- H3C SecPath M9000 Multi Service Security Gateway Configuration Examples(V7)(E9X71)-6W700
- 01-About the configuration examples
- 02-Web Login Configuration Examples
- 03-Internet Access Through a Static IP Address Configuration Examples
- 04-Internet access through PPPoE configuration examples
- 05-License Configuration Examples
- 06-Signature Library Upgrade Configuration Examples
- 07-Software Upgrade Examples
- 08-Routing deployment configuration examples
- 09-Transparent deployment configuration examples
- 10-Static routing configuration examples
- 11-RIP configuration examples
- 12-OSPF configuration examples
- 13-BGP configuration examples
- 14-Policy-based routing configuration examples
- 15-Security Policy Configuration Examples
- 16-APR-Based Security Policy Configuration Examples
- 17-Object Group Configuration Examples
- 18-User identification configuration examples
- 19-Attack defense configuration examples
- 20-Request Limit Configuration Examples
- 21-IPS Configuration Examples
- 22-URL Filtering Configuration Examples
- 23-Anti-Virus Configuration Examples
- 24-File Filtering Configuration Examples
- 25-Data Filtering Configuration Examples
- 26-WAF Configuration Examples
- 27-IP Reputation Configuration Examples
- 28-APT Defense Configuration Examples
- 29-NetShare Control Configuration Examples
- 30-Bandwidth Management Configuration Examples
- 31-IPsec configuration examples
- 32-SSL VPN IP access configuration examples
- 32-SSL VPN TCP access configuration examples
- 32-SSL VPN Web access configuration examples
- 33-L2TP Configuration Examples
- 34-NAT configuration examples
- 35-NPTv6 Configuration Examples
- 36-Policy-based NAT configuration examples
- 37-NAT hairpin configuration examples
- 38-NAT Flow Logging Configuration Examples
- 39-Inbound Link Load Balancing Configuration Examples
- 40-Outbound Link Load Balancing Configuration Examples
- 41-Server Load Balancing Configuration Examples
- 42-Transparent DNS Proxy Configuration Examples
- 43-Hot Backup Configuration Examples
- 44-Context Configuration Examples
- 45-DNS configuration examples
- 46-Server Connection Detection Configuration Examples
- 47-Connection Limit Configuration Examples
- 48-Public key management configuration examples
- 49-SSL Decryption Configuration Examples
- 50-MAC Address Learning Through a Layer 3 Device Configuration Examples
- 51-4G Configuration Examples
- 52-WLAN Configuration Examples
| 35-NPTv6 Configuration Examples | 151.83 KB |
· Example: Configuring source address translation
· Example: Configuring destination address translation
The following information provides NPTv6 configuration examples.
IPv6-to-IPv6 Network Prefix Translation (NPTv6), also known as NAT66, translates the internal IPv6 prefix in the IPv6 packet header to an external IPv6 prefix and vice versa.
NPTv6 supports the following address translation methods:
· Source address translation—Translates source IPv6 addresses in packets when internal users access an external network.
· Destination address translation—Translates destination IPv6 addresses in packets when external hosts access servers in the internal network.
This document is not restricted to specific software or hardware versions. Procedures and information in the examples might be slightly different depending on the software or hardware version of the device.
The following information is provided based on the assumption that you have basic knowledge of the NPTv6 feature.
This feature is mutually exclusive with global NAT.
As shown in Figure 1, configure source address translation on the device to allow internal users to access the server in the external network.
Software versions used
This configuration example was created and verified on E8371 of the F5000-AI160 device and E9671 of the M9000-X06 device.
1. Assign IP addresses to interfaces and add the interfaces to security zones.
# On the top navigation bar, click Network.
# From the navigation pane, select Interface Configuration > Interfaces.
# Click the Edit icon for GE 1/0/1.
# In the dialog box that opens, configure the interface:
a. Select the Untrust security zone.
b. On the IPv6 Address tab, enter the IPv6 global unicast address and prefix of the interface. In this example, enter 2019:2019:2019:1010::100/64.
c. Retain the default configuration for the rest of parameters.
d. Click OK.
# Add GE 1/0/0 to the Trust security zone and set its IPv6 global unicast address to FEC0:FEC0:FEC0:1010::100/64 in the same way you configure GE 1/0/1.
2. Create a route.
The following configuration example involves only static route for illustration. To apply a dynamic route, you can configure a dynamic routing protocol as needed.
# From the navigation pane, select Routing > Static Routing > IPv6 Static Routing.
# Click Create.
# In the dialog box that opens, create an IPv6 static route.
¡ Enter 2019:2019:2019:1011::1 as the destination address.
¡ Set the prefix length to 64.
¡ Enter 2019:2019:2019:1010::101 as the next hop.
¡ Retain the default configuration for the rest of parameters.
# Click OK.
3. Create a security policy.
# On the top navigation bar, click Policies.
# From the navigation pane, select Security Policies > Security Policies.
# Click Create.
# In the dialog box that appears, configure a security policy to allow packets from the internal network to pass through.
¡ Enter policy name Secpolicy.
¡ Select source zone Trust.
¡ Select destination zone Untrust.
¡ Select type IPv6.
¡ Select action Permit.
¡ Enter FEC0:FEC0:FEC0:1010::1 as the source address.
# Click OK.
4. Configure NPTv6.
# From the navigation pane, select Interface NAT > IPv6.
# Click Create.
# Create a prefix translation mapping, as shown in Figure 2.
Figure 2 Creating a NAT66 prefix translation mapping
# Click OK.
1. Verify that the host can successfully ping the server in the external network.
C:\Users\abc>ping 2019:2019:2019:1011::1
Pinging 2019:2019:2019:1011::1 with 32 bytes of data:
Reply from 2019:2019:2019:1011::1: bytes=32 time<1ms TTL=253
Ping statistics for 2019:2019:2019:1011::1:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
2. Verify that a session is generated when the host accesses the server.
# On the top navigation bar, click Monitor.
# From the navigation pane, select Sessions.
Figure 3 Session list
As shown in Figure 4, configure destination address translation on the device to allow the external host to access the internal Web server.
d. Click OK.
# Add GE 1/0/0 to the Trust security zone and set its IPv6 address to FEC0:FEC0:FEC0:1010::100/64 in the same way you configure GE 1/0/1.
2. Create a route.
# Click Create.
¡ Enter :: as the destination address.
¡ Set the prefix length to 0.
# Click OK.
# Click Create.
# In the dialog box that appears, configure a security policy to allow packets from the external host to pass through.
¡ Select source zone Untrust.
¡ Select destination zone Trust.
¡ Select type IPv6.
¡ Enter 2019:2019:2019:1011::1 as the source address.
¡ Enter FEC0:FEC0:FEC0:1010::1 as the destination address.
# Click OK.
4. Configure NPTv6.
# Click Create.
# Create a prefix translation mapping, as shown in Figure 5.
Figure 5 Creating a NAT66 prefix translation mapping
# Click OK.
1. Verify that the host can successfully ping the internal Web server.
2. Verify that a session is generated when the host accesses the internal Web server.
Figure 6 Session list
