H3C S6860 Switch Series Configuration Examples-Release 26xx-6W100
HomeSupportSwitchesS6860 SeriesConfigure & DeployConfiguration ExamplesH3C S6860 Switch Series Configuration Examples-Release 26xx-6W100
Table of Contents
Related Documents
01-Login Management Configuration Examples
Copyright © 2018 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides login configuration examples. It also provides examples for implementing user access control by using command authorization and command accounting.
This document assumes that you have basic knowledge of login management.
Example: Configuring console login
Configure console login so users must pass local authentication to log in to the device through the console port.
Analysis
The port properties for the terminal emulation program must match the console port's default settings.
By default, a local user is assigned the user role network-operator and is not assigned any service type. To enable the user to log in through the console port, you must assign the terminal service type to the user. To enable the user to manage the device, you must assign the network-admin user role to the user.
Software versions used
This configuration example was created and verified on Release S6860-CMW710-R2612.
For successful console port login, follow these restrictions and guidelines:
·     Identify the console port carefully to make sure you are connecting to the correct port.
·     Prepare a console terminal, for example, a PC. Make sure the console terminal has a terminal emulation program, such as HyperTerminal or PuTTY. For information about how to use terminal emulation programs, see the programs' user guides.
Procedures
1.     Turn off the PC if the PC is on.
2.     Connect the DB-9 female connector of the console cable to the serial port of the PC.
3.     Identify the console port of the device carefully and connect the RJ-45 connector of the console cable to the console port.
IMPORTANT
IMPORTANT:
The serial ports on PCs do not support hot swapping. To connect a PC to an operating switch, first connect the PC end. To disconnect a PC from an operating device, first disconnect the device end.
Figure 1 Connecting a configuration terminal to the console port
4.     Turn on the PC.
5.     On the PC, launch the terminal emulation program, and create a connection that uses the serial port connected to the device. Set the port properties so the port properties match the following console port default settings:
?     Bits per second9600 bps.
?     Flow controlNone.
?     ParityNone.
?     Stop bits—1.
?     Data bits—8.
6.     Power on the device and press Enter as prompted.
The user view prompt appears. You can enter commands to configure or manage the device. To get help, enter ?.
7.     Configure AUX line 0:
# Enter AUX line view.
[Sysname] line aux 0
# Enable scheme authentication to use AAA to authenticate the console login user.
[Sysname-line-aux0] authentication-mode scheme
[Sysname-line-aux0] quit
# Create the local user admin.
[Sysname] local-user admin class manage
New local user added.
# Set the password to 123 (plain text) for the local user.
[Sysname-luser-manage-admin] password simple 123
# Assign the terminal service type and the network-admin user role to the user. Reclaim the default user role.
[Sysname-luser-manage-admin] service-type terminal
[Sysname-luser-manage-admin] authorization-attribute user-role network-admin
[Sysname-luser-manage-admin] undo authorization-attribute user-role network-operator
[Sysname-luser-manage-admin] quit
Log in to the device through the console port again, and press Enter and enter the username admin and password 123 as prompted.
* Copyright (c) 2004-2018 New H3C Technologies Co., Ltd. All rights reserved.*
Line aux0 is available.
Press ENTER to get started.
login: admin
Password:
<Sysname>
Configuration files
line aux 0
 password hash $h$6$RgG+mm4RKXICN1tY$ld6pV+qB2a/BBFXVnqocFJjYgx/EKCYod9tHmGRP8AA
1qnbeRcB6Bd4jW+cteG9aY2Gc+J8JqLHsWwvtnLyEAw==
Example: Configuring user-role based Telnet login
As shown in Figure 2, users need to log in to the device remotely to manage the device.
·     Configure Telnet login to enable users to Telnet to the device.
·     Configure Telnet user authentication so a Telnet user must provide the correct username and password at login.
·     Configure access control so only Telnet users at 192.168.0.46/24 and 192.168.0.52/24 can Telnet to the device.
