H3C S6860 Switch Series Configuration Examples-Release 26xx-6W100
HomeSupportSwitchesS6860 SeriesConfigure & DeployConfiguration ExamplesH3C S6860 Switch Series Configuration Examples-Release 26xx-6W100
Table of Contents
Related Documents
11-PBB Configuration Examples
Copyright © 2018 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides PBB configuration examples.
This document assumes that you have basic knowledge of PBB.
Example: Configuring PBB
As shown in Figure 1, Site A and Site B both have VLANs 100 through 120.
·     Configure QinQ on Device A and Device B to transmit VLANs 100 through 120 in SVLAN 1000.
·     Configure PBB on BEB 1 and BEB 2 to extend the VLANs across the two sites.
Figure 1 Network diagram
Analysis
To meet the network requirements, you must perform the following tasks on BEB 1 and BEB 2:
·     Configure a service instance on the downlink port to match frames that have an outer VLAN ID of 1000.
·     Specify the access mode and data encapsulation type of the PBB VSI as Ethernet to retain the VLAN tags of the customer frames.
Software versions used
This configuration example was created and verified on S6860-CMW710-R2612.
You need to configure PBB only on BEBs.
Procedures
Configuring BEB 1
# Create VLAN 1000 and VLAN 2000.
<BEB1> system-view
[BEB1] vlan 1000
[BEB1-vlan1000] quit
[BEB1] vlan 2000
[BEB1-vlan2000] quit
# Enable L2VPN.
[BEB1] l2vpn enable
# Create a VSI.
[BEB1] vsi test
# Assign PBB I-SID 1 to the VSI.
[BEB1-vsi-test] pbb i-sid 1
# Specify B-VLAN 2000 for the PBB VSI.
[BEB1-vsi-test-1] bvlan 2000
[BEB1-vsi-test-1] quit
[BEB1-vsi-test] quit
# Configure Ten-GigabitEthernet 1/0/1 as a trunk port, assign it to VLAN 2000, and remove it from VLAN 1. Configure Ten-GigabitEthernet 1/0/1 as an uplink port of the PBB VSI.
[BEB1] interface ten-gigabitethernet 1/0/1
[BEB1-Ten-GigabitEthernet1/0/1] port link-type trunk
[BEB1-Ten-GigabitEthernet1/0/1] port trunk permit vlan 2000
[BEB1-Ten-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[BEB1-Ten-GigabitEthernet1/0/1] pbb uplink vsi test
[BEB1-Ten-GigabitEthernet1/0/1] quit
# Configure Ten-GigabitEthernet 1/0/2 as a trunk port, assign it to VLAN 1000, and remove it from VLAN 1.
[BEB1] interface ten-gigabitethernet 1/0/2
[BEB1-Ten-GigabitEthernet1/0/2] port link-type trunk
[BEB1-Ten-GigabitEthernet1/0/2] port trunk permit vlan 1000
[BEB1-Ten-GigabitEthernet1/0/2] undo port trunk permit vlan 1
# Create service instance 1 on Ten-GigabitEthernet 1/0/2.
[BEB1-Ten-GigabitEthernet1/0/2] service-instance 1
# Configure the service instance to match frames that have an outer VLAN ID of 1000. Associate the service instance with the PBB VSI, and set the access mode to Ethernet.
[BEB1-Ten-GigabitEthernet1/0/2-srv1] encapsulation s-vid 1000
[BEB1-Ten-GigabitEthernet1/0/2-srv1] xconnect vsi test access-mode ethernet
[BEB1-Ten-GigabitEthernet1/0/2-srv1] quit
[BEB1-Ten-GigabitEthernet1/0/2] quit
# Enable Ethernet encapsulation for the PBB VSI.
[BEB1] vsi test
[BEB1-vsi-test-1] encapsulation ethernet
Configuring BEB 2
# Configure BEB 2 in the same way BEB 1 is configured. (Details not shown.)
Configuring BCB
# Create VLAN 2000.
<BCB> system-view
[BCB] vlan 2000
[BCB-vlan2000] quit
# Configure Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/2 as trunk ports, assign them to VLAN 2000, and remove them from VLAN 1.
[BCB] interface range ten-gigabitethernet 1/0/1 to ten-gigabitethernet 1/0/2
[BCB-if-range] port link-type trunk
[BCB-if-range] port trunk permit vlan 2000
[BCB-if-range] undo port trunk permit vlan 1
[BCB-if-range] quit
Configuring Device A
# Create VLAN 1000.
[DeviceA] vlan 1000
[DeviceA-vlan1000] quit
# Configure Ten-GigabitEthernet 1/0/1 as an access port, and assign it to VLAN 1000.
[DeviceA-Ten-GigabitEthernet1/0/1] port access vlan 1000
# Enable QinQ on Ten-GigabitEthernet 1/0/1.
[DeviceA-Ten-GigabitEthernet1/0/1] qinq enable
[DeviceA] interface ten-gigabitethernet 1/0/2
[DeviceA-Ten-GigabitEthernet1/0/2] port link-type trunk
[DeviceA-Ten-GigabitEthernet1/0/2] port trunk permit vlan 1000
[DeviceA-Ten-GigabitEthernet1/0/2] undo port trunk permit vlan 1
[DeviceA-Ten-GigabitEthernet1/0/2] quit
Configuring Device B
# Configure Device B in the same way Device A is configured. (Details not shown.)
# Verify that correct PBB VSI uplink connections have been established between BEB 1 and BEB 2.
<BEB1> display pbb connection
BMAC            BVLAN  Port                      Type  Aging
011e-8300-0001  2000   XGE1/0/1                  MC    N
0cda-415e-232e  2000   XGE1/0/1                  UC    Y
<BEB2> display pbb connection
00e0-fc58-1234  2000   XGE1/0/1                  UC    Y
# Verify that hosts in Site 1 and Site 2 can ping each another. (Details not shown.)
# Verify that the BCB does not learn customer MAC addresses.
<BCB> display mac-address
Configuration files
·     BEB 1 and BEB 2:
vlan 1000
vlan 2000
 l2vpn enable
vsi test
 pbb i-sid 1
  bvlan 2000
 port link-mode bridge
 pbb uplink vsi test
 service-instance 1
·     BCB:
vlan 2000
·     Device A and Device B:
vlan 1000
 qinq enable
Related documentation
·     H3C S6860 Switch Series Layer 2—LAN Switching Command Reference-Release 26xx
·     H3C S6860 Switch Series Layer 2—LAN Switching Configuration Guide-Release 26xx
H3C reserves the right to modify its collaterals without any prior notice. For the latest information of the collaterals, please consult H3C sales or call 400 hotline.
