H3C S6860 Switch Series Configuration Examples-Release 26xx-6W100
HomeSupportSwitchesS6860 SeriesConfigure & DeployConfiguration ExamplesH3C S6860 Switch Series Configuration Examples-Release 26xx-6W100
Table of Contents
Related Documents
44-Ethernet OAM Configuration Examples
44-Ethernet OAM Configuration Examples 61.44 KB
Copyright © 2018 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides Ethernet OAM configuration examples.
Ethernet OAM is a tool that monitors the status of the link between two directly connected devices.
This document assumes that you have basic knowledge of Ethernet OAM.
Example: Configuring Ethernet OAM
As shown in Figure 1, the edge devices Device A and Device B connect the enterprise network and the carrier network. Configure Ethernet OAM on Device A and Device B to meet the following Service Level Agreement (SLA) requirements:
·     Device A and Device B automatically monitor the link between them.
·     The administrator can view critical link events on the link between Device A and Device B.
·     The administrator can obtain the link status by observing link error event statistics.
Figure 1 Network diagram
Analysis
For Device A to establish an Ethernet OAM connection with Device B, configure XGE1/0/1 on Device A to operate in active mode, and configure XGE1/0/1 on Device B to operate in passive mode.
To implement link event detection based on the network environment, configure errored frame event detection parameters and use global settings for other detection parameters.
Software versions used
This configuration example was created and verified on S6860-CMW710-R2612.
To change the Ethernet OAM mode on an Ethernet OAM-enabled port, first disable Ethernet OAM on the port.
Procedures
Configuring Device A
# Configure Ten-GigabitEthernet 1/0/1 to operate in active Ethernet OAM mode (default mode), and enable Ethernet OAM for it.
[DeviceA-Ten-GigabitEthernet1/0/1] oam mode active
[DeviceA-Ten-GigabitEthernet1/0/1] oam enable
# Set the errored frame event detection window to 20000 milliseconds, and set the errored frame event triggering threshold to 10.
[DeviceA-Ten-GigabitEthernet1/0/1] oam errored-frame window 200
[DeviceA-Ten-GigabitEthernet1/0/1] oam errored-frame threshold 10
Configuring Device B
# Configure Ten-GigabitEthernet 1/0/1 to operate in passive Ethernet OAM mode, and enable Ethernet OAM for it.
[DeviceB-Ten-GigabitEthernet1/0/1] oam mode passive
[DeviceB-Ten-GigabitEthernet1/0/1] oam enable
# Display Ethernet OAM configuration globally and on ports that do not use the default configuration.
[DeviceA] display oam configuration
---------------- [Global] ----------------
 OAM timers
   Hello timer        : 1000 milliseconds
   Keepalive timer    : 5000 milliseconds
 Link monitoring
   Errored symbol period
     Window           : 100 x 1000000 symbols
     Threshold        : 1 error symbols
   Errored frame
     Window           : 10 x 100 milliseconds
     Threshold        : 1 error frames
   Errored frame period
     Window           : 1000 x 10000 frames
   Errored frame seconds
     Window           : 600 x 100 milliseconds
     Threshold        : 1 error seconds
----------- [Ten-GigabitEthernet1/0/1] -----------
 OAM timers
 Link monitoring
   Errored frame
     Window           : 200 x 100 milliseconds
     Threshold        : 10 error frames
# Display the statistics for critical Ethernet OAM link events that occurred on all ports of Device A.
[DeviceA] display oam critical-event
 Local link status   : UP
 Event statistics
   Link fault        : Not occurred
   Dying gasp        : Not occurred
   Critical event    : Not occurred
The output shows that no critical link event has occurred on the link between Device A and Device B.
# Display Ethernet OAM link event statistics for the local end of Device A.
[DeviceA] display oam link-event local
 Link status: UP
 OAM local errored frame event
   Event time stamp        : 5789 x 100 milliseconds
   Errored frame window    : 200 x 100 milliseconds
   Errored frame threshold : 10 error frames
   Errored frame           : 13 error frames
   Error running total     : 350 error frames
   Event running total     : 17 events
·     350 errors have occurred after Ethernet OAM is enabled on Device A.
·     17 errors are caused by error frames.
·     The link is unstable.
If the link is unstable, contact H3C Support.
Configuration files
·     Device A:
 port link-mode bridge
 oam enable
·     Device B:
 oam mode passive
 oam enable
Related documentation
·     H3C S6860 Switch Series High Availability Command Reference-Release 26xx
·     H3C S6860 Switch Series High Availability Configuration Guide-Release 26xx
