examples
- 57-MVRP Configuration Examples
- 58-MCE Configuration Examples
- 59-Congestion Avoidance and Queue Scheduling Configuration Examples
- 60-Attack Protection Configuration Examples
- 61-Smart Link Configuration Examples
- 62-RRPP Configuration Examples
- 63-BGP Route Selection Configuration Examples
- 64-IS-IS Route Summarization Configuration Examples
- 65-IRF Configuration Examples
- 66-MPLS OAM Configuration Examples
- 67-MPLS TE Configuration Examples
- 68-VXLAN Configuration Examples
- 69-NetStream Configuration Examples
- 70-DRNI Configuration Examples
- 71-DRNI and EVPN Configuration Examples
- 72-EVPN-DCI over an MPLS L3VPN Network Configuration Examples
- 73-VCF Fabric Configuration Examples
- 74-PTP Configuration Examples
- 75-S-MLAG Configuration Examples
- 76-Puppet Configuration Examples
- 77-802.1X Configuration Examples
- 78-MAC Authentication Configuration Examples
- 79-MOD and Elephant and Mice Flow Configuration Examples
- 80-TCB Configuration Examples
- 81-Multicast VPN Configuration Examples
| 22-IPv6 IS-IS Configuration Examples | 105.99 KB |
H3C S6805&S6825&S6850&S9850&S9820 |
Copyright © 2020-2023 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides IPv6 IS-IS configuration examples.
This document assumes that you have basic knowledge of IPv6 IS-IS.
Example: Configuring IPv6 IS-IS
As shown in Figure 1, the company's headquarters and the branch run IPv6 IS-IS. The partner runs OSPFv3.
Configure the switches to meet the following requirements:
· The Marketing department can reach the Finance department, the branch, and the partner.
· The Finance department and the branch cannot reach each other, and the branch does not have a route to the Finance department.
Analysis
To meet the network requirements, you must perform the following tasks:
· Configure Switch A and Switch B in Area 10 as Level-1 routers to allow communication between the Marketing department and the Finance department.
· Configure route redistribution between IPv6 IS-IS and OSPFv3 on Switch D to allow communication between the Marketing department and the partner.
· Configure Switch C to use a prefix list to advertise only network 3001:1::/64 to Level-2. So that the branch does not have a route to the Finance department.
Hardware |
Software version |
S6805 switch series |
Release 6607, Release 6616, Release 6616P01, Release 6635 and later |
S6825 switch series |
S6850 switch series S9850 switch series |
Release 6555P01, Release 6607, Release 6616, Release 6616P01, Release 6635 and later |