·     Configure two local users.
?     One local user can manage the device.
?     One local user can use only the read commands of features.
Figure 2 Network diagram
Analysis
Telnet service is disabled by default. To enable Telnet login, you must enable Telnet service.
To control Telnet login, configure an ACL to permit access only from the specified IP addresses.
By default, a local user is assigned the user role network-operator. To restrict a local user to read commands, you must create a user role that can access only read commands.
Procedures
# Log in to the device through the console port. (Details not shown.)
# Enable Telnet service.
# Enable scheme authentication to use AAA to authenticate the Telnet login user.
[Sysname] line vty 0 63
[Sysname-line-vty0-63] authentication-mode scheme
[Sysname-line-vty0-63] quit
# Create the local user userA. Set the password to 123 (plain text).
[Sysname] local-user userA class manage
[Sysname-luser-manage-userA] password simple 123
# Assign the Telnet service type and the network-admin user role to the user. Reclaim the default user role.
[Sysname-luser-manage-userA] authorization-attribute user-role network-admin
[Sysname-luser-manage-userA] service-type telnet
[Sysname-luser-manage-userA] undo authorization-attribute user-role network-operator
[Sysname-luser-manage-userA] quit
# Create user role roleB. Add rule 1 to permit the user role to access read commands of all features.
[Sysname] role name roleB
[Sysname-role-roleB] rule 1 permit read feature
[Sysname-role-roleB] quit
# Create the local user userB. Set the password to 123 (plain text).
[Sysname] local-user userB class manage
[Sysname-luser-manage-userB] password simple 123
# Assign the Telnet service type and the roleB user role to the user. Reclaim the default user role.
[Sysname-luser-manage-userB] authorization-attribute user-role roleB
[Sysname-luser-manage-userB] service-type telnet
[Sysname-luser-manage-userB] undo authorization-attribute user-role network-operator
[Sysname-luser-manage-userB] quit
# Create ACL 2000 and add rules to permit only access from 192.168.0.46 and 192.168.0.52.
[Sysname] acl basic 2000
[Sysname-acl-basic-2000] rule 1 permit source 192.168.0.46 0
[Sysname-acl-basic-2000] rule 2 permit source 192.168.0.52 0
[Sysname-acl-basic-2000] rule 3 deny source any
[Sysname-acl-basic-2000] quit
# Apply the ACL to filter Telnet logins.
[Sysname] telnet server acl 2000
1.     Telnet to the device from Host A, and enter the username userA and password 123 as prompted.
2.     Display the commands available in user view.
The commands for device configuration and management are included in the list.
login: userA
Password:
<Sysname> ?
User view commands:
  archive             Archive configuration
  arp                 Address Resolution Protocol (ARP) module
  backup              Backup operation
  boot-loader         Software image file management
  bootrom             Update/read/backup/restore bootrom
  cd                  Change current directory
  cfd                 Connectivity Fault Detection (CFD) module
  clock               Specify the system clock
  copy                Copy a file
  debugging           Enable system debugging functions
  delete              Delete a file
  diagnostic-logfile  Diagnostic log file configuration
  dir                 Display files and directories on the storage media
  display             Display current system information
  emulate-ping        Emulate ping function
  erase               Alias for 'delete'
  exception           Exception information configuration
  exit                Alias for 'quit'
  fdisk               Partition a storage medium
  fixdisk             Check and repair a storage medium
  format              Format a storage medium
  free                Release a connection
  ftp                 Open an FTP connection
---- More ----
3.     Telnet to the device from Host B, and enter the username userB and password 123 as prompted.
4.     Display the commands available in user view.
Only read commands are displayed.
login: userB
Password:
<Sysname> ?
