- H3C SecPath M9000 Multi Service Security Gateway Configuration Examples(V7)(E9X71)-6W700
- 01-About the configuration examples
- 02-Web Login Configuration Examples
- 03-Internet Access Through a Static IP Address Configuration Examples
- 04-Internet access through PPPoE configuration examples
- 05-License Configuration Examples
- 06-Signature Library Upgrade Configuration Examples
- 07-Software Upgrade Examples
- 08-Routing deployment configuration examples
- 09-Transparent deployment configuration examples
- 10-Static routing configuration examples
- 11-RIP configuration examples
- 12-OSPF configuration examples
- 13-BGP configuration examples
- 14-Policy-based routing configuration examples
- 15-Security Policy Configuration Examples
- 16-APR-Based Security Policy Configuration Examples
- 17-Object Group Configuration Examples
- 18-User identification configuration examples
- 19-Attack defense configuration examples
- 20-Request Limit Configuration Examples
- 21-IPS Configuration Examples
- 22-URL Filtering Configuration Examples
- 23-Anti-Virus Configuration Examples
- 24-File Filtering Configuration Examples
- 25-Data Filtering Configuration Examples
- 26-WAF Configuration Examples
- 27-IP Reputation Configuration Examples
- 28-APT Defense Configuration Examples
- 29-NetShare Control Configuration Examples
- 30-Bandwidth Management Configuration Examples
- 31-IPsec configuration examples
- 32-SSL VPN IP access configuration examples
- 32-SSL VPN TCP access configuration examples
- 32-SSL VPN Web access configuration examples
- 33-L2TP Configuration Examples
- 34-NAT configuration examples
- 35-NPTv6 Configuration Examples
- 36-Policy-based NAT configuration examples
- 37-NAT hairpin configuration examples
- 38-NAT Flow Logging Configuration Examples
- 39-Inbound Link Load Balancing Configuration Examples
- 40-Outbound Link Load Balancing Configuration Examples
- 41-Server Load Balancing Configuration Examples
- 42-Transparent DNS Proxy Configuration Examples
- 43-Hot Backup Configuration Examples
- 44-Context Configuration Examples
- 45-DNS configuration examples
- 46-Server Connection Detection Configuration Examples
- 47-Connection Limit Configuration Examples
- 48-Public key management configuration examples
- 49-SSL Decryption Configuration Examples
- 50-MAC Address Learning Through a Layer 3 Device Configuration Examples
- 51-4G Configuration Examples
- 52-WLAN Configuration Examples
| 22-URL Filtering Configuration Examples | 132.31 KB |
URL filtering configuration examples
· Example: Configuring URL filtering
The following information provides URL filtering configuration examples.
This document is not restricted to specific software or hardware versions. Procedures and information in the examples might be slightly different depending on the software or hardware version of the device.
The following information is provided based on the assumption that you have basic knowledge of the URL filtering feature.
The URL filtering feature requires a license to run on the device. After the license expires, URL filtering can use the existing URL filtering signature library on the device, but the library cannot be updated.
As shown in Figure 1, a security gateway device is deployed at the border of the enterprise network. Configure URL filtering on the device to block and log the following Internet access behaviors of internal users:
· Access to shopping website taobao and adult websites.
· Access to the www.tudou.com website.
Software versions used
This configuration example was created and verified on E8371 of the F5000-AI160 device.
This configuration example was created and verified on E9671 of the M9000-X06 device.
1. Assign IP addresses to interfaces:
# On the top navigation bar, click Network.
# From the navigation pane, select Interface Configuration > Interfaces.
# Click the Edit icon for GE 1/0/1.
# In the dialog box that opens, configure the interface:
a. Select the Trust security zone.
b. Click the IPv4 Address tab, and then enter the IP address and mask length of the interface. In this example, enter 10.1.1.1/24.
c. Use the default settings for other parameters.
d. Click OK.
# Add GE 1/0/2 to the Untrust security zone and set its IP address to 20.1.1.1./24 in the same way you configure GE 1/0/1.
2. Configure routing settings.
This example configures a static route. To use dynamic routing, configure dynamic routing protocols as required.
Configure the next hop IP address to reach the Web server in the external network according to the actual network conditions. In this example, the next hop IP address is 20.1.1.2.
To configure a static route:
# From the navigation pane, select Routing > Static Routing.
# On the IPv4 Static Routing tab, click Create.
# In the dialog box that opens, configure a static IPv4 route to reach 0.0.0.0:
¡ Enter destination IP address 5.5.5.0.
¡ Enter mask length 24.
¡ Enter next hop address 20.1.1.2.
¡ Use the default settings for other parameters.
# Click OK.
3. Update the URL filtering signature library to the latest version. (Details not shown.)
4. Configure a URL category:
# On the top navigation bar, click Objects.
# From the navigation pane, select APPSecurity > URL Filtering > URL Categories.
# Click Create.
# In the dialog box that opens, configure a URL category:
¡ Enter shopping in the Name field.
¡ Set the severity level to 2000.
¡ Click Add.
¡ In the dialog box that opens, select Regular expression from the Match pattern list and enter taobao in the Host name field, and then click OK.
Figure 2 Adding a rule to the URL category
# Click OK.
5. Configure a URL filtering profile:
# From the navigation pane, select APPSecurity > URL Filtering > Profiles.
# Click Create.
# In the dialog box that opens, configure a URL filtering profile:
¡ Enter the name urlfilter.
¡ Select Permit as the default action.
¡ Select the Logging option.
¡ In the Blacklist area, click Add.
¡ In the dialog box that opens, select Text from the Match pattern list and enter www.tudou.com in the Host name field, and then click OK.
Figure 3 Adding a blacklist rule
¡ In the URL categories area, select the Drop and Logging actions for user-defined URL category shopping and predefined URL category Pre-Adult.
# Click OK.
Figure 4 Configuring a URL filtering profile
6. Create a security policy:
# On the top navigation bar, click Policies.
# From the navigation pane, select Security Policies > Security Policies.
# Click Create, and then click Create a policy.
# In the dialog box that opens, configure a security policy named urlfilter to permit the specified traffic from the Untrust to Trust security zones:
¡ Enter policy name urlfilter.
¡ Select source zone Untrust.
¡ Select destination zone Trust.
¡ Select type IPv4.
¡ Select action Permit.
¡ Select source IP address 10.1.1.0/24.
¡ Select URL filtering profile urlfilter in the Content security area.
# Click OK.
7. Activate the settings on the Security Policies page:
# After you apply the URL filtering profile to the security policy, click Submit (the second Submit in Figure 5) to have the content security configuration take effect.
# Click Activate (the first Submit in Figure 5) to activate security policy matching acceleration.
Figure 5 Activate security policy settings
8. Enable logging:
# On the top navigation bar, click System.
# From the navigation pane, select Log Settings > Basic Settings.
# Click the Storage Space Settings tab.
# Edit the storage space settings for the URL filtering service and enable logging for the service.
Verify that URL filtering can log and block the following Internet access behaviors of internal users:
To view the logs generated for these behaviors, click Monitor on the top navigation bar, and then select Security Logs > URL Filtering Logs from the navigation pane.