S9820-64H switch |
S9820-8C switch |
Procedures
Configuring Switch A
# Configure an IPv6 address for VLAN-interface 11.
[SwitchA-Vlan-interface11] ipv6 address 2001:1::1 64
# Configure IPv6 addresses for other interfaces, as shown in Figure 1. (Details not shown.)
# Configure IPv6 IS-IS.
[SwitchA] isis 1
[SwitchA-isis-1] is-level level-1
[SwitchA-isis-1] network-entity 10.3001.0001.0001.00
[SwitchA-isis-1] address-family ipv6
[SwitchA-isis-1-ipv6] quit
[SwitchA-isis-1] quit
[SwitchA–vlan-interface 11] isis ipv6 enable 1
[SwitchA–vlan-interface 11] quit
[SwitchA–Vlan-interface100] isis ipv6 enable 1
[SwitchA–Vlan-interface100] quit
Configuring Switch B
# Configure an IPv6 address for VLAN-interface 12.
[SwitchB] interface vlan-interface 12
[SwitchB-Vlan-interface12] ipv6 address 2001:2::1 64
[SwitchB-Vlan-interface12] quit
[SwitchB] isis 1
[SwitchB-isis-1] is-level level-1
[SwitchB-isis-1] network-entity 10.3001.0002.0001.00
[SwitchB-isis-1] address-family ipv6
[SwitchB-isis-1-ipv6] quit
[SwitchB-isis-1] quit
[SwitchB–Vlan-interface12] isis ipv6 enable 1
[SwitchB–Vlan-interface12] quit
[SwitchB–Vlan-interface 200] isis ipv6 enable 1
[SwitchB–Vlan-interface 200] quit
Configuring Switch C
[SwitchC] interface vlan-interface 11
[SwitchC-Vlan-interface11] ipv6 address 2001:1::2 64
[SwitchC-Vlan-interface11] quit
[SwitchC] isis 1
[SwitchC-isis-1] is-level level-1
[SwitchC-isis-1] network-entity 10.2001.0010.0001.00
[SwitchC-isis-1] address-family ipv6
[SwitchC-isis-1-ipv6] quit
[SwitchC-isis-1] quit
[SwitchC] interface vlan-interface 10
[SwitchC–Vlan-interface10] isis ipv6 enable 1
[SwitchC–Vlan-interface10] quit
[SwitchC–Vlan-interface11] isis ipv6 enable 1
[SwitchC–Vlan-interface11] quit
[SwitchC] interface vlan-interface 12
[SwitchC–Vlan-interface12] isis ipv6 enable 1
[SwitchC–Vlan-interface12] quit
# Configure route leaking from Level-1 to Level-2, and use prefix list 1 to advertise only network 3001:1::/64 to Level-2.
[SwitchC] ipv6 prefix-list 1 permit 3001:1:: 64
[SwitchC] isis 1
[SwitchC] address-family ipv6
[SwitchC-isis-1-ipv6] import-route isisv6 level-1 into level-2 filter-policy prefix-list 1