User view commands:
  md5sum       Compute the hash digest of a file using the MD5 algorithm
  more         Display the contents of a file
  no           Alias for 'undo'
  pwd          Display current working directory
  quit         Exit from current command view
  sha256sum    Compute the hash digest of a file using the SHA256 algorithm
  show         Alias for 'display'
  system-view  Enter the System View
  write        Alias for 'save'
<Sysname>
5.     Telnet to the device from Host C.
Your access request is rejected.
Configuration files
acl basic 2000
 rule 3 deny
line vty 0 63
 password hash $h$6$I2Sg4Llj1qVUWQZ3$JA6KkU3zfVVRg48MM92X6cVpdiqR2JF887PKi3GQMwn
XXXcsWBuz7GIeJZeeNFMmMBaV7DPkKblnb0sGT2axvg==
 service-type telnet
 password hash $h$6$q+c3OcSxrPpDpsDf$BWkgfOyxBLyR5zyYgF/+VvN/1ofy81zoHDlFf80OjDl
a6/EiSJbSBl33PeazilSkWSYcttkg5v5bGecB7oYwAw==
 service-type telnet
role name roleB
Example: Configuring login user command authorization and accounting
As shown in Figure 3, Host A needs to log in to the device to manage the device.
For device security purposes, configure the device to perform the following tasks:
·     Allow Host A to Telnet in after authentication.
·     Use the HWTACACS server to control the commands that the user can execute.
·     Send commands executed by users to the HWTACACS server to monitor and control user operations on the device.
Figure 3 Network diagram
Analysis
To implement command authorization and accounting, you must perform the following tasks:
·     Enable scheme authentication and configure a HWTACACS scheme on the device.
·     Configure an account on the HWTACACS server for the Telnet user and assign commands for the user to use.
The command authorization function takes effect immediately after you execute the command authorization command. Before executing this command, you must complete the following tasks:
·     Configure a user account on the HWTACACS server and specify the commands for the user to use.
·     Configure the required HWTACACS scheme on the device.
Procedures
Configuring the HWTACACS server
In this example, the HWTACACS server runs on IMC PLAT 7.1 (E0302) and IMC EIA 7.1 (E0301).
1.     Add a device area:
a.     Log in to IMC.
b.     Click the User tab.
c.     From the navigation tree, select Device User Policy > Authorization Conditions > Device Areas.
d.     Click Add.
e.     Set the area name to system and click OK.
Figure 4 Adding a device area
2.     Add a device:
a.     From the navigation tree, select Device User Policy > Device Management.
b.     Click Add.
c.     Enter expert for both Shared Key and Confirm Shared Key.
d.     Set the authentication port to 49.
e.     Select the device area system.
f.     Select Not Supported for Single Connection to disable establishing multiple sessions over a single TCP connection.
g.     Select Not Supported for Watchdog to disable the device from sending watchdog packets while the user is online.
h.     In the Device Management area, click Add Manually.
i.     Enter the IP address 192.168.2.1 and click OK.
j.     Click OK.
Figure 5 Adding a device
3.     Add a shell profile:
a.     From the navigation tree, select Device User Policy > Authorization Command > Shell Profiles.
b.     Click Add.
c.     Enter the profile name Shell Profile1.
d.     Select the privilege Level 1.
e.     Click OK.
Figure 6 Adding a shell profile
4.     Add an authorization policy:
a.     From the navigation tree, select Device User Policy > Authorization Policies.
b.     Click Add.
c.     Enter the policy name tac.
d.     In the Access Authorization Info area, click Add to configure access authorization information.
e.     Select system for Device Area, Unlimited for Device Type and Authorized Time Range.
f.     Select the shell profile Shell Profile1.
g.     Select Unlimited for Authorization Command Set and click OK.
h.     Click OK.
Figure 7 Configuring access authorization information
Figure 8 Adding an authorization policy
5.     Add a device user:
a.     From the navigation tree, select Device User > All Device Users.
b.     Click Add.
c.     Enter the account name monitor and username telnet-user.
d.     Enter the login password 123 and confirm the password.
e.     Select the user authorization policy tac.
f.     Enter 5 for Max. Online Users to limit the number of online users that use the account.
g.     Click OK.
