- H3C SecPath M9000 Multi Service Security Gateway Configuration Examples(V7)(E9X71)-6W700
- 01-About the configuration examples
- 02-Web Login Configuration Examples
- 03-Internet Access Through a Static IP Address Configuration Examples
- 04-Internet access through PPPoE configuration examples
- 05-License Configuration Examples
- 06-Signature Library Upgrade Configuration Examples
- 07-Software Upgrade Examples
- 08-Routing deployment configuration examples
- 09-Transparent deployment configuration examples
- 10-Static routing configuration examples
- 11-RIP configuration examples
- 12-OSPF configuration examples
- 13-BGP configuration examples
- 14-Policy-based routing configuration examples
- 15-Security Policy Configuration Examples
- 16-APR-Based Security Policy Configuration Examples
- 17-Object Group Configuration Examples
- 18-User identification configuration examples
- 19-Attack defense configuration examples
- 20-Request Limit Configuration Examples
- 21-IPS Configuration Examples
- 22-URL Filtering Configuration Examples
- 23-Anti-Virus Configuration Examples
- 24-File Filtering Configuration Examples
- 25-Data Filtering Configuration Examples
- 26-WAF Configuration Examples
- 27-IP Reputation Configuration Examples
- 28-APT Defense Configuration Examples
- 29-NetShare Control Configuration Examples
- 30-Bandwidth Management Configuration Examples
- 31-IPsec configuration examples
- 32-SSL VPN IP access configuration examples
- 32-SSL VPN TCP access configuration examples
- 32-SSL VPN Web access configuration examples
- 33-L2TP Configuration Examples
- 34-NAT configuration examples
- 35-NPTv6 Configuration Examples
- 36-Policy-based NAT configuration examples
- 37-NAT hairpin configuration examples
- 38-NAT Flow Logging Configuration Examples
- 39-Inbound Link Load Balancing Configuration Examples
- 40-Outbound Link Load Balancing Configuration Examples
- 41-Server Load Balancing Configuration Examples
- 42-Transparent DNS Proxy Configuration Examples
- 43-Hot Backup Configuration Examples
- 44-Context Configuration Examples
- 45-DNS configuration examples
- 46-Server Connection Detection Configuration Examples
- 47-Connection Limit Configuration Examples
- 48-Public key management configuration examples
- 49-SSL Decryption Configuration Examples
- 50-MAC Address Learning Through a Layer 3 Device Configuration Examples
- 51-4G Configuration Examples
- 52-WLAN Configuration Examples
| 13-BGP configuration examples | 289.56 KB |
The following information provides BGP configuration examples.
This document is not restricted to specific software or hardware versions. Procedures and information in the examples might be slightly different depending on the software or hardware version of the device.
The following information is provided based on the assumption that you have basic knowledge of BGP.
As shown in Figure 1, Device A and Device B are connected to R&D and finance departments, respectively. Device C is a router that acts as the gateway to the Internet.
Configure BGP on the devices to enable the R&D and finance departments to learn routing information from each other. Configure a default route with the next hop being gateway address 200.2.2.254 on Device C, and redistribute the default route to BGP.
Software versions used
This configuration example was created and verified on E8371 of the F5000-AI160 device.
This configuration example was created and verified on E9671 of the M9000-X06 device.
BGP uses TCP (port number 179) to establish peer relationships. You must configure a security policy to permit the traffic between the local security zone and the security zones that contain the BGP interfaces. For more information, see the configuration procedure.
By default, BGP does not redistribute default IGP routes. To redistribute default IGP routes into the BGP routing table, you must use the default-route imported command together with the import-route command.
Configuring Device A
1. Assign IP addresses to interfaces and add the interfaces to security zones.
# On the top navigation bar, click Network.
# From the navigation pane, select Interface Configuration > Interfaces.
# Click the Edit icon for GE 1/0/1.
# In the dialog box that opens, configure the interface:
a. Select the Untrust security zone.
b. On the IPv4 Address tab, enter the IP address and mask of the interface. In this example, enter 10.0.0.1/30.
c. Retain the default configuration for the rest of parameters.
d. Click OK.
# Add GE 1/0/2 to the Trust security zone and set its IP address to 10.1.1.1/24 in the same way you configure GE 1/0/1.
2. Create security policies.
# On the top navigation bar, click Policies.
# From the navigation pane, select Security Policies > Security Policies.
# Select Create > Create a policy.
# Create security policy bgp-a:
¡ Enter policy name bgp-a.
¡ Select source zone Trust.
¡ Select destination zone Untrust.
¡ Select type IPv4.
¡ Select action Permit.
¡ Enter 10.1.1.0/24 as the source address.
¡ Retain the default configuration for the rest of parameters.
# Click OK.
# Create security policy bgp-b:
¡ Enter policy name bgp-b.
¡ Select source zone Local.
¡ Select type IPv4.
¡ Select service object group bgp.
# Click OK.
# Create security policy bgp-c:
¡ Enter policy name bgp-c.
¡ Select source zone Untrust.
¡ Select destination zone Local.
¡ Select type IPv4.