Configuring Switch D
# Configure an IPv6 address for VLAN-interface 10.
<SwitchD> system-view
[SwitchD] interface vlan-interface 10
[SwitchD-Vlan-interface10] ipv6 address 2001:10::2 64
[SwitchD-Vlan-interface10] quit
[SwitchD] isis 1
[SwitchD-isis-1] is-level level-2
[SwitchD-isis-1] network-entity 20.2001.0020.0001.00
[SwitchD-isis-1] address-family ipv6
[SwitchD-isis-1-ipv6] quit
[SwitchD-isis-1] quit
[SwitchD–Vlan-interface10] isis ipv6 enable 1
[SwitchD–Vlan-interface10] quit
[SwitchD] interface vlan-interface 20
[SwitchD–Vlan-interface20] isis ipv6 enable 1
[SwitchD–Vlan-interface20] quit
# Configure OSPFv3.
[SwitchD] ospfv3
[SwitchD-ospfv3-1] router-id 4.4.4.4
[SwitchD-ospfv3-1] quit
[SwitchD–Vlan-interface20] ospfv3 1 area 0
# Redistribute OSPFv3 and direct routes into IPv6 IS-IS.
[SwitchD] isis 1
[SwitchD] address-family ipv6
[SwitchD-isis-1-ipv6] import-route ospfv3
[SwitchD-isis-1-ipv6] import-route direct
# Redistribute IPv6 IS-IS and direct routes into OSPFv3.
[SwitchD] ospfv3 1
[SwitchD-ospfv3-1] import-route isisv6 1
[SwitchD-ospfv3-1] import-route direct
Configuring Switch E
# Configure an IPv6 address for VLAN-interface 20.
<SwitchE> system-view
[SwitchE] interface vlan-interface20
[SwitchE-Vlan-interface12] ipv6 address 2001:20::2 64
[SwitchE-Vlan-interface12] quit
# Configure OSPFv3.
[SwitchE] ospfv3
[SwitchE-ospfv3-1] router-id 5.5.5.5
[SwitchE-ospfv3-1] quit
[SwitchE] interface vlan-interface 20
[SwitchE–Vlan-interface 20] ospfv3 1 area 0
[SwitchE–Vlan-interface 20] quit
[SwitchE] interface vlan-interface 300
[SwitchE–Vlan-interface 300] ospfv3 1 area 0
[SwitchE–Vlan-interface 300] quit
# Verify that the branch can reach the Marketing department, but cannot reach the Finance department.
[SwitchD] display isis route ipv6
Level-2 IPv6 forwarding table
Destination : 2001:10:: PrefixLen: 64
Flag : D/L/- Cost : 10
Next hop : Direct Interface: Vlan10
Destination : 2001:1:: PrefixLen: 64
Flag : R/-/- Cost : 20
Next hop : FE80::7625:8AFF:FE02:4D13 Interface: Vlan10
Destination : 2001:2:: PrefixLen: 64
Destination : 3001:1:: PrefixLen: 64
Flag : R/-/- Cost : 30
# Verify that the company can communicate with the partner.
· Display the IPv6 IS-IS routing table on Switch C.
[SwitchC] display isis route ipv6 level-2
Next hop : Direct Interface: Vlan11
Next hop : Direct Interface: Vlan12
Destination : 2001:20:: PrefixLen: 64
Flag : R/L/- Cost : 20
Next hop : FE80::BAAF:67FF:FE30:3304 Interface: Vlan10
Destination : 3001:200:: PrefixLen: 64
· Ping 3001:200::1 from Switch A.
[SwitchA] ping ipv6 –a 3001:1::1 3001:200::1
Ping6(56 data bytes) 3001:1::1 --> 3001:200::1, press CTRL+C to break
56 bytes from 3001:200::1, icmp_seq=0 hlim=63 time=7.230 ms
56 bytes from 3001:200::1, icmp_seq=1 hlim=63 time=3.449 ms
56 bytes from 3001:200::1, icmp_seq=2 hlim=63 time=2.779 ms
56 bytes from 3001:200::1, icmp_seq=3 hlim=63 time=2.652 ms
56 bytes from 3001:200::1, icmp_seq=4 hlim=63 time=2.558 ms
--- Ping6 statistics for 3001:200::1 ---
round-trip min/avg/max/std-dev = 2.558/3.734/7.230/1.776 ms
Configuration files
· Switch A:
isis 1
is-level level-1
address-family ipv6 unicast
vlan 11
vlan 100
interface Vlan-interface11
isis ipv6 enable 1
ipv6 address 2001:1::1/64
interface Vlan-interface100
isis ipv6 enable 1
ipv6 address 3001:1::1/64
· Switch B:
isis 1
is-level level-1
vlan 12
vlan 200
interface Vlan-interface12
isis ipv6 enable 1
ipv6 address 2001:2::1/64
interface Vlan-interface200
isis ipv6 enable 1
ipv6 address 3001:2::1/64
· Switch C:
isis 1
vlan 11 to 13
isis ipv6 enable 1
ipv6 address 2001:1::2/64
isis ipv6 enable 1
ipv6 address 2001:2::2/64
interface Vlan-interface13
isis ipv6 enable 1
ipv6 address 2001:10::1/64
ipv6 prefix-list 1 index 10 permit 3001:1:: 64
· Switch D:
isis 1
is-level level-2
import-route direct
import-route ospfv3 1
ospfv3 1
router-id 4.4.4.4
area 0.0.0.0
import-route direct
vlan 10
vlan 20
isis ipv6 enable 1
ipv6 address 2001:10::2/64
ospfv3 1 area 0.0.0.0
ipv6 address 2001:20::1/64
· Switch E:
ospfv3 1
router-id 5.5.5.5
area 0.0.0.0
vlan 20
vlan 300
ospfv3 1 area 0
ipv6 address 2001:20::2/64
interface Vlan-interface300
ospfv3 1 area 0
ipv6 address 3001:200::1/64
Related documentation
Use this document in conjunction with the following documents for the product and software version you are working with:
· Layer 3—IP Routing Configuration Guide
· Layer 3—IP Routing Command Reference