Figure 9 Adding a device user
Configuring the device
# Assign IP addresses to relevant interfaces. Make sure the device and the HWTACACS server can reach each other, and the device and Host A can reach each other. (Details not shown.)
# Create the HWTACACS scheme tac.
[Sysname] hwtacacs scheme tac
# Configure the scheme to use the HWTACACS server at 192.168.2.20:49 for authentication, authorization, and accounting.
[Sysname-hwtacacs-tac] primary authentication 192.168.2.20 49
[Sysname-hwtacacs-tac] primary authorization 192.168.2.20 49
[Sysname-hwtacacs-tac] primary accounting 192.168.2.20 49
# Set the shared keys to expert.
[Sysname-hwtacacs-tac] key authentication simple expert
[Sysname-hwtacacs-tac] key authorization simple expert
[Sysname-hwtacacs-tac] key accounting simple expert
# Remove domain names from usernames sent to the HWTACACS server.
[Sysname-hwtacacs-tac] user-name-format without-domain
[Sysname-hwtacacs-tac] quit
# Configure the system-predefined domain system.
[Sysname] domain system
# Use the HWTACACS scheme tac for login user authentication, authorization, and accounting. Use local authentication, authorization, and accounting as the backup method.
[Sysname-isp-system] authentication login hwtacacs-scheme tac local
[Sysname-isp-system] authorization login hwtacacs-scheme tac local
[Sysname-isp-system] accounting login hwtacacs-scheme tac local
# Use the HWTACACS scheme tac for command authorization and accounting. Use local authorization as the backup command authorization method.
[Sysname-isp-system] authorization command hwtacacs-scheme tac local
[Sysname-isp-system] accounting command hwtacacs-scheme tac
[Sysname-isp-system] quit
# Create the local user monitor. Set the password to 123 (plain text).
[Sysname] local-user monitor class manage
[Sysname-luser-manage-monitor] password simple 123
# Assign the Telnet service type and the level-1 user role to the user. Reclaim the default user role.
[Sysname-luser-manage-monitor] service-type telnet
[Sysname-luser-manage-monitor] authorization-attribute user-role level-1
[Sysname-luser-manage-monitor] undo authorization-attribute user-role network-operator
[Sysname-luser-manage-monitor] quit
# Enable command authorization and command accounting.
[Sysname-line-vty0-63] command authorization
[Sysname-line-vty0-63] command accounting
1.     Verify the command authorization feature:
# Telnet to the device, and enter the username monitor and password 123.
C:\Documents and Settings\Administrator> telnet 192.168.2.1
login:monitor
Password:
<Sysname>
# Display commands available in user view and system view. Only commands permitted by the level-1 user role are displayed.
<Sysname> ?
User view commands:
  mtrace       Configure the multicast traceroute
  no           Alias for 'undo'
  ping         Ping function
  ssh2         Establish an Stelnet connection to an Stelnet server
  super        Switch to a user role
  telnet       Establish a telnet connection
  tracert      Tracert function
[Sysname] ?
System view commands:
  access-list  Alias for 'acl'
  end          Alias for 'return'
  hostname     Alias for 'sysname'
  logging      Alias for 'info-center'
  no           Alias for 'undo'
  ping         Ping function
  return       Exit to User View
2.     Verify the command accounting feature:
a.     Log in to IMC.
c.     From the navigation tree, select Device User > Log Management > Audit Logs.
d.     In the Query Audit Logs area, enter the account name monitor, select the audit time range, and click Query.
A log for user monitor shows that the user executed the system-view command.
Figure 10 Querying audit logs
e.     Click the Details icon  for the log of the Start audit type.
Figure 11 Displaying details about the log of the Start audit type
f.     Click the Details icon  for the log of the Enter Command At CLI audit type.