# Click OK.
3. Configure an underlying routing protocol. In this example, configure RIP.
# From the navigation pane, select Routing > RIP.
# Click Create.
# In the dialog box that opens, configure a RIP instance.
Figure 2 RIP instance
4. Configure BGP.
# From the navigation pane, select Routing > BGP.
# Select Enable BGP, enter AS number 65534, and then click Apply.
Figure 3 Configuring BGP
# On the BGP Address Family tab, select an address family, and then click Apply.
Figure 4 Selecting a BGP address family
# On the BGP Peer tab, click Create.
# In the dialog box that opens, specify a BGP peer, and then click OK.
Figure 5 Specifying a BGP peer
# Repeat the above two steps to specify another BGP peer.
Figure 6 Specifying another BGP peer
Figure 7 BGP peers
# On the BGP Network tab, click Create.
# In the dialog box that opens, specify the network to be advertised for the specified address family, and then click OK.
Figure 8 BGP network advertisement
Figure 9 BGP network advertisement
Configuring Device B
b. On the IPv4 Address tab, enter the IP address and mask of the interface. In this example, enter 10.0.0.5/30.
d. Click OK.
# Add GE 1/0/2 to the Trust security zone and set its IP address to 10.2.2.1/24 in the same way you configure GE 1/0/1.
¡ Select type IPv4.
¡ Enter 10.2.2.0/24 as the source address.
# Click OK.
¡ Select type IPv4.
# Click OK.
¡ Select type IPv4.
# Click OK.
# Click Create.
Figure 10 RIP instance
4. Configure BGP.
Figure 11 Configuring BGP
Figure 12 Selecting a BGP address family
Figure 13 Specifying a BGP peer
Figure 14 Specifying another BGP peer
Figure 15 BGP peers
Figure 16 BGP network advertisement
Figure 17 BGP network advertisement
Configuring Device C
1. Assign IP addresses to interfaces. (Details not shown.)
2. Configure an underlying routing protocol. In this example, configure RIP.
<Device C> system-view
[Device C]rip
[Device C-rip-1]network 10.0.0.0 0.0.0.255
3. Configure BGP.
# Enable BGP.
[Device C] bgp 65534
# Specify BGP peers.
[Device C-bgp-default]peer 10.0.0.1 as 65534
[Device C-bgp-default]peer 10.0.0.5 as 65534
# Enable BGP peers.
[Device C-bgp-default]address-family ipv4 unicast
[Device C-bgp-default-ipv4]peer 10.0.0.1 enable
[Device C-bgp-default-ipv4]peer 10.0.0.5 enable
[Device C-bgp-default-ipv4]quit
[Device C-bgp-default]quit
# Configure the default route to the ISP.
[Device C] ip route-static 0.0.0.0 0 200.2.2.254
# Redistribute the default route to the BGP routing table.
[Device C]bgp 65534
[Device C-bgp-default-ipv4]import-route static
[Device C-bgp-default-ipv4]default-route imported
1. View information about BGP peers of Device A.
# On the BGP Peer tab, verify that the BGP peers are in Established state.
Figure 18 BGP routing table of Device A
You can see that the BGP peers are in Established state.
2. View information about BGP peers of Device B.
Figure 19 BGP routing table of Device B
3. View information about the BGP routing table of Device A.
# From the navigation pane, select Routing > Routing Table.
# On the IPv4 Routing Table tab, view the BGP routing table information.
Figure 20 BGP routing table of Device A
You can see the redistributed BGP route and default route.
4. View information about the BGP routing table of Device B.
Figure 21 BGP routing table of Device B
5. Verify that Device A can ping the ISP.
<Device A> ping -a 10.1.1.1 200.2.2.254
Ping 200.2.2.254 (200.2.2.254) from 10.1.1.1: 56 data bytes, press CTRL_C to break
56 bytes from 200.2.2.254: icmp_seq=0 ttl=254 time=0.423 ms
56 bytes from 200.2.2.254: icmp_seq=1 ttl=254 time=0.222 ms
56 bytes from 200.2.2.254: icmp_seq=2 ttl=254 time=0.173 ms
56 bytes from 200.2.2.254: icmp_seq=3 ttl=254 time=0.170 ms
56 bytes from 200.2.2.254: icmp_seq=4 ttl=254 time=0.167 ms
--- Ping statistics for 200.2.2.254 ---
round-trip min/avg/max/std-dev = 0.167/0.231/0.423/0.098 ms
The output shows that the ISP can be pinged.
6. Verify that Device B can ping the ISP.
<Device B> ping -a 10.0.0.5 200.2.2.254
Ping 200.2.2.254 (200.2.2.254) from 10.0.0.5: 56 data bytes, press CTRL_C to break
56 bytes from 200.2.2.254: icmp_seq=0 ttl=254 time=0.437 ms
56 bytes from 200.2.2.254: icmp_seq=1 ttl=254 time=0.209 ms
56 bytes from 200.2.2.254: icmp_seq=2 ttl=254 time=0.194 ms
56 bytes from 200.2.2.254: icmp_seq=3 ttl=254 time=0.174 ms
56 bytes from 200.2.2.254: icmp_seq=4 ttl=254 time=0.179 ms
round-trip min/avg/max/std-dev = 0.174/0.239/0.437/0.100 ms
