- H3C SecPath M9000 Multi Service Security Gateway Configuration Examples(V7)(E9X71)-6W700
- 01-About the configuration examples
- 02-Web Login Configuration Examples
- 03-Internet Access Through a Static IP Address Configuration Examples
- 04-Internet access through PPPoE configuration examples
- 05-License Configuration Examples
- 06-Signature Library Upgrade Configuration Examples
- 07-Software Upgrade Examples
- 08-Routing deployment configuration examples
- 09-Transparent deployment configuration examples
- 10-Static routing configuration examples
- 11-RIP configuration examples
- 12-OSPF configuration examples
- 13-BGP configuration examples
- 14-Policy-based routing configuration examples
- 15-Security Policy Configuration Examples
- 16-APR-Based Security Policy Configuration Examples
- 17-Object Group Configuration Examples
- 18-User identification configuration examples
- 19-Attack defense configuration examples
- 20-Request Limit Configuration Examples
- 21-IPS Configuration Examples
- 22-URL Filtering Configuration Examples
- 23-Anti-Virus Configuration Examples
- 24-File Filtering Configuration Examples
- 25-Data Filtering Configuration Examples
- 26-WAF Configuration Examples
- 27-IP Reputation Configuration Examples
- 28-APT Defense Configuration Examples
- 29-NetShare Control Configuration Examples
- 30-Bandwidth Management Configuration Examples
- 31-IPsec configuration examples
- 32-SSL VPN IP access configuration examples
- 32-SSL VPN TCP access configuration examples
- 32-SSL VPN Web access configuration examples
- 33-L2TP Configuration Examples
- 34-NAT configuration examples
- 35-NPTv6 Configuration Examples
- 36-Policy-based NAT configuration examples
- 37-NAT hairpin configuration examples
- 38-NAT Flow Logging Configuration Examples
- 39-Inbound Link Load Balancing Configuration Examples
- 40-Outbound Link Load Balancing Configuration Examples
- 41-Server Load Balancing Configuration Examples
- 42-Transparent DNS Proxy Configuration Examples
- 43-Hot Backup Configuration Examples
- 44-Context Configuration Examples
- 45-DNS configuration examples
- 46-Server Connection Detection Configuration Examples
- 47-Connection Limit Configuration Examples
- 48-Public key management configuration examples
- 49-SSL Decryption Configuration Examples
- 50-MAC Address Learning Through a Layer 3 Device Configuration Examples
- 51-4G Configuration Examples
- 52-WLAN Configuration Examples
| 03-Internet Access Through a Static IP Address Configuration Examples | 231.74 KB |
Internet access through a static IP address configuration examples
· Example: Configuring Internet access through a static IP address
The following information provides the configuration examples of using a static IP address to access the Internet.
This document is not restricted to specific software or hardware versions. Procedures and information in the examples might be slightly different depending on the software or hardware version of the device.
The following information is provided based on the assumption that you have basic knowledge of IP features.
As shown in Figure 1, a device is deployed as the egress device that connects the internal network to the ISP. Perform the following tasks to allow the internal users to access the Internet:
· Configure the DHCP server on the device to assign private IP addresses and the DNS server address to the hosts.
· Allow the internal users to access the Web server on the Internet. The website of the Web server is www.example.com.
Software versions used
This configuration example was created and verified on E8371 of the F5000-AI160 device.
When you configure the DHCP server on the device, perform the following tasks:
· Allow traffic from security zones Trust (to which the DHCP server belongs) to Local to ensure that the DHCP clients can obtain IP addresses.
· Enable DNS service on the device to convey DNS requests between the DNS server and the DNS clients.
Configuring the device
1. Configure a static IP address.
# On the top navigation bar, click System.
# From the navigation pane, select Configuration Wizard > Internet Access.
Figure 2 Internet access configuration page
# Select the routing mode and click Configure.
# Configure the WAN interface as shown in Figure 3.
Figure 3 WAN interface configuration
# Click Next.
# Configure the LAN interface as shown in Figure 4.
Figure 4 LAN interface configuration
# Click Next. Skip the security cloud configuration.
# Click Next. The following page opens.
Figure 5 Verifying the configuration
# Verify the configuration and click Finish.
2. Configure a security policy.
# After you configure the Internet access through a static IP address, the system automatically creates a security policy named GuideSecPolicy.
# To view the security policy:
a. On the top navigation bar, click Policies.
b. From the navigation pane, select Security Policies > Security Policies.
Figure 6 Security policy configuration page
# Click the Edit icon for this security policy.
# In the dialog box that opens, add security zone Local to the source zones, and add security zones Trust and Local to the destination zones.
Figure 7 Editing the security policy
3. Configure DHCP.
# On the top navigation bar, click Network.
# From the navigation pane, select DHCP > DHCP Address Pools.
# Click the Address Pool Options tab, and configure the settings as shown in Figure 8.
Figure 8 Address pool option configuration
4. Configure DNS service.
# From the navigation pane, select DNS > Advanced Settings.
# Enable the DNS service.
Figure 9 DNS service configuration page
Configuring the host
# Configure the host to obtain an IP address through DHCP.
1. Display the IP address that the host obtains.
C:\>ipconfig /all
Ethernet adapter Ethernet 1:
Connection-specific DNS SUffix.:
Description....................: Intel(R) 82579LM Gigabit Network Connection
Physical Address...............: E8-39-35-5C-92-B8
DHCP Enabled ..................: Yes
Autoconfiguration Enabled......: Yes
Link-local IPv6 Address........: fe80::b8dd:d091:201a:6db2%13(Preferred)
IPv4 Address...................: 172.16.1.3(Preferred)
Subnet Mask....................: 255.255.255.0
Lease Obtained.................: Monday, October 8, 2018 2:44:36 AM
Lease Expires..................: Tuesday, October 9, 2018 2:44:36 AM
Default Gateway................: 172.16.1.254
DHCP Server....................: 172.16.1.254
DHCPv6 IAID....................: 384317749
DHCPv6 Client DUID.............: 00-01-00-01-1F-B4-A3-F5-B8-A3-86-6F-0F-02
DNS Server.....................: 219.141.136.102
NetBIOS over Tcpip.............: Enabled
2. Verify that you can ping a domain name on the public network from the host.
C:\>ping www.example.com
Pinging www.example.com [192.168.100.201] with 32 bytes of data:
Reply from 192.168.100.201: bytes=32 time<1ms TTL=253
Ping statistics for 192.168.100.201:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss)
Minimum = 0ms, Maximum = 0ms, Average = 0ms