Figure 12 Displaying details about the log of the Enter Command At CLI audit type
Configuration files
hwtacacs scheme tac
 key authentication cipher $c$3$Fl1Mn3wBsh+vH6otPvoz+AdE7VaNS3c0Pw==
 key authorization cipher $c$3$2x6XI5xU7UGX6VqWFXNp2n3FG07uTNjiQw==
 key accounting cipher $c$3$2oKsuCOAZX1+3ibvTPxnJ1YvJ1MHqv73Lw==
domain system
 password hash $h$6$5BqWnAJTpBbU5NbY$PbdgF+43eE5WMvj2iHPySfd5nGqj5AhDCDOXTiUMJvR
FFVsZaF8EW1tgpsQPRSq7SDKaGqwHTy9nsabAoGNaYg==
 service-type telnet
line vty 0 63
 idle-timeout 0 0
 command accounting
Example: Configuring Telnet login
As shown in Figure 13, users need to log in to the device remotely to manage the device.
·     Configure the device to send up to 20 lines to the configuration terminal at a time.
·     Set the command history buffer size to 100.
·     Set the maximum number of concurrent Telnet users to 10.
·     Set the session idle timeout to 20 minutes.
Figure 13 Network diagram
Analysis
By default, a local user is assigned the user role network-operator. To allow the user to use all commands on the device, assign the user role network-admin to the user.
Procedures
# Change the device name and enable Telnet service.
[Sysname] sysname Device
[Device] telnet server enable
# Assign IP addresses to interfaces.
[Device] vlan 2
[Device-vlan2] port GigabitEthernet 3/0/1
[Device-vlan2] quit
[Device] interface Vlan-interface 2
[Device-Vlan-interface2] ip address 192.168.3.1 24
[Device-Vlan-interface2] quit
[Device] interface GigabitEthernet 3/0/1
[Device-GigabitEthernet3/0/1] undo shutdown
[Device-GigabitEthernet3/0/1] quit
[Device-GigabitEthernet3/0/1] ip address 192.168.3.1 24
[Device] interface Ten-GigabitEthernet 3/0/1
[Device-Ten-GigabitEthernet3/0/1] port link-mode route
[Device-Ten-GigabitEthernet3/0/1] ip address 192.168.3.1 24
[Device-Ten-GigabitEthernet3/0/1] quit
[Device] line vty 0 63
[Device-line-vty0-63] authentication-mode scheme
# Configure common VTY line settings.
[Device-line-vty0-63] screen-length 20
[Device-line-vty0-63] history-command max-size 100
[Device-line-vty0-63] idle-timeout 20
[Device-line-vty0-63] quit
# Set the maximum number of concurrent Telnet users to 10.
[Device] aaa session-limit telnet 10
# Create the local user test. Set the password to test (plain text).
[Device] local-user test class manage
[Device-luser-manage-test] password simple test
[Device-luser-manage-test] service-type telnet
[Device-luser-manage-test] authorization-attribute user-role network-admin
[Device-luser-manage-test] undo authorization-attribute user-role network-operator
[Device-luser-manage-test] quit
1.     Telnet to the device from Host A, and enter the username test and password test.
If the number of online Telnet users is less than 20, you are logged in to the system.
login: test
Password:
<Device>
If the number of concurrent Telnet users has reached the maximum number, an error message is displayed.
C:\Users\zhangsan>telnet 192.168.3.1
Trying 192.168.3.1 ...
Press CTRL+K to abort
Connected to 192.168.3.1 ...
Failed to connect to the remote host!
2.     After login, do not perform any operations within 20 minutes.
You are logged out.
login:
Configuration files
 sysname Device
interface Vlan-interface2
 ip address 192.168.3.1 255.255.255.0
interface GigabitEthernet3/0/1
 port link-mode bridge
 port access vlan 2
interface Ten-GigabitEthernet3/0/1
line vty 0 63
 idle-timeout 20 0
 screen-length 20
 password hash $h$6$/Xa6qIOrThQEVqbK$C00MPM5UaYoigaOfflWhpTskb/uB80yZ9O06tpztnDe
vrFEHqkvxfkSb4hUadHuknPSnjLNQByztfr30cP/Hlg==
 service-type telnet
Example: Telnetting from the device to another device
As shown in Figure 14, the user connected to Device A needs to Telnet to Device B to manage Device B.
·     Configure Telnet login to enable users to Telnet to Device A and Device B.
·     Configure Telnet user authentication on Device A so a Telnet user must provide the correct username and password to log in to Device A.
·     Configure access control so only Telnet users at 192.168.10.1/24 can Telnet to Device A and only Device A can Telnet to Device B.
·     Configure the devices to send up to 20 lines to the configuration terminal at a time.
Figure 14 Network diagram
Analysis
By default, a local user is assigned the default user role network-operator. To allow the user to use all commands on the device, assign the user role network-admin to the user.
To control Telnet login, configure an ACL on each device to permit access only from the specified IP address.
Procedures
Configuring Device A
# Log in to Device A through the console port. (Details not shown.)
[Sysname] sysname DeviceA
[DeviceA] telnet server enable
[DeviceA] vlan 2
[DeviceA-vlan2] port GigabitEthernet 3/0/2
[DeviceA-vlan2] quit
[DeviceA] interface Vlan-interface 2
[DeviceA-Vlan-interface2] ip address 192.168.10.2 24
[DeviceA-Vlan-interface2] quit
[DeviceA] vlan 3
[DeviceA-vlan3] port GigabitEthernet 3/0/1
[DeviceA-vlan3] quit
[DeviceA] interface Vlan-interface 3
[DeviceA-Vlan-interface3] ip address 192.168.3.2 24
[DeviceA-Vlan-interface3] quit
[DeviceA] interface GigabitEthernet 3/0/1
[DeviceA-GigabitEthernet3/0/1] undo shutdown
[DeviceA-GigabitEthernet3/0/1] quit
[DeviceA] interface GigabitEthernet 3/0/2
[DeviceA-GigabitEthernet3/0/2] undo shutdown
[DeviceA-GigabitEthernet3/0/2] quit
[DeviceA-GigabitEthernet3/0/1] ip address 192.168.3.2 24
[DeviceA-GigabitEthernet3/0/2] ip address 192.168.10.2 24
[DeviceA] interface Ten-GigabitEthernet 3/0/1
[DeviceA-Ten-GigabitEthernet3/0/1] ip address 192.168.3.2 24
[DeviceA-Ten-GigabitEthernet3/0/1] quit
[DeviceA] interface Ten-GigabitEthernet 3/0/2
[Device-Ten-GigabitEthernet3/0/2] port link-mode route
[DeviceA-Ten-GigabitEthernet3/0/2] ip address 192.168.10.2 24
[DeviceA-Ten-GigabitEthernet3/0/2] quit
[DeviceA] line vty 0 63
[DeviceA-line-vty0-63] authentication-mode scheme
[DeviceA-line-vty0-63] screen-length 20
[DeviceA-line-vty0-63] history-command max-size 100
[DeviceA-line-vty0-63] idle-timeout 20
[DeviceA-line-vty0-63] protocol inbound telnet
[DeviceA-line-vty0-63] quit
[DeviceA] local-user test class manage
[DeviceA-luser-manage-test] password simple test
[DeviceA-luser-manage-test] service-type telnet
[DeviceA-luser-manage-test] authorization-attribute user-role network-admin
[DeviceA-luser-manage-test] undo authorization-attribute user-role network-operator
[DeviceA-luser-manage-test] quit
# Create ACL 2000 and add rules to permit only access from 192.168.10.1.
[DeviceA] acl basic 2000
[DeviceA-acl-basic-2000] rule 1 permit source 192.168.10.1 0
[DeviceA-acl-basic-2000] rule 2 deny source any
[DeviceA-acl-basic-2000] quit
[DeviceA] telnet server acl 2000
Configuring Device B
# Log in to Device B through the console port. (Details not shown.)
[Sysname] sysname DeviceB
[DeviceB] telnet server enable
[DeviceB] vlan 3
[DeviceB-vlan3] port GigabitEthernet 3/0/1
[DeviceB-vlan3] quit
[DeviceB] interface Vlan-interface 3
[DeviceB-Vlan-interface3] ip address 192.168.3.1 24
[DeviceB-Vlan-interface3] quit
[DeviceB] interface GigabitEthernet 3/0/1
[DeviceB-GigabitEthernet3/0/1] undo shutdown
[DeviceB-GigabitEthernet3/0/1] quit
[DeviceB-GigabitEthernet3/0/1] ip address 192.168.3.1 24
[DeviceB] interface Ten-GigabitEthernet 3/0/1
[DeviceB-Ten-GigabitEthernet3/0/1] ip address 192.168.3.1 24
[DeviceB-Ten-GigabitEthernet3/0/1] quit
# Disable authentication for the Telnet login user.
[DeviceB] line vty 0 63
[DeviceB-line-vty0-63] authentication-mode none
[DeviceB-line-vty0-63] screen-length 20
[DeviceB-line-vty0-63] history-command max-size 100
[DeviceB-line-vty0-63] idle-timeout 20
[DeviceB-line-vty0-63] protocol inbound telnet
[DeviceB-line-vty0-63] quit
# Create ACL 2000 and add rules to permit only access from 192.168.3.2.
[DeviceB] acl basic 2000
[DeviceB-acl-basic-2000] rule 1 permit source 192.168.3.2 0
[DeviceB-acl-basic-2000] rule 2 deny source any
[DeviceB-acl-basic-2000] quit
[DeviceB] telnet server acl 2000
1.     Telnet to Device A from Host A and enter the username test and password test.
You are logged in to the system.
login: test
Password:
<DeviceA>
If you use another host to Telnet to Device A, your access request is rejected.
C:\Users\zhangsan>telnet 192.168.10.2
Trying 192.168.10.2 ...
Connected to 192.168.10.2 ...
2.     After login, do not perform any operations in 20 minutes.
You are logged out.
login:
3.     Telnet from Device A to Device B.
<DeviceA> telnet 192.168.3.1
<DeviceB>
If you use another host or device to Telnet to Device B, your access request is rejected.
[Telnet error. Number: 10061     Description: Connect method failed. No connection could be made because the target machine actively refused it.  This usually results from trying to connect to a service that is inactive on the foreign host
- i.e. one with no server application running.]
4.     After login, do not perform any operations within 20 minutes.
You are logged out.
Configuration files
·     Device A:
 sysname DeviceA
 ip address 192.168.10.2 255.255.255.0
interface Vlan-interface3
 ip address 192.168.3.2 255.255.255.0
 port access vlan 3
interface GigabitEthernet3/0/2
 port access vlan 2
interface Ten-GigabitEthernet3/0/2
line vty 0 63
 idle-timeout 20 0
 screen-length 20
acl basic 2000
 password hash $h$6$V5dw8qzFDLAOmDzx$upf9K29n110G6OGdSXI0t69IoE5eot/Qh9Iuv/hptq6
2vxUq3867QbUBzmc6/hHwIfVQcDC8gVWpGvDQWXQTSQ==
 service-type telnet
·     Device B:
 sysname DeviceB
 port access vlan 3
line vty 0 63
 idle-timeout 20 0
 screen-length 20
acl basic 2000
Related documentation
·     H3C S6860 Switch Series Fundamentals Command Reference-Release 26xx
·     H3C S6860 Switch Series Fundamentals Configuration Guide-Release 26xx
H3C reserves the right to modify its collaterals without any prior notice. For the latest information of the collaterals, please consult H3C sales or call 400 hotline.
